STP Loop
bava_ccna
05:39:42: %C4K_EBM-4-HOSTFLAPPING: Host 02:01:00:00:00:00 in vlan 1 is flapping between port Gi2/7 and port Gi2/14,where Gi2/7 and Gi2/14 were connected to two servers.both are in Vlan1.We are using PVST in our LAN.why this problem occurs?
Any help can be appreciated
Bava
bvsnarayana03
Level 5
Level 5
Yes its a STP loop. You need to identify the culprit causing the loop.
Check with the command "sh spanning-tree root"
to see if the root for vlan 1 has changed.
I found that the root for vlan 1 is not changed and there is no loop also.still the problem exists
It's likely to be a duplicate mac address in your network. The mac address you mentioned seems to be locally administered. So it's probably been generated by an application or a device. Try to find out where the entries are leading to in order to find the culprit(s).
Francois
