subinterfaces on 4948
sultan-shaikh
Level 5
Level 5
EDIT: Just confirmed on the forum that sub-interfaces are not possible on 4948.
My stupid mistake, I didn't use the search feature earlier.
Thanks to original contributors.
Cheers
Guys,
Is it possible to configure L3 sub interfaces on 4948 switches (switches 🙂
I don't have it with me hence can't verify.
Cheers
~sultan
Giuseppe Larosa
Hello Sultan,
no problem you are wellcome.
I'm answering to your thread just to remove it from the list of unanswered.
Best Regards
Giuseppe
