Sup 2T with TCAM issue
Hi All
We are facing a issue regarding with TCAM on ACL entries for one of the vlan.
- VLAN ACL applied on 1 ,2 , 3 Vlans ,only users on 3rd Vlan are facing packet drop/slowness , after remove the ACL it’s working fine without packet drop.
- Same ACL used in Sup720 (sometimes before upgrade to Sup2T VSS)   - ACL entry ( nearly 500 line item)
- TCAM B only used(90 %), why TCAB A block not used(10 %)
- If hardware limitation for Sup2T ,than why it’s working in 1st & 2nd VLAN
- Most of TCAM command not support in Sup2T ( Currently Running Image version # s2t54-advipservicesk9-mz.SPA.150-1.SY1.bin )
TCAM Output:
chesw0301#show platform software acl tcam count
Showing TCAM counts
                                       Total    Used    Free
TCAM A  Bank 0    16384      1188   15196
TCAM A  Bank 1    16384      283    16101
TCAM B  Bank 0    16384      16286  98
TCAM B  Bank 1    16384      16381  3
QoS TCAM
                                       Total    Used    Free
Other Errors:-
Dec 26 16:34:00: %EARL_CM-SW1_DFC1-5-NOTCAMENTRY: No free tcam entries available on tcam=1 bank=0
Dec 26 16:34:00: %EARL_CM-SW2_STBY-5-NOTCAMENTRY: No free tcam entries available on tcam=1 bank=0
Dec 26 16:34:00: %EARL_CM-SW1_DFC4-5-NOTCAMENTRY: No free tcam entries available on tcam=1 bank=0
Dec 26 16:34:00: %EARL_CM-SW2_DFC1-5-NOTCAMENTRY: No free tcam entries available on tcam=1 bank=0
CM-MSG:ERR Error programming tcam entries for fno:0 status:-2
CM-MSG:ERR cm_replace_req_hdlr: hw programming error for appid:8
Pandiyan
0 Replies 0
