Sup-7 cores backgroud processing
r.kukreja
We recently installed the sup 7-E there are two cores on Ist core cpu utilization is 10% and on other one it is 15 % .can any one tell on what basis the cpu processing decision is made and why it is lesson Ist core and high on other core.
Rajat
16 Replies 16
r.kukreja
Can any body share there view on above. its not lesson it is less on ist core and high on othercore as mentioned above.
rajat
can any body reply ?response will be highly appreciated
Rajat
Jon Marshall
Rajat
It depends on how you have it setup and how the traffic passes through the switches. For example if you have HSRP and STP setup so that one of the switches is the active HSRP and STP root then more traffic will go to this switch than the other one.
So the fact that one switch is showing higher CPU than the other is not necessarily an issue. Like i say it's difficult to give any more information.
Jon
Hi Jon,
Thanks for your exclusive response. actually  StP and HSRP kind of traffic is not flowing through this swtich it is in transparent mode.
my qusetion is if there are 10 packets why seven packet go to ist core and 3 packet to 2 core. why dont packet equally get distribute.
Rajat
It all depends on how your topology is setup. Without knowing how the switches are interconnected it's impossible to say. It could simply be that you have more devices communicating via one switch than the other.
Like i say, without understanding the topology it's impossible to say.
Jon
There is not an issue of topolgy. there are SAP servers and database server and web servers are connected just
and my question is not topology specific. its a general  question whose answer i am eager to know. I just want to know
why 2 cores does not have same utilization at same period.
But it is to do with our topology. For example lets say you have multiple servers dual honed to both switches. If you are running active/passive then the switch with the active connection will be receiving more packets than the switch with the passive connection.
It is all to do with how much traffic each switch is processing and unless you can confirm that each switch has exactly the same number of active connections from servers/uplinks etc. then it's not surprising that one switch has a higher utilisation than the other.
Jon
edvgispteam
hi,
last week i replaced our campus switches (2 4k5 sup6) with sup7 and see the same "issue" as r.kukreja. Of course the switch which is the root bridge and hsrp primary got more cpu utilization than the other(that was already like that with the sup6) but we are talking about 50-60% more utilization( and approximatley 20% more than with the sup6). when i do an "show proc cpu sort" i see that the load isn´t equally load-shared at all, my question is what happens if one of the cores hit´s 100% or some watermark at 90%? Will then start some sort of intelligent load-share process? Can i influence that behaviour with some hidden command other than making 50% of my hsrp&stp instances primary on the other switch?
Core 0: CPU utilization for five seconds: 25%; one minute: 26%; five minutes: 25%
Core 1: CPU utilization for five seconds: 74%; one minute: 65%; five minutes: 64%
PID    Runtime(ms) Invoked  uSecs  5Sec     1Min     5Min     TTY   Process
10151  1533830     37678302 1      43.27734 40.64355 39.88671 0     iosd
5474   1111163     5329219  574    0.353516 0.311523 0.315430 0     ffm
10965  167388      1058260  3949   0.040039 0.040039 0.040039 0     cpumemd
10109  16624       872705   4284   0.017578 0.002930 0.001953 0     licensed
8326   12321       859260   4342   0.011719 0.002930 0.002930 0     cli_agent
5450   12519       953909   4119   0.002930 0.002930 0.002930 0     hwcontrol
5460   10131       846035   1821   0.002930 0.002930 0.002930 0     profiled
5480   17008       962825   4282   0.002930 0.003906 0.003906 0     plogd
5547   14815       954105   2023   0.002930 0.002930 0.002930 0     pdsd
8347   13276       1058604  369    0.002930 0.002930 0.002930 0     ngdumper_provid
10971  11002       882531   2733   0.002930 0.002930 0.002930 0     licenseagentd
8      7818        324919   10843  0.001953 0.001953 0.001953 0     events/1
5438   10460       859752   2175   0.001953 0.001953 0.001953 0     ha_mgr
5442   10087       845189   1771   0.001953 0.001953 0.001953 0     oscore_p
5454   10328       845036   2057   0.001953 0.001953 0.001953 0     ns_oir_proxy
5456   10353       848217   2079   0.001953 0.001953 0.001953 0     sysmgr
5466   10301       846231   2022   0.001953 0.001953 0.001953 0     os_info_p
5470   13831       937382   1009   0.001953 0.001953 0.001953 0     eicored
5602   10114       849553   1794   0.001953 0.001953 0.001953 0     iifd
7972   10565       858390   2301   0.001953 0.001953 0.001953 0     dtmgr
8239   10733       856520   2503   0.001953 0.001953 0.001953 0     installer
8257   10402       850223   2131   0.001953 0.001953 0.001953 0     snmp_subagent
9731   10202       845370   1907   0.001953 0.001953 0.001953 0     netd
10533  9986        846620   1649   0.001953 0.001953 0.001953 0     liin_tap
7      5971        323381   5184   0.000977 0.000977 0.000977 0     events/0
thanks
Gernot
Gernot
If the switch hits 90 - 100% it will not intelligently load-balance although you may find that it cannot respond to HSRP queries and so the standby becomes active.
If it is a concern then you should look to load balance your vlans as you suggest with odd vlans on sw1 and even vlans on sw2. That would at least spread the load from the clients. But you also need to be aware of return traffic if the traffic goes beyond the 4500 switches ie. if you had a WAN router one connected to sw1 that would be an issue as well.
Jon
Hi Jon,
thanks for your quick reply. alright, so i think the answer is that i have no choice in influencing that behaviour(except for changing my topology design). One last question, what´s the point of having a multicore environment when one core is doing almost all the work and the other one is "sleeping", do you know what´s behind those iosd processes that consume most cpu time?
thanks!
Gernot
Gernot
Having a core with 2 switches is primarily for redundancy so that if one switch fails there is no interruption in service within your network. That is the primary reason.
However, switches, especially the modular ones, are expensive so it makes sense to try and use both if you can. That is why a common approach is to spread the STP root and HSRP active between the switches that do the inter-vlan routing. And if you hve WAN connectivity it is also a good idea to connect any WAN routers to both switches, that way each router has 2 active paths for return traffic and will spread the traffic load.
Note that obviously within a network you never get a 50/50 spread of traffic because some connections send a lot more traffic than others but it is still worth load-balancing vlans on our core/distro switches.
Jon
i think we are talking about different things when we use the word "core". when i wrote core i meant a single core from an dual core cpu as the one in the sup7. take a look at the output(that´s from one physical switch with a single supervisor engine in the chassis):
It seems that when you are talking about core you mean an switch as part of the core switching layer, right?
Gernot
Gernot
Good point
I suspect, but do not know, that some processes/protocols might well be assigned to a specific core ie. they always use the same CPU and that is why you are seeing a higher utilisation on one than the other but i can't say for sure.
Apologies for my misreading of the question.
Jon
no problem :-)
i think i will open an TAC case, when i got more informatin on that i will update this thread!
thanks anyway
Gernot
