STP is cisco proprietary protocol or open standard
patelabhishek
Hello all,
Is STP a cisco proprietary or an open source protocol????
I searched it on google but i ain't satisfied with the answers i got.
THANKS!!!!!
STP is just the overall term. IEEE has a couple of open source STP implementations, such as MSTP and RSTP. Cisco has its own, such as PVST, PVST+, and PPVST+. So to answer your question, it all depends on what type of STP you are looking at.
from the link below:
'There are many types of STP variants. Some of them are Cisco proprietary, some of them are standardized by IEEE.
Cisco’s proprietary variants are Per-VLAN Spanning Tree Protocol (PVST), Per-VLAN Spanning Tree Protocol Plus (PVST+) and Rapid PVST+.
IEEE’s standards are Rapid Spanning Tree Protocol (RSTP) and Multiple STP (MSTP).'
https://www.certificationkits.com/spanning-tree-protocol-stp-part-ii/
Protocol Standard Resources Needed Convergence STP Tree Calculation
STPIEEE 802.1DLowSlowAll VLANs
PVST+CiscoHighSlowPer VLAN
RSTPIEEE 802.1wMediumFastAll VLANs
Rapid PVST+CiscoHighFastPer VLAN
MSTP (MST)IEEE 802.1s, CiscoMedium or highFastPer instance
you can see from table above that PVST+  and R-PVST+ it list under standard cisco not IEEE that meaning it cisco proprietary.
