02-20-2012 12:40 AM - edited 03-07-2019 05:02 AM
Hi all
can you please suggest me a Wi-FI device. which supports 50+ users per device.
Thanks & regards
sreekanth
02-20-2012 12:49 AM
What are you trying to achieve. Your statement is very cryptic.
Look under the Cisco Aironet portfollio to find your WAP. There is no single WAP that is designed for 50+ clients. Cisco recommends no more than 25 clients per WAP. If you are transmitting video this number is around 8-10 clients per WAP.
02-20-2012 12:52 AM
Do you want a router with WIFI in one box?
What are the limitations?
Are you looking to have a Wireless controller and run unified mode?
There are more questions before anyone could give you an answer. Could you give a little bit more explanation as to what you are looking to achieve?
