11-14-2006 01:07 AM - edited 03-05-2019 12:47 PM
The below is outout from one of my acess switch,does this tel " STP is disabled" on this switch. if not why it is not participating in STP.
Access Switch Cat6500> (enable) sh spantree
VLAN 1
Spanning tree mode RAPID-PVST+
Spanning tree type ieee
Spanning tree enabled
Designated Root 00-00-00-00-00-00
Designated Root Priority 0
Designated Root Cost 0
Designated Root Port 1/0
Root Max Age 0 sec Hello Time 0 sec Forward Delay 0 sec
Bridge ID MAC ADDR 00-00-00-00-00-00
Bridge ID Priority 32768
Bridge Max Age 20 sec Hello Time 2 sec Forward Delay 15 sec
Port State Role Cost Prio Type
helpful info,
1.Cisco Three Layer Archtecture
2.Sh port shows connections to each DE switch is in forwarding stage
3.Other switches are fine with STP
RP
11-14-2006 01:21 AM
Hi ,
Check the below link.
http://www.cisco.com/univercd/cc/td/doc/product/lan/cat5000/rel_6_3/cmd_ref/sh_sp_te.htm#12352
Troubleshotting spanning tree.
http://www.cisco.com/en/US/customer/tech/tk389/tk621/technologies_tech_note09186a00800951ac.shtml
satish
11-14-2006 01:25 AM
It looks as if the switch is not processing this vlan.
Did you alter the native vlan on this switch or perhaps on the entire network?
Did you verify that vlan1 is enabled on the network?
Leo
11-14-2006 02:07 AM
You are right, Thanks!
We have one VLAN/Switch so as you said VLAN 1 is no more active and I should have given "sh spantree 132"(my vlan number) instead sh spantree.
11-14-2006 01:28 AM
Hello Arun,
your 6500 is running rapid-PVST+, what about your other switches ? Can you post the output of one of the switches that do have a valid output when you issue the 'show spantree' or 'show spanning-tree vlan 1' command ?
GNT
