Subnet mask
robertsmith10
Community Member
    Can someone please tell me if you can calculate the subnet mask having only the ip and default gateway?
Thanks in advance.
As mentioned before, you can't tell that. But you can calculate the smallest subnet possible to make sure that both PC and DG are in the same subnet.
Example: PC has 10.0.0.194 and DG has 10.0.0.254. With a subnet-mask of /26 (255.255.255.192) both are in the same subnet. But with any bigger subnet (/25, /24, ...) the PC would also be able to reach it's gateway.
Challenge questions: Which minimum subnet is needed for:
  1. PC 10.0.0.126, DG 10.0.0.129
  2. PC 10.0.0.200, DG 10.0.1.254
  3. PC 10.0.1.0, DG 10.0.1.255
If you found this post helpful, please give it Kudos. If my answer solves your problem, please click Accept as Solution so others can benefit from it.
1. 10.0.0.0 /24
2. 10.0.0.0 /23
3. 10.0.0.0 /22
acampbell
Basically you cant tell your mask unless you are using the class defaults from your info.
Class "A" = 255.0.0.0 (1.0.0.0 - 126.255.255.255)
Class "B" = 255.255.0.0 (128.0.0.0 - 191.255.255.255)
Class "C" = 255.255.255.0 (192.0.0.0 - 223.255.255.255)
Alex
Regards, Alex. Please rate useful posts.
