11-04-2020 04:36 AM
Hi ,
Am preparing for a interview, i would like to know Realtime STP issues in network and most common question from STP, it will be a great help.
Vasanth R
11-04-2020 07:17 AM
Its depends on how interviewer ask question there are many scenario based questions. - But you need to understand how sTP works. that give ability to answer the right answer.
if you looking questions here are many :
https://www.wisdomjobs.com/e-university/spanning-tree-protocol-stp-interview-questions.html
If you looking to learn STP
11-04-2020 10:30 AM
11-04-2020 02:20 PM
Hello
Any question could be asked
possible stp modes and timers - the differences
multiple stp transmissions- possible root cause edge ports not running portfast - link flaps
loop guard - root guard - udld - backbone-fast
bridge assurance
err-disabled ports - bpduguard- bpdu being seen on a portfast port
pvid inconsistent - vlan mismatch -
pvid simulation - when joining pvid domain to mst domain
etc...
11-04-2020 08:15 PM
Hi Paul,
Thanks for the response.
Vasanth R
