Bookmark
Subscribe
7005
%STORM_CONTROL-3-SHUTDOWN - How do know if mulitcast or broadcast triggered it
jmandersson
Hi Experts,
I'm trying to tune our Storm-Control settings on host ports and have problems to determine if it's broadcast or multicast levels that's need to be adjusted.
When the upper level has been exceeded, a syslog is generated but it does not includ information if it was broadcast or multicast. show storm-control interface only show current level so it does not help me.
Any creative idea's are welcome!
JOhan
8 Replies 8
Ganesh Hariharan
Hello Johan,
I belive show strom-control can give details with interface , type , filter state , upper , lower level and current rate.
Hope it Helps..
-GI
No, show storm-control only show configured values and current rate. That does not help me to afterwards determine which of the threshold that where exceeded.
Johan
InayathUlla Sharieff
Johan,
The below link will help you:-
http://www.netcraftsmen.com/understanding-cisco-traffic-storm-control/
http://packetlife.net/blog/2008/nov/27/storm-control/
Inayagth
Hi Inayagth,
Thanks for the link, good info indeed.
Packetlifes blogpost show an intressting difference:
Packelifes example log:" %STORM_CONTROL-3-FILTERED: A Broadcast storm detected on Fa0/5. A packet filter action has been applied on the interface."
Fro the switches I'm currently working on (3650):  %STORM_CONTROL-3-SHUTDOWN: A packet storm was detected on Gi1/0/28. The interface has been disabled.
The 3650 does not point out that it was a broadcast storm, it just says a paket storm
The blogpost on Netcraftsmen do help, it explains that there are in fact one threshold, not seperate for Broadcast, Multicast or Unicast.  Unforuntally it seems to be platform dependet.
I have Storm Control enabled on a  3750 stack, code 15.0(2)SE8.  I do see a distinction in the logs:
%STORM_CONTROL-3-FILTERED: A Unicast storm detected on Gi2/0/21. A packet filter action has been applied on the interface
I assuming the 3650 is running IOS-XE?  Perhaps that's why the messaging is different.
I added the "storm-control action shutdown" statement on my ports and now see these:
%PM-4-ERR_DISABLE: storm-control error detected on Gi1/0/1, putting Gi1/0/1 in err-disable state
%STORM_CONTROL-3-SHUTDOWN: A packet storm was detected on Gi1/0/1. The interface has been disabled.
So I'd conclude that the log message only differentiates unicast/broadcast/multicast when filtering.  Enabling shutdown causes it to not log which type of storm occurred.
That's an interessting finding. I will definitly test that.
Thanks!
simr1874
Hello Guys,
I am getting the events on Qradar about Multicast storm detected on Te0/5/8. A packet filter action has been applied on the interface. I just wanted to know that is there an security issue with this or not?
