06-03-2005 06:35 AM - edited 03-05-2019 11:33 AM
Hi on my network a have this segment 167.175.60.0 with mask 255.255.255.0.
Can I take this segment to do something like 167.175.60.220 mask 255.255.255.252.
Can I have this segment with both masks?
thanks
regards
06-03-2005 06:51 AM
overlapping address spaces on the same router are not allowed. If you actually configure this:
interface FastEthernet0/0
ip address 167.175.60.1 255.255.255.0
and then try to configure:
interface FastEthernet0/1
ip address 167.175.60.221 255.255.255.252
the router would tell you:
167.175.60.220 overlaps with FastEthernet0/0
HTH,
GP
06-03-2005 06:52 AM
You cannot normally have two overlapping subnets on the same segment at the same time - at least not in the same router. Even in different devices, having an inconsistent mask is quite problematic. 167.175.60.220/30 is a subset of 167.175.60.0/24, so that would not be allowed.
But perhaps I misunderstand the question - could you go into a bit more detail please.
Kevin Dorrell
Luxembourg
