subnetting
carl_townshend
Hi all, is there a quick and easy way to remember subnetting, ie, /26 etc
JORGE RODRIGUEZ
Level 11
Level 11
Easy and quick way may varied from people to people, there are few short cut methods out there. Go over this link which I think is the easiest way .
http://www.cisco.com/web/about/ac123/ac147/archived_issues/ipj_9-1/ip_addresses.html
Rgds
Jorge
Jorge Rodriguez
frank.murray
Community Member
the way that works for me is this:
if you label the value of each bit position in a byte you get:
128 64 32 16 8 4 2 1
You have to commit this to memory.
Now for each bit over the classful boundry (8,16,24) you place the bit over the bit value. so for the /26, you're two bits over the classful 24:
1 1
this tells you that the subnet has a range of 64 addresses. If you had a /27 you would place an additional 1 over the 32 place:
1 1 1
this tells you a /27 is a 32 address range.
