STP listening and learning timers
carl_townshend
Hi all, in theory in normal STP , should the port take 30 seconds to come on? 15 listening and 15 learning by default,
which is the port that would take 50 secs to come on, would this be the if the root port failed, it would have to wait the max age, then go through listening and learning, which would be 50 secs.
is this correct
Giuseppe Larosa
Hello Carl,
your understanding is correct
Hope to help
Giuseppe
