Statis NAT and HSRP on Layer 3 switches
sbgcsdtsg
We have a 6509 switch (server farm switch)to which all the servers are connected. Access layer has 2 no. 3750 switches in HSRP mode connected to server farm switch through a set of distribution and core switches. All of these switches are 6500. VLANs have been created on 3750 switches in HSRP mode.
I wish to do static NAT for a server in server farm switch.
When I ping to Global IP of server, from access layer switch or a PC connected to 3750, there is a packet drop after every 2 packets.
If HSRP is removed from 3750 switch, it becomes fine. What could be the issue?
thanks
EK
satish_zanjurne
Level 4
Level 4
hi,
Can attach the diagram ?
You said, HSRP is running on access switch !!!
Bit confusing !!
