Subinterface configuration on ASA
snowmizer
I am trying to set up my ASA 5510 inside interface with sub-interfaces because I need to allow for more than one VLAN on the same physical interface. I have the ASA configured for the subinterfaces and pointing to vlan 10. I have the switch port on my core swith where the ASA inside interface plugs into set up as a trunk port with vlan 10. When I try to access my ASA from inside the network I cannot connect. Here's a sample of each config:
ASA
interface Ethernet0/1
speed 100
duplex full
no nameif
no security-level
no ip address
interface Ethernet0/1.1
description Inside
vlan 10
nameif inside
security-level 100
ip address 10.128.1.254 255.255.0.0
Core Switch port
interface GigabitEthernet4/16
switchport trunk native vlan 10
switchport mode trunk
duplex full
qos trust dscp
auto qos voip trust
tx-queue 3
   priority high
   shape percent 33
spanning-tree portfast
service-policy output autoqos-voip-policy
If I set up the inside interface without the sub-interface and leave the switchport as an access port I can get to my ASA fine. However I need the VLANs for a current project I'm working on. I've looked at lots of documentation and from what I've read everything looks fine. What am I missing?
Thanks.
IAN WHITMORE
Level 4
Level 4
You've set the native vlan to vlan 10, so the switch actually doesn't tag these packets. Change the native vlan to something else and try again. That could be it.
HTH,
Ian
IAN WHITMORE
Level 4
Level 4
HTH,
Ian
IAN,
YOU ARE A GENIUS!!!!!! That was it. Thank you so much.
I wish. But very nice of you to say so
Glad it sorted it for you.
Ian
