Router not issuing IP's
rrealy
Hello all,
Newbie here and have been working on configuring a router and not having any luck getting ip's from it.
Any help will greatly be appreciated....
Current configuration : 3990 bytes
! Last configuration change at 01:06:48 PCTime Thu Aug 29 2013
version 12.4
hostname St.Patricks
boot-start-marker
boot-end-marker
logging message-counter syslog
enable secret 5 $1$lvNA$wGnkzv7kjLmif0RNDxf2g0
no aaa new-model
clock timezone PCTime -6
clock summer-time PCTime date Apr 6 2003 2:00 Oct 26 2003 2:00
crypto pki trustpoint TP-self-signed-3607837666
enrollment selfsigned
subject-name cn=IOS-Self-Signed-Certificate-3607837666
revocation-check none
rsakeypair TP-self-signed-3607837666
crypto pki certificate chain TP-self-signed-3607837666
certificate self-signed 01
  30820243 308201AC A0030201 02020101 300D0609 2A864886 F70D0101 04050030
  31312F30 2D060355 04031326 494F532D 53656C66 2D536967 6E65642D 43657274
  69666963 6174652D 33363037 38333736 3636301E 170D3133 30383239 30363232
  34395A17 0D323030 31303130 30303030 305A3031 312F302D 06035504 03132649
  4F532D53 656C662D 5369676E 65642D43 65727469 66696361 74652D33 36303738
  33373636 3630819F 300D0609 2A864886 F70D0101 01050003 818D0030 81890281
  8100E525 0425ECCD 2F904636 B21AF280 AD7993E4 8F79564C 6203B366 E769FAF5
  62DACE0A 40CFD386 0F5BD78F FE7C6A7C EACC4A3C 3F84A48C AC7D3280 9FF029BE
  D5BA4E83 00F7BD4B 11984721 76F5CCDF D03E6CD7 84195C8F 73D770C8 99734F0D
  4F583941 0BE9FD8D 87F3D876 FFDB0588 2BECA057 79DA62D2 AC47D3ED 6AE5C7F4
  B3AB0203 010001A3 6B306930 0F060355 1D130101 FF040530 030101FF 30160603
  551D1104 0F300D82 0B53742E 50617472 69636B73 301F0603 551D2304 18301680
  146385C7 4B02E815 B28909F2 2A604395 37FB3F60 21301D06 03551D0E 04160414
  6385C74B 02E815B2 8909F22A 60439537 FB3F6021 300D0609 2A864886 F70D0101
  04050003 81810067 7A20CF98 7D7FAC17 A5B73A4A 00BEAE11 3BFFF9BC 1A74E61A
  E7DC833C FDBA0BB8 A0F74011 C3B1F3AA 0CF39238 66A9AF5F EB62E3C3 D92A4289
  E6000537 D253E03F A1B95F7C A545EC84 14724057 E72DAEE2 568A7B40 174FEB03
  1373CFAE 4BEC84B1 794E3E1B D56E2DDC DD2B1162 7B0A782C A4D2391E 83DA63D6
  4CD7029D B9F668
        quit
dot11 syslog
ip source-route
ip dhcp excluded-address 10.10.10.1 10.10.10.99
ip dhcp pool DHCP_POOL
   import all
   network 10.10.10.0 255.255.255.0
   dns-server 208.67.222.123 208.67.220.123
   default-router 10.10.10.1
   domain-name St.Patricks
ip cef
no ip domain lookup
no ipv6 cef
username patrick privilege 15 secret 5 $1$MLJt$jLLnyQkm61ukzlwxHB/7f0
archive
log config
  hidekeys
interface FastEthernet0
description WAN
ip address dhcp
ip nat outside
ip virtual-reassembly
duplex auto
speed auto
interface FastEthernet1
no ip address
shutdown
duplex auto
speed auto
interface FastEthernet2
interface FastEthernet3
interface FastEthernet4
interface FastEthernet5
interface FastEthernet6
interface FastEthernet7
interface FastEthernet8
interface FastEthernet9
interface Dot11Radio0
no ip address
shutdown
speed basic-1.0 basic-2.0 basic-5.5 6.0 9.0 basic-11.0 12.0 18.0 24.0 36.0 48.0 54.0
station-role root
interface Dot11Radio1
no ip address
shutdown
speed basic-6.0 9.0 basic-12.0 18.0 basic-24.0 36.0 48.0 54.0
station-role root
interface Vlan1
no ip address
interface Async1
no ip address
encapsulation slip
ip forward-protocol nd
ip http server
ip http authentication local
ip http secure-server
ip http timeout-policy idle 60 life 86400 requests 10000
control-plane
banner motd ^C
YOU ARE NO AUTHORIZED -------- SEE ADMINISTRATOR
^C
alias exec s show ip int br
alias exec sr show run
line con 0
exec-timeout 0 0
logging synchronous
line 1
modem InOut
stopbits 1
speed 115200
flowcontrol hardware
line aux 0
line vty 0 4
login
transport input telnet ssh
end
Thanks!
The router doesn't have an IP configured on an interface. Assuming that you want to use the switchports for your PCs, you have to configure the following:
interface vlan 1
  ip address 10.10.10.1 255.255.255.0
But for communication to the internet you need also NAT and (if available) a firewall-config.
Don't stop after you've improved your network! Improve the world by lending money to the working poor:
http://www.kiva.org/invitedby/karsteni
interface vlan 1
That was what I was missing. That worked. Thanks!
