STP is making a mess of my network
chrissolo88
I installed redundant link between my switches and set up port channels and everything was working fine at first then stp started blocking host ports and not effectivley utilizing the port channels like it should
Switch 1 which goes out to the edge router and down to switch 2 and 3
spanning-tree mode rapid-pvst
spanning-tree portfast default
interface Port-channel2
switchport trunk native vlan 100
switchport mode trunk
interface Port-channel3
interface FastEthernet0/1
switchport trunk allowed vlan 2,5,100
duplex full
speed 100
interface FastEthernet0/2
duplex full
speed 100
channel-group 2 mode desirable
interface FastEthernet0/3
duplex full
speed 100
interface FastEthernet0/4
duplex full
speed 100
channel-group 3 mode passive
interface FastEthernet0/5
duplex full
speed 100
interface FastEthernet0/6
switchport access vlan 2
switchport mode access
switchport port-security mac-address sticky
duplex full
speed 100
spanning-tree bpduguard enable
shutdown
interface FastEthernet0/7
duplex full
speed 100
shutdown
interface FastEthernet0/8
duplex full
speed 100
shutdown
interface FastEthernet0/9
duplex full
speed 100
shutdown
interface FastEthernet0/10
duplex full
speed 100
shutdown
interface FastEthernet0/11
switchport access vlan 5
duplex full
speed 100
shutdown
interface FastEthernet0/12
duplex full
speed 100
shutdown
interface FastEthernet0/13
duplex full
speed 100
shutdown
interface FastEthernet0/14
duplex full
speed 100
shutdown
interface FastEthernet0/15
duplex full
speed 100
shutdown
interface FastEthernet0/16
duplex full
speed 100
shutdown
interface FastEthernet0/17
shutdown
interface FastEthernet0/18
shutdown
interface FastEthernet0/19
shutdown
interface FastEthernet0/20
duplex full
speed 100
shutdown
interface FastEthernet0/21
duplex full
speed 100
shutdown
interface FastEthernet0/22
duplex full
speed 100
shutdown
interface FastEthernet0/23
duplex full
speed 100
interface FastEthernet0/24
duplex full
speed 100
shutdown
interface GigabitEthernet0/1
duplex full
speed 100
shutdown
interface GigabitEthernet0/2
duplex full
speed 100
shutdown
interface Vlan1
no ip address
shutdown
interface Vlan100
mac-address 0006.2a7a.e801
ip address 10.24.0.11 255.255.255.0
ip default-gateway 10.24.0.1
Switch 2 which is blocking the host ports f0/11 and 6
interface Port-channel1
duplex full
speed 100
channel-group 1 mode auto
duplex full
speed 100
duplex full
speed 100
shutdown
duplex full
speed 100
shutdown
duplex full
speed 100
shutdown
duplex full
speed 100
duplex full
speed 100
shutdown
duplex full
speed 100
shutdown
duplex full
speed 100
shutdown
duplex full
speed 100
shutdown
duplex full
speed 100
duplex full
speed 100
shutdown
duplex full
speed 100
shutdown
duplex full
speed 100
shutdown
duplex full
speed 100
shutdown
duplex full
speed 100
shutdown
shutdown
shutdown
shutdown
duplex full
speed 100
shutdown
duplex full
speed 100
shutdown
duplex full
speed 100
shutdown
duplex full
speed 100
shutdown
duplex full
speed 100
shutdown
duplex full
speed 100
channel-group 3 mode desirable
duplex full
speed 1000
interface Vlan1
no ip address
shutdown
interface Vlan100
mac-address 0004.9a5b.9a01
ip address 10.24.0.12 255.255.255.0
switch 3 which goes to 1 and 2 then out to a edge router to a remote office all traffic should head to switch 1
duplex full
speed 100
duplex full
speed 100
shutdown
duplex full
speed 100
shutdown
duplex full
speed 100
channel-group 1 mode active
duplex full
speed 100
switchport port-security maximum 2
switchport port-security violation restrict
duplex full
speed 100
duplex full
speed 100
shutdown
duplex full
speed 100
shutdown
duplex full
speed 100
shutdown
duplex full
speed 100
shutdown
duplex full
speed 100
duplex full
speed 100
shutdown
duplex full
speed 100
shutdown
duplex full
speed 100
shutdown
duplex full
speed 100
shutdown
duplex full
speed 100
shutdown
switchport access vlan 100
duplex full
speed 100
spanning-tree link-type point-to-point
shutdown
shutdown
shutdown
duplex full
speed 100
shutdown
duplex full
speed 100
shutdown
duplex full
speed 100
shutdown
duplex full
speed 100
shutdown
duplex full
speed 100
shutdown
duplex full
speed 100
channel-group 2 mode auto
duplex full
speed 1000
interface Vlan1
no ip address
shutdown
interface Vlan100
mac-address 0060.2f92.4201
ip address 10.24.0.13 255.255.255.0
really confused on this one
A couple of things I noticed are the following:
1) There is "speed" mismatch on SW3 Po2 member interfaces (Gig0/1 is 100 and Gig0/2 is 1000). Match the speed.
2) I am not sure how you configure the Port-channels. I prefer them to have similar configuration with the member interfaces interms of allowed VLANs. It is a good practice to allow similar VLANs. If you are going to make the change, you will need to shutdown/ no shutdown the interfaces. Please make sure you have console access as you might lose your connection.
HTH,
Meheretab
HTH,
Meheretab
16 Replies 16
Hello
make switch 1 your stp root
Sw1
conf t
spanning-tree vlan 1-4094 priority 0
Kind Regards
Paul
i had it that way originally but stp blocks the port out to the branch office, just incase it worked i just switched it back a and sure enough f0/1 on switch 3 is being blocked
Hi @chrissolo88 ,
Could you share some diagram of your network indicating the ports between switches?
Reindicate the problem you have and what you want to achieve
the problem is STP is blocking host ports/ ports to my routers, routing updates are not being passed through from R1 to R2 because STP is blocking ports. this problem only started after i initiated port-channels. and im not sure how to resolve this
Please share the output of "show interface trunk" and "show etherchannel summary" on all switches.
HTH,
Meheretab
S1#sh int trunk
Port Mode Encapsulation Status Native vlan
Po2 on 802.1q trunking 100
Po3 on 802.1q trunking 100
Fa0/1 on 802.1q trunking 100
Port Vlans allowed on trunk
Po2 1-1005
Po3 1-1005
Fa0/1 2,5,100
Port Vlans allowed and active in management domain
Po2 1,2,5,100
Po3 1,2,5,100
Fa0/1 2,5,100
Port Vlans in spanning tree forwarding state and not pruned
Po2 1,2,5,100
Po3 1,2,5,100
Fa0/1 2,5,100
S1#sh ethe sum
Flags: D - down P - in port-channel
I - stand-alone s - suspended
H - Hot-standby (LACP only)
R - Layer3 S - Layer2
U - in use f - failed to allocate aggregator
u - unsuitable for bundling
w - waiting to be aggregated
d - default port
Number of channel-groups in use: 2
Number of aggregators: 2
Group Port-channel Protocol Ports
2 Po2(SU) PAgP Fa0/2(P) Fa0/3(P)
3 Po3(SU) LACP Fa0/4(P) Fa0/5(P)
S2#sh int trunk
Po1 on 802.1q trunking 100
Po1 1-1005
Po3 1-1005
Po1 1,2,5,100
Po3 1,2,5,100
Po1 1,2,5,100
Po3 2,5,100
S2#sh ethe sum
d - default port
1 Po1(SU) PAgP Fa0/1(P) Fa0/2(P)
3 Po3(SU) PAgP Gig0/1(P) Gig0/2(P)
S2#
S3#sh int tr
Po1 1-1005
Po2 1-1005
Fa0/1 2,5,100
Po1 1,2,5,100
Po2 1,2,5,100
Fa0/1 2,5,100
Po1 1,2,5
Po2 1
Fa0/1 2,5,100
S3#sh eth sum
d - default port
1 Po1(SU) LACP Fa0/4(P) Fa0/5(P)
2 Po2(SU) PAgP Gig0/1(P) Gig0/2(P)
S3#
HTH,
Meheretab
HTH,
Meheretab
i didnt notice the speed mismatch, i have 2,5,and 100 allowed on each trunk interface im not seeing a mismatch in that
wow a speed mismatch caused all that thanks for the input its always the smallest things
Hi @chrissolo88 ,
If it is an exercise in PacketTracer, can you compress the exercise (with Winzip, for example) and attach it to review the configurations?
it isnt a packet tracer exercise, i do have my main part of my network configured on packet tracer so i can see what changes will do to my system before implementing it on production equipment ill zip and post
Hello
now seeing your topology yo need  also to make sw3 more  stp preferable then sw2
Sw1
conf t
Sw3
conf t
spanning-tree vlan 1-4094 priority 4096
Kind Regards
Paul
