Subnet issues
unnikannanvj
Community Member
Hi Team
Suppose that an IP address is assigned to a device, not an interface of the device.
How would subnetting be done in this case?
Thank you.
Unni
John Blakley
I'm not sure I understand the question...
The address would still be part of an overall subnet regardless if it's per interface or per device. For example, if you had a device that had three nics, you may need a different address on each nic, but if you have a printer, it only uses a single address for the whole node.
HTH,
John
*** Please rate all useful posts ***
HTH, John *** Please rate all useful posts ***
Unni, John,
To add my two cents, in IP, there is no such thing as "IP address per device". In the IP addressing paradigm, addresses are always assigned to interfaces, never to entire devices. If the device has just one network interface, the address will be assigned to that interface, sometimes giving the impression that it is the device's address. In reality, though, IP addresses are always a property of network interfaces, and are therefore directly related to the network into which respective network interfaces connect to.
Best regards,
Peter
Joseph W. Doherty
Disclaimer
The  Author of this posting offers the information contained within this  posting without consideration and with the reader's understanding that  there's no implied or expressed suitability or fitness for any purpose.  Information provided is for informational purposes only and should not  be construed as rendering professional advice of any kind. Usage of this  posting's information is solely at reader's own risk.
Liability Disclaimer
In  no event shall Author be liable for any damages whatsoever (including,  without limitation, damages for loss of use, data or profit) arising out  of the use or inability to use the posting's information even if Author  has been advised of the possibility of such damage.
Posting
As Peter has noted, you normally assign IPs to interfaces, although something like a routing protocol's explicit router-ID might be considered an "IP address" assigned to the device and not an interface.
As to assigning a subnet mask, it really depends on whether the IP address is routable, and whether it will create a conflict with other interface IPs on the device as Cisco devices often "complain" (or not accept) if they see multiple interfaces within the same subnet.
