STP prioritize port priority over System-Mac-Address in my project.
eitanbenari4
Root bridge is IOU1
i executed this script on the kali machine. after it the egress port to the root transitioned to the alternative state, despite the lower mac address of the Root-bridge. CHAT said its becuase of a lower port priority, but from what i know, port priority only comes after mac address.
18 Replies 18
Well I did a little check. In stp only the root send config bpdu and changes the fields of bridge/root mac. But in rstp every sw sends config bpdu, which explains why the Mac address needs to be identical to the bridge id(the sw the made the bpdu)
Again your topolgy since there is no loop in connection (triangle or rectangle) there is no BLK.
For MAC let me summary mac
Bpdu source :- mac address of SW
Bpdu destiantion:- multicast of STP (this mac is different between stp modes)
Bridge -id :- is the mac of SW from where this bpdu come from
Root -id:- this mac address of root SW
MHM
In a case of indirectional link failure, the switch can block a port even if there are no loops. Check out backbonefast
Friend check out what ?
backbone fast is feature of STP which use to stop loop
your topology is chain of SW there is no loop
anyway
let other help you I am little busy sorry
goodluck
MHM
