Sup-32: Boot into Rommon
colmgrier
After reload Sup-32 (6509), it boots into Rommon mode.
Please advise
Sup-32#sh running-config | i boot
boot-start-marker
boot system sup-bootdisk:s3223-adventerprisek9_wan-mz.122-33.SXH5.bin
boot system sup-bootdisk:s3223-adventerprisek9_wan-mz.122-33.SXH3.bin
boot-end-marker
Sup-32#sh version
12.2(33)SXH5, RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2009 by Cisco Systems, Inc.
Compiled Thu 16-Apr-09 01:34 by prod_rel_team
ROM: System Bootstrap, Version 12.2(17r)SX3, RELEASE SOFTWARE (fc1)
p21-cty-core-01 uptime is 13 minutes
Uptime for this control processor is 13 minutes
Time since p21-cty-core-01 switched to active is 12 minutes
System returned to ROM by power cycle at 11:15:17 GMT Fri Oct 23 2009 (SP by po
wer on)
System image file is "sup-bootdisk:s3223-adventerprisek9_wan-mz.122-33.SXH5.bin"
cisco WS-C6509-E (R7000) processor (revision 1.2) with 458752K/65536K bytes of m
emory.
Processor board ID SMG1039NZFB
R7000 CPU at 300Mhz, Implementation 0x27, Rev 3.3, 256KB L2, 1024KB L3 Cache
Last reset from power-on
18 Virtual Ethernet interfaces
48 FastEthernet interfaces
15 Gigabit Ethernet interfaces
1915K bytes of non-volatile configuration memory.
65536K bytes of Flash internal SIMM (Sector size 512K).
rommon 1 > set
PS1=rommon ! >
LOG_PREFIX_VERSION=1
SUPW_6=1
BOOTLDR=
SUPW_5=1
CRASHINFO=crashinfo_FAILED
SLOTCACHE=cards;
RET_2_RTS=17:20:13 UTC Mon Sep 14 2009
BOOT=bootdisk:s3223-adventerprisek9_wan-mz.122-33.SXH5.bin,12;bootdisk:s3223-adv
enterprisek9_wan-mz.122-33.SXH3.bin,12;
?=0
TYFIB_BLOCK_ALLOC=
CV=bootdisk:s3223-adventerprisek9_wan-mz.122-33.SXH5.bin
BSI=0
RET_2_RCALTS=
RANDOM_NUM=1097206823
ACL_DENY=0
PF_REDUN_CRASH_COUNT=0
rommon 2 >
rommon 2 > dir bootdisk:
Initializing ATA monitor library...
Directory of bootdisk:
2 60139044 -rw- s3223-adventerprisek9_wan-mz.122-33.SXH3.bin
14685 26843548 -rw- sea_log.dat
21239 60237860 -rw- s3223-adventerprisek9_wan-mz.122-33.SXH5.bin
lgijssel
Level 9
Level 9
Clear the BOOT variable to load the first file in flash. (SXH3):
rommon >set BOOT =
Then reload again and when it boots, modify the BOOT-line to use IOS SXH5.
regards,
Leo
lgijssel
Level 9
Level 9
rommon >set BOOT =
regards,
Leo
