10-23-2019 10:51 AM
Wow, been while since I have looked at Cisco switches. I need an affordable L3 switch that will support VRF's and static routing between VRF's. I don't need POE, 10G, 40G, 48 ports. 12 port's would be enough 24 if I must.
Best I can tell the 550X won't do it, neither will the 350 series. I don't need a $3,000 switch to connect 6 devices! Back in the day a 3750X or 3750E would do the trick. but I need something not EOL/EOS or only supported by 3rd parties.
I have a /32 subnet that I need to static route out the all to the next hop. On same switch, I need to configure a /29 that will static route all it's traffic to the /32 on the same switch.
Yes, I have to deal with AT&T Internet that requires a L3 connection. Seems they can't "find the technology" to just give me a L2 hand off like other vendors can. :(
Or am I over complicating this trying to use VRF's and it could achieve the same without them?
Suggestions?
Solved! Go to Solution.
10-24-2019 12:06 AM
Hi there,
Knowing you requirements of 6 devices, <$3000 and VRF-lite your best bet is the 3560CX, probably the 3560CX-8TC-S. You will need the IP Services license to get the VRF feature which will bump up the price but shouldn't break the bank.
cheers,
Seb.
10-24-2019 12:06 AM
Hi there,
cheers,
Seb.
10-26-2019 12:50 AM
I also need this kind of a switch to implement vlans for a small Network of less than 60 users. For me I don't need VRF, just to create vlans. Any suggestion of entry level L3 switch? No PoE, no 10g ports, probably 24 ports.
10-26-2019 01:10 AM
the C9200-24T might work as well...
