Stopping 6506 CatOS Auto Reboot
davidhuynh5
I have a Cat6506 running CatOS with Sup720. The supervisory modules keeps on rebooting (see attachment). How can I break out of this? Thanks in advance.
glen.grant
I would call the TAC if it is happening continuosly. It's either a supervisor or memory problem and would probably have to be replaced.
There is no break sequence to get into ROMMON?
Hi David,
You can go to ROMmon but I doubt if you can do anything to fix the blade.
You need to contact Cisco TAC and get the blade RMA-ed because it has totally (and utterly) failed. Based on the following error messages:
SysAD Parity Error Exception occurred on Mar 30 2009 06:53:22
Nested exception occured
*** Mistral Interrupt on line 2 ***
IO bus interrupt due to illegal addr, no ack, etc
PC = 0xbfc12a04, Cause = 0x1000, Status Reg = 0x30419003
ROM Monitor Can Not Recover From Exception
A Board Reset Is Issued
Address trap interrupt ..
PC = 0xbfc278bc, Cause = 0x80001000, Status Reg = 0x30419003
Cat6k-Sup720/SP processor with 524288 Kbytes of main memory
