stp guard loop
suthomas1
Level 7
Level 7
Hello All,
We were trying to add a vlan on one of the downstream access switches when we found that it wasn't showing the correct root for this vlan.
Logs show the below message:-
NW-TDC-N95-2 %STP-2-LOOPGUARD_BLOCK: Loop guard blocking port port-channel12 on VLAN2115. configuration for po12 is:-
interface port-channel12
  description vPC Link to NW-TDC-N9372
  switchport mode trunk
  spanning-tree guard loop
  mtu 9216
  storm-control broadcast level 10.00
  storm-control multicast level 10.00
  vpc 12
sh vpc 12
vPC status
id   Port   Status Consistency Reason                     Active vlans
12   Po12   up     success     success
Rest of all the vlans on this switch appear fine with correct root..this is the only one giving this problem.
Appreciate all help. thanks in advance.
InayathUlla Sharieff
Which device is STP ROOT for thise vlans ?  the device reporting this error or some other device ?
Do you have vPC feature enabled ? If so, do you have "peer-switch" enabled on vPC peers ?
The device showing this error is the core switch(NW-TDC-N95-2) for this particular physical DC.
there is another DC( which usually has the main stp roots for all vlans in network) which is connected over layer 2 links to this particular DC.
  description vPC Link to NW-TDC-N9372 >>>this interface on NW-TDC-N95-2 links to distribution switch NW-TDC-N9372.
How do we check the "peer-switch" enabled on vpc peers? is there any command i can use.
vpc feature is enabled on these devices.
thank you.
You can use the command:-
Command: show running-config vpc
version 6.2(10)
feature vpc
vpc domain 500
  peer-switch>>>>>> here you can see.
Some info on the same:-
https://supportforums.cisco.com/document/118156/nexus-peer-switch-feature-hybrid-setup
