Stop logging of Port up/down
ahmad82pkn
Level 3
Level 3
We have our remote offices Core switches pointing to our syslog.
Problem is that those Core switches has servers/printers that keep going up/down through out the day , and we see ports up/down alert on syslog.
We want to stop receiving port up/down message on syslog.
one option is to disable logging of the ports with command no logging event link-status.
but it also stops logging of port up/down event in buffer, even if someone admin shutdown the port, buffer will not have that log.
How can i have logging still available for ports going up/down in buffer, but dont receive it in syslog server?
Philip D'Ath
The answer depends on your switch model a little.  Try applying this interface configuration:
interface Gigabit a/b/c
Oops, silly me.  You specifically mention this in your post.
Paul Bundschuh
One workaround it to keep using your "no logging event link-status" status on the ports, but also configure buffer/syslog logging of all configuration changes, which would record any admin shutdown port changes (along with all other config changes). We use this on our routers and switches - it will put messages in the buffer and to any remote syslog server you have configured:
archive
  log config
    logging enable
    notify syslog content type plaintext
    hidekeys
