STP Command help
toufeeq690
Community Member
Dear All,
spanning-tree port fast
switch port mode access
is there any command which can combined these two commands.?
means only single command can do the same.
Toufeeq
nkarpysh
No and afaik no plans to combine both. Even if both are used usually on a port connected to the end station (host, server, etc) they mean different things. First - not to trigger TCN on port flap and enforce the network boundary. Second only means that all packets should be sent untagged on that port and force traffic to the specific VLAN. Thus nothing in common between two and there are situation you would need access configured without portfast.
Nik
HTH,
Niko
