Sub-Interface Packet Drop
nasr.khan
When connecting Link2 to subinterface it shows packet drops,but connecting Link2 directly on a PC shows no packet drops.
Swapped the interfaces but still shows packet drops. Anything wrong with config
Config
crypto isakmp policy 1
encr 3des
hash md5
authentication pre-share
crypto isakmp key PAL address 90.20.25.94
crypto ipsec transform-set STRONG esp-3des esp-md5-hmac
crypto map VPN 10 ipsec-isakmp
set peer 90.20.25.94
set transform-set VPN-2-B1
match address VPN-2-B1_GRE
interface Tunnel9
description connection-to-B1
ip address 172.16.100.205 255.255.255.252
ip mtu 1400
ip flow ingress
ip flow egress
no ip mroute-cache
tunnel source 75.226.8.66
tunnel destination 90.20.25.94
interface Tunnel10
description connection-to-B1_Link2
ip address 172.16.102.20 255.255.255.252
tunnel source 192.168.1.20
tunnel destination 192.168.3.2
interface Loopback1
ip address 172.16.16.1 255.255.255.255
interface GigabitEthernet0/0
no ip address
duplex full
speed 100
media-type rj45
interface GigabitEthernet0/0.1
encapsulation dot1Q 1 native
ip address 192.168.199.1 255.255.255.248
interface GigabitEthernet0/0.9
description Link1
encapsulation dot1Q 9
ip address 75.226.8.66 255.255.255.224
interface GigabitEthernet0/0.10
description Link2
encapsulation dot1Q 10
ip address 192.168.1.20 255.255.255.224
interface GigabitEthernet0/1
description Lan Connection
ip address 10.10.10.1 255.255.255.248
duplex full
speed 100
router eigrp 5
variance 128
redistribute ospf 1
network 172.16.100.205 0.0.0.3
metric weights 0 1 1 1 0 0
default-metric 100000 1000 255 1 1500
distance eigrp 120 190
no auto-summary
router ospf 1
log-adjacency-changes
redistribute eigrp 5 subnets
network 10.10.10.1 0.0.0.0 area 0
ip route 0.0.0.0 0.0.0.0 75.226.8.68
ip route 192.168.3.2 255.255.255.255 192.168.1.22
Giuseppe Larosa
Hello Nasr,
what device is involved?
you may be facing a performance issue and not a configuration problem.
Hope to help
Giuseppe
