Suggestions to sort out IOS 12.2 outside NAT?
Chris Simon
Any suggestions of what to try to fix the outside for this 831? Here's the setup. It's connecting to another internal router which runs through the building's infrastructure to a faceplate in a computer lab. Testing the inside setup with Ubuntu desktop, I was able to get assigned to the 10.0.0.0 network. However, ping has no route to the internet.
What's stopping this from getting outside?
Here's the current running-config:
version 12.2
no service pad
hostname drizzledrazzle
logging queue-limit 100
enable secret 5 [password]
enable password [password]
ip subnet-zero
no ip routing
ip dhcp pool DHCP
   import all
   network 10.0.0.0 255.255.255.0
   default-router 10.0.0.1
   lease infinite
ip audit notify log
ip audit po max-events 100
no ftp-server write-enable
interface Ethernet0
 description Internal LAN
 ip address 10.0.0.1 255.255.255.0
 ip nat inside
 no ip route-cache
 no ip mroute-cache
 no cdp enable
 hold-queue 100 out
interface Ethernet1
 description Internet
 ip address dhcp
 ip nat outside
 no ip route-cache
 no ip mroute-cache
 no shutdown
 duplex auto
 no cdp enable
ip nat inside source list 100 interface Ethernet1 overload
ip classless
ip http server
no ip http secure-server
access-list 100 permit ip any any
line con 0
 exec-timeout 0 0
 no modem enable
 stopbits 1
 ip address dhcp
 ip nat outside
 no ip route-cache
 no ip mroute-cache
 shutdown
 duplex auto
 no cdp enable
ip classless
ip http server
line con 0
 exec-timeout 0 0
 no modem enable
 stopbits 1
line vty 0 4
 password [password]
 login
scheduler max-task-time 5000
end
2 Accepted Solutions
Jon Marshall
Chris
Couple of things to check/change -
1) do you have a default route ie. are you getting it via DHCP.
If you do a "sh ip ro" do you see a default route ?
2) can you change your NAT acl to -
access-list 100 permit ip 10.0.0.0 0.0.0.255 any
Jon
Chris
Your router has ip routing disabled.
You need to enable it ie. -
"ip routing"
and then you need to check whether you have a default route in the IP routing table.
Edit - sorry, I should have spotted that before :-)
Jon
10 Replies 10
Jon Marshall
Chris
Jon
I changed #2 to no effect. Here's the output for #1,
#sh ip ro
Default gateway is not set
Host               Gateway           Last Use    Total Uses  Interface
ICMP redirect cache is empty
Looking how to solve this...
Chris
"ip routing"
Jon
Here's another example config from a tutorial site for an 806 behind another router. [1] This is similar to my configuration.
Does it matter that my internal ip is 10.0.0.0 and the external ip from the current network is 10.0.0.0 as well? Should I change this to 192.168.0.0 or 10.10.10.0? Is this a possible conflict?
Fact is the router is getting DHCP from the external network and my internal NAT is assigning IPs, but they're just not connecting.
From the 806 example, there is this line:
ip route 0.0.0.0 0.0.0.0 66.108.112.1
!--- IP address 66.108.112.1 is the next hop IP address, also called
!--- the default gateway. Your Internet service provider (ISP) can tell you what IP address to
!--- configure as the next hop address.
I've replaced with this, simply because the external, which I receive at Ethernet1 is dhcp, and I don't know what it's going to be.
ip route 0.0.0.0 0.0.0.0 Ethernet1
What am I missing here?
1: http://www.cisco.com/c/en/us/support/docs/broadband-cable/cable-modems/19268-router-behind-cm-19268.html
Chris
Apologies for this, I missed your post a while back.
Can you post your full configuration at the moment together with a "sh ip route".
What exactly do you mean by packet loss ie. what symptoms are you seeing ?
Jon
No worries. It's a free country. haha.
Here's my current running config
version 12.2
no parser cache
no service pad
no logging console
enable secret 5 $1$/7YO$wqJvklE9jh9fuaa.r2HEN1
ip subnet-zero
ip dhcp pool CLIENT
   import all
   network 10.10.10.0 255.255.255.0
   default-router 10.10.10.1
ip audit notify log
interface Ethernet0
 ip address 10.10.10.1 255.255.255.0
 ip nat inside
 no ip route-cache
 no ip mroute-cache
 no cdp enable
 hold-queue 100 out
interface Ethernet1
 ip address dhcp
 ip nat outside
 no ip route-cache
 no ip mroute-cache
 duplex auto
 no cdp enable
ip nat inside source list 102 interface Ethernet1 overload
ip classless
ip http server
access-list 102 permit ip 10.10.10.0 0.0.0.255 any
no cdp run
line con 0
 exec-timeout 0 0
 no modem enable
 stopbits 1
line aux 0
 stopbits 1
line vty 0 4
 password [password]
 login local
 length 0
end
Route
drizzledrazzle#show ip ro
Codes: C - connected, S - static, R - RIP, M - mobile, B - BGP
       D - EIGRP, EX - EIGRP external, O - OSPF, IA - OSPF inter area
       N1 - OSPF NSSA external type 1, N2 - OSPF NSSA external type 2
       E1 - OSPF external type 1, E2 - OSPF external type 2
       i - IS-IS, L1 - IS-IS level-1, L2 - IS-IS level-2, ia - IS-IS inter area
       * - candidate default, U - per-user static route, o - ODR
       P - periodic downloaded static route
Gateway of last resort is not set
     10.0.0.0/24 is subnetted, 1 subnets
C       10.10.10.0 is directly connected, Ethernet0
And here's one more thing showing the ip assigned to the router, which shows up at restart:
Translating "eneiiiiee"...domain server (10.0.20.10) (10.0.1.16)
% Unknown command or computer name, or unable to find computer address
I don't think I can describe it any better without more information. It appears to me the router gets an ip from the external network (LAN) and my computer connected to the router gets an ip from the internal network. But I still get no route to Host with a ping.
EDIT
Here's a post from supportforums.cisco.com [1] describing a default route through dhcp with dhcp as the last argument of `ip route`
drizzledrazzle#conf t
Enter configuration commands, one per line.  End with CNTL/Z.
drizzledrazzle(config)#ip route 0.0.0.0 0.0.0.0 dhcp
% Invalid input detected at '^' marker.
[1]: https://supportforums.cisco.com/discussion/10301531/default-route-through-dhcp-interface
[2]: http://www.cisco.com/c/en/us/td/docs/ios-xml/ios/sec_conn_esyvpn/configuration/12-4t/sec-easy-vpn-12-4t-book/sec-easy-vpn-rem.html
[3]: http://www.cisco.com/c/en/us/support/docs/broadband-cable/cable-modems/19268-router-behind-cm-19268.html
Chris
Is your outside interface up/up because if it was your routing table should show the static route you have in the configuration but it isn't.
What does a "sh ip int brief" show ?
Jon
This is frustrating. I can find detailed instructions for something like the 806 router [1], but this doesn't workout on the 831 router. Previously, when I've asked for assistance on this unit (before I bought an 871W and gave up for my personal use) one thing was people were giving me commands which didn't apply to this unit--no wonder I got it for $15 on ebay ! But this darn thing worked once.
drizzledrazzle#show ip int brief
Interface         IP-Address      OK? Method Status       Protocol
Ethernet0         10.10.10.1      YES NVRAM  up           up
Ethernet1         10.0.20.105     YES DHCP   up           up
[1]: http://www.cisco.com/c/en/us/support/docs/broadband-cable/cable-modems/19268-router-behind-cm-19268.html
---MOVED REPLY UP--
Helo,
I'm still really interested in solving this problem. Anyone able to help?
PS> Sorry about the "correct answer" thing, I accidentally clicked this and then tried to click it off. This ended up giving me three incorrect "correct answers"!
