02-09-2013 08:23 PM - edited 03-07-2019 11:37 AM
Dear friends,
We have layer-2 6500-CATOS switches which are connected to one layer-3 6500-IOS switch via
port-channel consist of 4x1G interfaces from each switch, and each switch contains three
vlans. We want to have same vlan number across all layer-2 switches without VTP and want to create
sub-interfaces on layer-3 switch under the respective port-channel interface (same like router on a stick), but were unable to do it.
Now need your help to create sub-interfaces. Always getting this error 'Command rejected: VLAN 308 not available' but vlan exist. see below confiugration of my layer-3 switch.
EOB2EUDS#config t
Enter configuration commands, one per line. End with CNTL/Z.
EOB2EUDS(config)#int po1.308
EOB2EUDS(config-subif)#en
EOB2EUDS(config-subif)#encapsulation do
EOB2EUDS(config-subif)#encapsulation dot1Q 308
EOB2EUDS(config-subif)#do show vtp status
VTP Version : 2
Configuration Revision : 0
Maximum VLANs supported locally : 1005
Number of existing VLANs : 24
VTP Operating Mode : Transparent
VTP Domain Name : EOB
VTP Pruning Mode : Disabled
VTP V2 Mode : Disabled
VTP Traps Generation : Disabled
MD5 digest : 0x08 0x31 0xEB 0x95 0xC2 0xC5 0xA9 0x54
Configuration last modified by 10.2.101.254 at 2-5-13 08:38:01
EOB2EUDS(config-subif)#do show vlan
VLAN Name Status Ports
1 default active
9 ENTRY active
208 3W-Linux active
308 3W-WIN active
02-10-2013 12:46 AM
Can you give output of show etherchannel
Smitesh
02-10-2013 01:45 AM
Its been resolved by deleting layer-2 vlan database from the switch then i managed to create sub-interfaces means point-to-point same as juniper router, this solution will eliminate spanning the same vlans(VTP) across switch network as well layer-2 loop problem.
We got this idea from juniper router. thanks.
02-10-2013 01:47 AM
closing thanks all for your support as i have managed to resolved the problem.
