STP port cost and Etherchannel
I have seen references that two bundled FastEthernet ports into an Etherchannel results in an STP cost of 12.
How is STP cost of 12 derived when the port cost of a single FastEthernet port is 19? --> FastEthernet is 100 Mbps.
I want to grasp and understand this so that I can determine STP cost of an an Etherchannel bundle that has 3,4.5,6,7,8 bundled FastEthernet ports.
Thank you.
Peter Paluch
Cisco has never published the formula it uses to recalculate the total EtherChannel bundle bandwidth into the STP cost. It appears to be an exponential function in the format
SpeedA * B = Cost
where A and B are unknown constants.
Nonetheless, to be at least partially helpful, I have tested out all typical bandwidths and I am enclosing a table of the resulting STP costs for your convenience.
Speed Resulting Cost
10M 100
20M 56
30M 47
40M 41
50M 35
60M 30
70M 26
80M 23
100M 19
200M 12
300M 9
400M 8
500M 7
600M 6
700M 5
800M 5
1G 4
2G 3
3G 3
4G 3
5G 3
6G 3
7G 3
8G 3
Hope it helps.
Best regards,
Peter
Peter Paluch
SpeedA * B = Cost
10M 100
20M 56
30M 47
40M 41
50M 35
60M 30
70M 26
80M 23
100M 19
200M 12
300M 9
400M 8
500M 7
600M 6
700M 5
800M 5
1G 4
2G 3
3G 3
4G 3
5G 3
6G 3
7G 3
8G 3
Hope it helps.
Best regards,
Peter
Thank you very much Peter :-)   I had seen one of your earlier posts that was dated a few years ago.
