STP problem between ASA and switch
boban-petrovic
I have following situation: Host connected to switch port 0/1 and address 192.168.139.38 255.255.255.252, and connection between switch port 0/2 and asa port 0/1. Relevant configuration is:
Switch config:
spanning-tree mode pvst
no spanning-tree optimize bpdu transmission
no spanning-tree vlan 131
interface FastEthernet0/1
switchport access vlan 131
switchport mode access
interface FastEthernet0/2
ASA config:
interface Ethernet0/1
nameif line
security-level 100
ip address 192.168.139.37 255.255.255.252
In this scenario, host successfully ping ASA. But, as you can see, stp is disabled for vlan 131. If I enable it, my log shows:
Feb 14 09:05:59: %SPANTREE-7-RECV_1Q_NON_TRUNK: Received 802.1Q BPDU on non trunk FastEthernet0/2 VLAN131.
Feb 14 09:05:59: %SPANTREE-7-BLOCK_PORT_TYPE: Blocking FastEthernet0/2 on VLAN0131. Inconsistent port type.
switch# sh spa vlan 131 | inc Fa0/2
Fa0/2            Desg BKN*19        128.2    P2p *TYPE_Inc
If switch port is in access mode, then BPDU from ASA is got to be VLAN tagged, so I changed switch config to:
switchport trunk native vlan 131
switchport mode trunk
Feb 14 09:12:56: %SPANTREE-2-RECV_PVID_ERR: Received BPDU with inconsistent peer vlan id 1115 on FastEthernet0/2 VLAN131.
Feb 14 09:12:56: %SPANTREE-2-BLOCK_PVID_LOCAL: Blocking FastEthernet0/2 on VLAN0131. Inconsistent local vlan.
If I remove 'switchport trunk native vlan 131', I'm getting similiar error:
Feb 14 09:12:26: %SPANTREE-2-RECV_PVID_ERR: Received BPDU with inconsistent peer vlan id 1115 on FastEthernet0/2 VLAN1.
Feb 14 09:12:26: %SPANTREE-2-BLOCK_PVID_LOCAL: Blocking FastEthernet0/2 on VLAN0001. Inconsistent local vlan.
In both cases:
Fa0/2            Desg BKN*19        128.2    P2p *PVID_Inc
So, this time port type was correct but VLAN ID was not.
I've tried to change config on ASA:
nameif line2
security-level 100
no ip address
interface Ethernet0/1.1
vlan 131
nameif line
security-level 100
And setting on switch:
switchport trunk allow vlan 131
And this time was good:
Fa0/2            Desg FWD 19        128.2    P2p
But, in this case, my host can't ping ASA!
How to solve this?
6 Replies 6
cadet alain
on the switch is vlan 131 the native vlan ?
if so can you use a physical interface on the asa to configure it as only dot1q tagged vlan  is configured  on subinterfaces.
Regards.
Alain
No, vlan 131 is not native on the switch. It's regular vlan, native vlan is VLAN1.
why did you disable STP for this VLAN on the switch ?
Regards.
Alain
At this moment I don't need STP because there are no loops in my network. If I enable STP on that VLAN, port 0/2 is going to blocking state, so I decided to disable stp, for that particular vlan. Now, I have a request for links and devices redundacy, so there will be loops in the network, and therefore I have to enable STP for all VLANs. That implicates that I have to solve this issue.
ok so now the STP port is forwarding and still not possible to ping ASA from the host in that VLAN, ok ?
can you post the running from ASA.
Regards.
Alain
ASA Version 7.2(3)
hostname asa
domain-name default.domain.invalid
names
dns-guard
interface Ethernet0/0
no ip address
nameif line2
security-level 100
ni ip address
nameif line
security-level 100
interface Ethernet0/2
no ip address
interface Ethernet0/3
no ip address
interface Management0/0
nameif management
security-level 100
management-only
boot system disk0:/asa723-k8.bin
ftp mode passive
clock timezone CET 1
same-security-traffic permit inter-interface
same-security-traffic permit intra-interface
access-list line_access_in extended permit ip 192.168.0.0 255.255.0.0 192.168.0.0 255.255.0.0
access-list line_access_in extended permit icmp any any
access-list nonat extended permit ip 192.168.0.0 255.255.0.0 192.168.0.0 255.255.0.0
access-list capture-line extended permit ip any any
pager lines 24
logging enable
logging timestamp
logging buffer-size 16384
logging console debugging
logging buffered debugging
logging trap informational
logging asdm informational
mtu line 1500
mtu management 1500
no failover
icmp unreachable rate-limit 1 burst-size 1
asdm image disk0:/asdm-523.bin
no asdm history enable
arp timeout 14400
access-group line_access_in in interface line
timeout xlate 3:00:00
timeout conn 1:00:00 half-closed 0:10:00 udp 0:02:00 icmp 0:00:02
timeout sunrpc 0:10:00 h323 0:05:00 h225 1:00:00 mgcp 0:05:00 mgcp-pat 0:05:00
timeout sip 0:30:00 sip_media 0:02:00 sip-invite 0:03:00 sip-disconnect 0:02:00
timeout uauth 0:05:00 absolute
no snmp-server location
no snmp-server contact
snmp-server enable traps snmp authentication linkup linkdown coldstart
class-map inspection_default
match default-inspection-traffic
policy-map global_policy
class inspection_default
  inspect ftp
  inspect h323 h225
  inspect h323 ras
  inspect rsh
  inspect rtsp
  inspect sqlnet
  inspect skinny
  inspect sunrpc
  inspect xdmcp
  inspect sip
  inspect netbios
  inspect tftp
  inspect pptp
service-policy global_policy global
