Storm-control recommended level
s.lachica
        Hello, we are to configure storm-control on a newly-deployed Campus network. We are required by the customer to set a storm-control value to each Ethernet interface. We are planning to set 10 for multicast but this is just an assumption from us out of nowhere. Are there any recommended or best practice value for storm-control? And another question is, it is a best practice to configure it to each ethernet interface (access/trunk)?
CCIE (R&S) #27666 CCSI HP MASE
Reza Sharifi
All routers in a VLAN see copies of all broadcast  traffic. To avoid high RP CPU utilization caused by a high volume of  broadcast traffic, the threshold is typically set to a very low value;  for example, less than 1 percent on a Gigabit Ethernet port.
Here is the best practice doc:
http://www.cisco.com/en/US/docs/switches/lan/catalyst6500/ios/12.2SX/best/practices/recommendations.html#wp1044029
Joseph W. Doherty
Disclaimer
The  Author of this posting offers the information contained within this  posting without consideration and with the reader's understanding that  there's no implied or expressed suitability or fitness for any purpose.  Information provided is for informational purposes only and should not  be construed as rendering professional advice of any kind. Usage of this  posting's information is solely at reader's own risk.
Liability Disclaimer
In  no event shall Author be liable for any damages whatsoever (including,  without limitation, damages for loss of use, data or profit) arising out  of the use or inability to use the posting's information even if Author  has been advised of the possibility of such damage.
Posting
As Reza's reference notes, best practice might be based on "normal" volume with some overage allowance.
Reza's reference also describes on-going monitoring.  Which is one of the issues with this "best practice" approach, insuring it's accurately set as your network traffic evolves or changes.
The other issue with this feature, even when "correctly" set, and even when there's "bad" traffic that you want to suppress, this feature suppresses the "good" traffic along with the "bad" traffic.
So, because of the last issue, another approach is to set the threshold such that if there is a storm, devices can successfully deal with the storm load, or they might still be managed and the storm mitigated manually.  For this approach, threshold might be set much, much higher than "normal".  Some equipment might not even be degraded by storm traffic and wouldn't require a threshold to be set at all.
BTW, another approach you might want to look at is Control Plane Policing.
