suggession
dhanikonda
Dear sir,
iam having 2 broadband serviceses from different isps so iam planing to do the loadbalance and automatic failover so plz suggest me if router require or any switch(managble switch require).
plz give me the best possible.
Thanks&Regards
srini
Wantser1981_2
http://www.cisco.com/en/US/products/ps8787/products_ios_protocol_option_home.html
You may find this helpful.
PfR (Performance Edge Routing) Internet Presence is what you want to be looking at.
Available on 1800-7301 routers release 12.4(15)T and later.
Hope this helps
