SUP 2T temperature
adamgibs7
Level 6
Level 6
Dears
I get the below from the show environment output I want to proof that the below output temperature is normal for the asic can anybody route me to the proper document for proof.
switch 1 module 5:
  switch 1 module 5 power-output-fail: OK
  switch 1 module 5 outlet temperature: 35C
  switch 1 module 5 inlet temperature: 26C
  switch 1 module 5 device-1 temperature: 30C
  switch 1 module 5 device-2 temperature: 33C
  switch 1 module 5 asic-1 temperature: 55C
  switch 1 module 5 asic-2 temperature: 46C
  switch 1 module 5 asic-3 temperature: 35C
  switch 1 module 5 asic-4 temperature: 59C
  switch 1 module 5 asic-5 temperature: 45C
  switch 1 module 5 asic-7 temperature: 45C
  switch 1 module 5 asic-8 temperature: 60C
  switch 1 module 5 RP outlet temperature: 31C
  switch 1 module 5 RP inlet temperature: 27C
  switch 1 module 5 RP device-1 temperature: 42C
  switch 1 module 5 EARL outlet temperature: 31C
  switch 1 module 5 EARL inlet temperature: 26C
  switch 1 module 5 EARL device-1 temperature: 0C
  switch 1 module 5 EARL device-2 temperature: 0C
- See more at: https://supportforums.cisco.com/discussion/12504416/sup-2t-temperature#sthash.GH80y1Se.dpuf
Mark Malone
whats that specific module 5 , the SUP2T temps below  0-40c is the normal operation temps
i have 5 6500s here all with dual sup2t all running over that as standard , only if there hitting and staying at above 70 you should be fine
http://www.cisco.com/c/en/us/products/collateral/interfaces-modules/catalyst-6500-series-supervisor-engine-2t/data_sheet_c78-648214.html
Example
switch-core4#SH ENv TEM | I asic
  module 5 asic-2 temperature: 35C
  module 5 asic-4 temperature: 52C
  module 5 asic-5 temperature: 46C
  module 5 asic-7 temperature: 46C
  module 6 asic-1 temperature: 54C
  module 6 asic-2 temperature: 35C
  module 6 asic-4 temperature: 52C
  module 6 asic-5 temperature: 46C
  module 6 asic-7 temperature: 46C
  module 6 asic-8 temperature: 57C
