Strange multicast problem when using Alteris Deployment Server
cbeswick
Level 5
Level 5
We use the PXE boot funtion on our desktop PCs and laptops. Multicast TFTP is enabled within the BIOS to grab a boot file and only recently we have been witnessing an "Open TFTP Timeout" during the bootup process.
I have checked over the IGMP / IP PIM configuration across our network and everything looks fine. However when I check the IGMP group that the client is trying to join I see address 224.1.1.2. Yet when I look at the IGMP group on the port to which the Altiris Deployment server connects I only see group 225.1.2.3.
A colleague has shown me the configuration for the MTFTP server on the deployment server and the group address is set at 224.1.1.0.
Shouldn't the group address on the Altiris deployment server also be 224.1.1.2 or is the 225.1.2.3 address within the 224.1.1.0 IGMP group and the problem is in fact something to do with the network ?
Chris
48 Replies 48
Giuseppe Larosa
Hello Chris,
it looks like the client is trying to get traffic from a different group, but when you check IGMP membership you can check receiver interest.
So server is interested in receiving traffic on 224.1.1.2
can 225.1.2.3 fit with 224.1.1.0?
it is unlikely as you can see first byte 225 is different then 224.1.1.0
check with
sh ip mroute 225.1.2.3
if there is any source sending packets to this group
(I mean (S,225.1.2.3) entries the (*, 225.1.2.3) should be present in any case)
sh ip pim rp mapping 225.1.2.3
there is an RP for this address?
if there is not you have a problem
Hope to help
Giuseppe
Hi Giuseppe and thanks for your reply.
When I look on the first hop distribution switch (the switch block that contains the server) I see the following:
(*, 225.1.2.3), 4d17h/00:02:55, RP 172.16.255.4, flags: SJC
Incoming interface: Vlan227, RPF nbr 172.16.227.250, Partial-SC
Outgoing interface list:
Vlan192, Forward/Sparse-Dense, 4d17h/00:02:55, H
The RP mapping shows the following:
ci_t2_c200_sfdist_sw1#sh ip pim rp mapping 225.1.2.3
PIM Group-to-RP Mappings
Group(s) 224.0.0.0/4
RP 172.16.255.4 (?), v2v1
Info source: 172.16.255.7 (?), elected via Auto-RP
Uptime: 4d17h, expires: 00:02:50
When I check the RP itself at 172.16.255.4, I see the following:
(*, 225.1.2.3), 4w0d/00:02:57, RP 172.16.255.4, flags: S
Incoming interface: Null, RPF nbr 0.0.0.0
Vlan227, Forward/Sparse-Dense, 4d17h/00:02:57
Everything looks fine for the group.
I have just looked at the IGMP group the client is trying to join and this has now changed to 224.1.1.3 all by itself. I have checked over the core switch and can see the following:
ci_t2_65_c200_core2#sh ip mroute 224.1.1.3
IP Multicast Routing Table
Flags: D - Dense, S - Sparse, B - Bidir Group, s - SSM Group, C - Connected,
L - Local, P - Pruned, R - RP-bit set, F - Register flag,
T - SPT-bit set, J - Join SPT, M - MSDP created entry,
X - Proxy Join Timer Running, A - Candidate for MSDP Advertisement,
U - URD, I - Received Source Specific Host Report,
Z - Multicast Tunnel, z - MDT-data group sender,
Y - Joined MDT-data group, y - Sending to MDT-data group
V - RD & Vector, v - Vector
Outgoing interface flags: H - Hardware switched, A - Assert winner
Timers: Uptime/Expires
Interface state: Interface, Next-Hop or VCD, State/Mode
(*, 224.1.1.3), 00:23:23/00:03:24, RP 172.16.255.4, flags: S
Vlan232, Forward/Sparse-Dense, 00:00:05/00:03:24
Vlan224, Forward/Sparse-Dense, 00:09:32/00:02:49
(172.16.192.49, 224.1.1.3), 00:23:23/00:02:16, flags:
Incoming interface: Vlan228, RPF nbr 172.16.228.251
Device 172.16.192.49 is the server address....So the server is a member of the 224.1.1.3 group, yet when I check on the switch port it is 225.1.2.3.
I just do not understand this.
Hello Chris,
note:
a source S for group G does not need to be a member of group G, it is simply a source of packets sent with destination G
then the server can be a multicast receiver on its own, and it can have joined a totally different multicast group G2 not related to the first.
This is what happens here
the following output shows the source is active:
Can the host receive on 224.1.1.3?
Hope to help
Giuseppe
Do you mean the server 172.16.192.49 ? How would I check this on the network ? If it is a source of the multicast group (S,G), would it not be able to automatically recieve on the same group ?
I think I may have found a problem.
When I trace the S,G multicast tree across the backbone I see the following:
1) On the Server distribution switch (switch block containing the server 172.16.192.49)
ci_t1_c050_sfdist_sw1#sh ip mroute 224.1.1.3
(*, 224.1.1.3), 16:53:00/stopped, RP 172.16.255.4, flags: SP
  Incoming interface: Vlan228, RPF nbr 172.16.228.250, RPF-MFD
  Outgoing interface list: Null
(172.16.192.49, 224.1.1.3), 16:53:00/00:03:21, flags: T
  Incoming interface: Vlan192, RPF nbr 0.0.0.0, RPF-MFD
    Vlan228, Forward/Sparse-Dense, 16:08:12/00:02:49, H
2) On the Core switch (also the RP for the group)
(*, 224.1.1.3), 16:54:57/00:03:18, RP 172.16.255.4, flags: S
    Vlan232, Forward/Sparse-Dense, 00:00:37/00:02:52
    Vlan222, Forward/Sparse-Dense, 00:05:46/00:00:38
    Vlan224, Forward/Sparse-Dense, 16:08:53/00:03:18
(172.16.192.49, 224.1.1.3), 16:54:57/00:01:53, flags:
3) On the distribution switch containing the clients using PXE Boot and the Multicast TFTP:
ci_t1_3a1_dist_sw1#sh ip mroute 224.1.1.3
(*, 224.1.1.3), 16:42:50/00:02:38, RP 172.16.255.4, flags: SJC
  Incoming interface: Vlan224, RPF nbr 172.16.224.250, Partial-SC
    Vlan5, Forward/Sparse-Dense, 00:00:34/00:02:38, H
    Vlan67, Forward/Sparse-Dense, 00:01:10/00:01:49, H
    Vlan8, Forward/Sparse-Dense, 00:02:33/00:00:41, H
    Vlan6, Forward/Sparse-Dense, 00:07:53/00:02:22, H
    Vlan68, Forward/Sparse-Dense, 16:10:37/00:02:28, H
On the above switch you can see the end hosts joining the group 224.1.1.3 but there is no S,G entry for the server.
We had an issue a few weeks ago where a rogue DHCP device dished out an ip address used by one of our HSRP groups and caused a few issues, this seems to coincide with when the multicasting stopped for this particular service. Could this have caused an issue with the multicast stream ?
Do you think a clearing of the mroute cache on the backbone switches might resolve the issue ?
Hello Chris,
cumulative answer to your two posts
no, as noted in my previous post a source is not a member of the group, it can be but being a source is not enough to be a member of group G
I meant on the intended receiver, that is what counts
Yes, there can be issues in interaction of HSRP and multicast.
I agree that there can be a relationship between the two events
Edit:
this partial-SC flag is the sign of a problem
you could use debug ip pim to see error messages
can you check on last switch
with
sh ip rpf
sh ip rpf 172.16.192.49
what should be the RPF neighbor for RP and for source?
Hope to help
Giuseppe
Hi ,
Output of show commands on the last distribution switch before hitting the receiver:
ci_t1_3a1_dist_sw1#sh ip rpf 172.16.255.4
  RPF information for ? (172.16.255.4)
  RPF interface: Vlan224
  RPF neighbor: ? (172.16.224.250)
  RPF route/mask: 172.16.255.4/32
  RPF type: unicast (ospf 1)
  RPF recursion count: 0
  Doing distance-preferred lookups across tables
ci_t1_3a1_dist_sw1#sh ip rpf 172.16.192.49
  RPF information for ? (172.16.192.49)
  RPF route/mask: 172.16.192.0/24
I haven't used this command before. The RP is 172.16.255.4 for the group yet the RPF neighbour is an interface on the RP itself. We have dual distribution switches / cores throughout the network so RPF should be blocking the stream from replicating across multiple paths, should I therefore expect the RFP neighbour to be the redundant / diverse path ?. Does the above indicate that Reverse Path Forward mechanism is actually blocking the path to the RP ? If so this would explain why the receivers aren't seeing the stream.
Hello Chris,
RPF checks look like fine
let's go on with
sh ip pim neighbor
on last switch
and
sh ip pim int
edit:
another thought
there is a companion switch in client vlan that could be the PIM DR on user segments
non PIM DR switch should have only the (*,G) entry
you could try to change HSRP active router on user lan segment to see if there is any effect
Hope to help
Giuseppe
As requested (many thanks for your help!)
ci_t1_3a1_dist_sw1#sh ip pim neighbor
PIM Neighbor Table
Mode: B - Bidir Capable, DR - Designated Router, N - Default DR Priority,
      P - Proxy Capable, S - State Refresh Capable
Neighbor          Interface                Uptime/Expires    Ver   DR
Address                                                            Prio/Mode
172.16.2.252      Vlan2                    6w6d/00:01:19     v2    1 / S P
172.16.3.252      Vlan3                    6w6d/00:01:34     v2    1 / S P
172.16.4.252      Vlan4                    6w6d/00:01:28     v2    1 / S P
172.16.5.252      Vlan5                    6w6d/00:01:28     v2    1 / S P
172.16.6.252      Vlan6                    6w6d/00:01:41     v2    1 / S P
172.16.7.252      Vlan7                    6w6d/00:01:15     v2    1 / S P
172.16.8.252      Vlan8                    6w6d/00:01:39     v2    1 / S P
172.16.10.252     Vlan10                   6w6d/00:01:17     v2    1 / S P
172.16.18.252     Vlan18                   6w6d/00:01:31     v2    1 / S P
172.16.20.252     Vlan20                   6w6d/00:01:27     v2    1 / S P
172.16.25.252     Vlan25                   6w6d/00:01:33     v2    1 / S P
172.16.27.252     Vlan27                   6w6d/00:01:30     v2    1 / S P
172.16.64.252     Vlan64                   6w6d/00:01:38     v2    1 / S P
172.16.65.252     Vlan65                   6w6d/00:01:31     v2    1 / S P
172.16.66.252     Vlan66                   6w6d/00:01:40     v2    1 / S P
172.16.67.252     Vlan67                   6w6d/00:01:20     v2    1 / S P
172.16.68.252     Vlan68                   6w6d/00:01:18     v2    1 / S P
172.16.69.252     Vlan69                   6w6d/00:01:16     v2    1 / S P
172.16.70.252     Vlan70                   6w6d/00:01:39     v2    1 / S P
172.16.71.252     Vlan71                   6w6d/00:01:43     v2    1 / S P
172.16.72.252     Vlan72                   6w6d/00:01:34     v2    1 / S P
172.16.73.252     Vlan73                   6w6d/00:01:32     v2    1 / S P
172.16.74.252     Vlan74                   6w6d/00:01:20     v2    1 / S P
172.16.76.252     Vlan76                   6w6d/00:01:39     v2    1 / S P
172.16.82.252     Vlan82                   6w6d/00:01:33     v2    1 / S P
172.16.83.252     Vlan83                   6w6d/00:01:30     v2    1 / S P
172.16.84.252     Vlan84                   6w6d/00:01:18     v2    1 / S P
172.16.85.252     Vlan85                   6w6d/00:01:22     v2    1 / S P
172.16.88.252     Vlan88                   6w6d/00:01:37     v2    1 / S P
172.16.89.252     Vlan89                   6w6d/00:01:23     v2    1 / S P
172.16.90.252     Vlan90                   6w6d/00:01:17     v2    1 / S P
172.16.91.252     Vlan91                   6w6d/00:01:43     v2    1 / S P
172.16.92.252     Vlan92                   6w6d/00:01:17     v2    1 / S P
172.16.93.252     Vlan93                   6w6d/00:01:21     v2    1 / S P
172.16.94.252     Vlan94                   6w6d/00:01:18     v2    1 / S P
172.16.95.252     Vlan95                   6w6d/00:01:24     v2    1 / S P
172.16.96.252     Vlan96                   6w6d/00:01:21     v2    1 / S P
172.16.97.252     Vlan97                   6w6d/00:01:19     v2    1 / S P
172.16.98.252     Vlan98                   6w6d/00:01:16     v2    1 / S P
172.16.99.252     Vlan99                   6w6d/00:01:43     v2    1 / S P
172.16.102.252    Vlan102                  6w6d/00:01:37     v2    1 / S P
172.16.104.252    Vlan104                  6w6d/00:01:16     v2    1 / S P
172.16.105.252    Vlan105                  6w6d/00:01:26     v2    1 / S P
172.16.106.252    Vlan106                  3w2d/00:01:42     v2    1 / S P
172.16.223.250    Vlan223                  4w0d/00:01:37     v2    1 / S P
172.16.224.250    Vlan224                  4w1d/00:01:41     v2    1 / S P
Vlans 223 and 224 (3rd octet) are the SVIs that form OSPF adjancies with the two Cores.
Hello Chris,
I think you should use the debug ip pim
to see what happens on the distribution switch
have a PC joining the group and see what happens
Hope to help
Giuseppe
I let an existing entry in the mroute cache time out before turning on a test machine, output below.
ci_t1_3a1_dist_sw1#debug ip pim 224.1.1.3
PIM debugging is on
004216: May 12 13:36:52: PIM(0): Received RP-Reachable on Vlan224 from 172.16.255.4
004217: May 12 13:36:52: PIM(0): Received RP-Reachable on Vlan224 from 172.16.255.4
004218: May 12 13:36:52:      for group 224.1.1.3
004219: May 12 13:36:52: PIM(0): Update RP expiration timer (270 sec) for 224.1.1.3
004220: May 12 13:36:52: PIM(0): Forward RP-reachability for 224.1.1.3 on Vlan68
004221: May 12 13:37:15: PIM(0): Building Periodic (*,G) Join / (S,G,RP-bit) Prune message for 224.1.1.3
004222: May 12 13:37:15: PIM(0): Insert (*,224.1.1.3) join in nbr 172.16.224.250's queue
004223: May 12 13:37:15: PIM(0): Building Join/Prune packet for nbr 172.16.224.250
004224: May 12 13:37:15: PIM(0):  Adding v2 (172.16.255.4/32, 224.1.1.3), WC-bit, RPT-bit, S-bit Join
004225: May 12 13:37:15: PIM(0): Send v2 join/prune to 172.16.224.250 (Vlan224)
004226: May 12 13:38:14: PIM(0): Building Periodic (*,G) Join / (S,G,RP-bit) Prune message for 224.1.1.3
004227: May 12 13:38:14: PIM(0): Insert (*,224.1.1.3) join in nbr 172.16.224.250's queue
004228: May 12 13:38:14: PIM(0): Building Join/Prune packet for nbr 172.16.224.250
004229: May 12 13:38:14: PIM(0):  Adding v2 (172.16.255.4/32, 224.1.1.3), WC-bit, RPT-bit, S-bit Join
004230: May 12 13:38:14: PIM(0): Send v2 join/prune to 172.16.224.250 (Vlan224)
004231: May 12 13:38:22: PIM(0): Received RP-Reachable on Vlan224 from 172.16.255.4
004232: May 12 13:38:22: PIM(0): Received RP-Reachable on Vlan224 from 172.16.255.4
004233: May 12 13:38:22:      for group 224.1.1.3
004234: May 12 13:38:22: PIM(0): Update RP expiration timer (270 sec) for 224.1.1.3
004235: May 12 13:38:22: PIM(0): Forward RP-reachability for 224.1.1.3 on Vlan68
004236: May 12 13:38:23: PIM(0): Insert (172.16.255.4,224.1.1.3) prune in nbr 172.16.224.250's queue
004237: May 12 13:38:23: PIM(0): Building Join/Prune packet for nbr 172.16.224.250
004238: May 12 13:38:23: PIM(0):  Adding v2 (172.16.255.4/32, 224.1.1.3), WC-bit, RPT-bit, S-bit Prune
004239: May 12 13:38:23: PIM(0): Send v2 join/prune to 172.16.224.250 (Vlan224)
(*, 224.1.1.3), 00:09:06/00:02:55, RP 172.16.255.4, flags: SP
  Incoming interface: Vlan224, RPF nbr 172.16.224.250, RPF-MFD
004240: May 12 13:38:55: PIM(0): Building Triggered (*,G) Join / (S,G,RP-bit) Prune message for 224.1.1.3
004241: May 12 13:38:55: PIM(0): Insert (*,224.1.1.3) join in nbr 172.16.224.250's queue
004242: May 12 13:38:55: PIM(0): Building Join/Prune packet for nbr 172.16.224.250
004243: May 12 13:38:55: PIM(0):  Adding v2 (172.16.255.4/32, 224.1.1.3), WC-bit, RPT-bit, S-bit Join
004244: May 12 13:38:55: PIM(0): Send v2 join/prune to 172.16.224.250 (Vlan224)
004245: May 12 13:39:14: PIM(0): Building Periodic (*,G) Join / (S,G,RP-bit) Prune message for 224.1.1.3
004246: May 12 13:39:14: PIM(0): Insert (*,224.1.1.3) join in nbr 172.16.224.250's queue
004247: May 12 13:39:14: PIM(0): Building Join/Prune packet for nbr 172.16.224.250
004248: May 12 13:39:14: PIM(0):  Adding v2 (172.16.255.4/32, 224.1.1.3), WC-bit, RPT-bit, S-bit Join
004249: May 12 13:39:14: PIM(0): Send v2 join/prune to 172.16.224.250 (Vlan224)
(*, 224.1.1.3), 00:17:49/00:00:25, RP 172.16.255.4, flags: SJC
    Vlan68, Forward/Sparse-Dense, 00:08:16/00:00:25, H
Hello Chris,
if you can repeat the same test on core switch to see the same debug output on it
we see that the switch attempts to prune from shared tree and to join source based tree but something goes wrong and it does not reach forward state for source based tree
Hope to help
Giuseppe
Hi Guiseppe,
The next debug, showing pim on the distribution switch where the receiver / client is, and the Core / RP switch:
Distribution Switch where the receiver is
004250: May 13 09:48:49: PIM(0): Building Periodic (*,G) Join / (S,G,RP-bit) Prune message for 224.1.1.3
004251: May 13 09:48:49: PIM(0): Insert (*,224.1.1.3) join in nbr 172.16.224.250's queue
004252: May 13 09:48:49: PIM(0): Building Join/Prune packet for nbr 172.16.224.250
004253: May 13 09:48:49: PIM(0):  Adding v2 (172.16.255.4/32, 224.1.1.3), WC-bit, RPT-bit, S-bit Join
004254: May 13 09:48:49: PIM(0): Send v2 join/prune to 172.16.224.250 (Vlan224)
RP and Core switch
000654: .May 13 09:48:49: PIM(0): Received v2 Join/Prune on Vlan222 from 172.16.222.251, to us
000655: .May 13 09:48:49: PIM(0): Join-list: (*, 224.1.1.3), RPT-bit set, WC-bit set, S-bit set
000656: .May 13 09:48:49: PIM(0): Update Vlan222/172.16.222.251 to (*, 224.1.1.3), Forward state, by PIM *G Join
000657: .May 13 09:48:49: PIM(0): Update Vlan222/172.16.222.251 to (172.16.192.49, 224.1.1.3), Forward state, by PIM *G Join
000658: .May 13 09:48:49: PIM(0): Received v2 Join/Prune on Vlan224 from 172.16.224.251, to us
000659: .May 13 09:48:49: PIM(0): Join-list: (*, 224.1.1.3), RPT-bit set, WC-bit set, S-bit set
000660: .May 13 09:48:49: PIM(0): Update Vlan224/172.16.224.251 to (*, 224.1.1.3), Forward state, by PIM *G Join
000661: .May 13 09:48:49: PIM(0): Update Vlan224/172.16.224.251 to (172.16.192.49, 224.1.1.3), Forward state, by PIM *G Join
000662: .May 13 09:48:50: PIM(0): Building Periodic (*,G) Join / (S,G,RP-bit) Prune message for 224.1.1.3
000663: .May 13 09:48:50: PIM(0): Insert (172.16.192.49,224.1.1.3) join in nbr 172.16.228.251's queue
000664: .May 13 09:48:50: PIM(0): Building Join/Prune packet for nbr 172.16.228.251
000665: .May 13 09:48:50: PIM(0):  Adding v2 (172.16.192.49/32, 224.1.1.3), S-bit Join
000666: .May 13 09:48:50: PIM(0): Send v2 join/prune to 172.16.228.251 (Vlan228)
000667: .May 13 09:48:53: PIM(0): Received v2 Register on Vlan227 from 172.16.227.251
000668: .May 13 09:48:53:      (Data-header) for 172.16.192.49, group 224.1.1.3
000669: .May 13 09:48:53: PIM(0): Send v2 Register-Stop to 172.16.227.251 for 172.16.192.49, group 224.1.1.3
000670: .May 13 09:48:53: PIM(0): Insert (172.16.192.49,224.1.1.3) join in nbr 172.16.228.251's queue
000671: .May 13 09:48:53: PIM(0): Building Join/Prune packet for nbr 172.16.228.251
000672: .May 13 09:48:53: PIM(0):  Adding v2 (172.16.192.49/32, 224.1.1.3), S-bit Join
000673: .May 13 09:48:53: PIM(0): Send v2 join/prune to 172.16.228.251 (Vlan228)
Hello Chris,
sorry for late answer
RP device is behaving correctly
just to know: in vlan 68 where are the users there is only the last switch or there are two switches providing L3 services to users in this vlan?
Hope to help
Giuseppe
