01-28-2015 02:40 AM - edited 03-07-2019 10:25 PM
Hi ,
Here is a brief overview of my infrastructure and want to get your opinion on it and then have some questions as below .
I have 2 backbone L3 switches which all of the other L2 access switches do connect to ( around 8) . Some of the access switches have links to other access switches for redundancy purposes as it is no possible to have many direct redundant links to the backbone due to the cost of installing new fiber lines .
Each access switch in on a different vlan .
backbone is then connected to server farm using etherchannel on L3 mode.
Backbone 1 is connected to serverfarm 1 ( 8 etherchannel L3)
backbone 2 is connected to serverfarm 2 ( 8 etherchannel L3 )
Now I have an out of band managment vlan which is 600 so what I want to do is hav the server farm routers accessible on the L2 vlan for management purposes only .
So I have a link from Backbone 1 to Serverfarm1 ( in addition to the 8 above) in L2 and access mode assigned to vlan 600
Same between backbone 2 and serverfrarm 2 .
So my question is , what are the improvement you would make to the design ?
2. I am trying to enable stp gaurd on Serverfarm and backbone 1 switched on the ports which are layer 2 in access mode but that does disable the port. I can get my head around it . I know it is very simple but yet very confused.
I am having portedge setup on those ports . My view is if they are edgeport and are in access mode, why would they receive stp bpdu ?
Many thanks
01-28-2015 03:11 AM
re question 2 , do i need to set it up as filter?
I have setup portfast on those links between Serverfarm and backbone (L2 single link) but when I am running show spanning-tree interface ..
it shows the status as p2p which it should be p2p edge .
again when I try to overwrite that nothing happens. I would expect it to change it to edge and then stop for 1 minute or so while it is moving the port from port edge to normal port and then start again.
In another work me running portfast command on that specific interface does not seem to do anything
05-29-2015 08:24 AM
any one ?
