Strange NAT behavior
tom.meyer
I have an 2901 router  and I am getting the strangest ping results from a NATed IP address on my DMZ.  I am about at my wits end and would appreciate any help.
From 192.168.1.X:
C:\>ping 192.168.12.140
Pinging 192.168.12.140 with 32 bytes of data:
Reply from 66.112.44.186: bytes=32 time=1ms TTL=126
Ping statistics for 192.168.12.140:
    Packets: Sent = 4, Received = 4, Lost = 0 (0% loss),
Approximate round trip times in milli-seconds:
    Minimum = 1ms, Maximum = 1ms, Average = 1ms
Network diagram:
I have a
Relevant config from 2901 router:
interface Vlan254
 ip address 192.168.254.2 255.255.255.248
 ip nat outside
 ip virtual-reassembly in
 no ip route-cache
interface GigabitEthernet0/1.12
 description Primary DMZ
 encapsulation dot1Q 12
 ip address 192.168.12.1 255.255.255.0
 ip nat inside
 ip inspect Inspect_1 in
 ip inspect Inspect_1 out
 no ip route-cache
interface GigabitEthernet0/1.66
 description Public
 encapsulation dot1Q 66
 ip address 66.112.44.190 255.255.255.240
 ip access-group Public_Access in
 no ip route-cache
ip nat inside source static 192.168.12.140 66.112.44.186
mgaven
This behaviour is correct following your configuration.
You have declared interface GigabitEthernet0/1.12 "NAT inside" and the interface Vlan254 "NAT outside".
If you send a ping from 192.168.1.x to 192.168.12.140 , the reply ingress to the 2901 from the "INSIDE" and egress from the "OUTSIDE". This causes that the router applies the rule "ip nat inside source static 192.168.12.140 66.112.44.186" and this is the IP that you see in your console, it´s correct.
Maybe the correct configuration for your scenario (I don´t know what do you want with it) is to declare like "NAT Outside" the interface GigabitEthernet0/1.12, not the interface vlan 254.
Success!
