I have two internet connections here, one is a T1 line connected to a Cisco 2800 series, the other is a DSL line connected to a Cisco 506-E which is used for a webserver and VPN traffic.
When I attempt to translate port 80 to the webserver on the internal network via the PDM, it says that it 'recommends I use X.X.X.0 instead of the full IP for the outside interface on the PIX.
The network is as follows:
IP Range: 159.112.75.1-159.112.75.255
IP Subnet: 255.255.255.128
2800 Series IP: 159.112.75.254
PIX IP: 159.112.76.1
PIX VPN Pool IP Range: 159.112.76.1-159.112.76.255
PIX VPN Pool Subnet: 255.255.255.0
All the machines are configured to use the 2800 series as the main gateway.
The webserver is using the DSL line on a separate interface (it also uses another interface for network traffic because it hosts files).
I need to forward port 80 as well as a few others to the webserver, but leave its settings untouched.
If we could work a way out how to do this then that would be awesome thank you.
-Mike Jankowski
