SUP2 not booting
pmarques
I'm having problems with a WS-X6K-SUP2-2GE module that is not booting up.
This is the output I get when trying to boot it up:
rommon 1 > i
System Bootstrap, Version 6.1(3)
Copyright (c) 1994-2000 by cisco Systems, Inc.
Testing lower main memory - data equals address
Testing lower main memory - checkerboard
Testing lower main memory - inverse checkerboard
Clearing lower 16K memory for cache initialization
Clearing bss
Reading monitor variables from NVRAM
Warning: Rommon NVRAM area is corrupted. Initialize the area to default values
environment checksum in NVRAM failed
Enabling interrupts
Initializing TLB
Initializing cache
Initializing required TLB entries
Initializing main memory
Sizing NVRAMWarning: NVRAM size is 0
Initializing PCMCIA controller
Exiting init
c6k_sup2 processor with 131072 Kbytes of main memory
rommon 1 > set
PS1=rommon ! >
rommon 2 >
rommon 2 > boot
unable to initialize the monitor library "bootflash:%c7200-fslib-m"
boot: cannot open "bootflash:"
boot: cannot determine first file name on device "bootflash:"
rommon 3 > confreg 0x2102
You must reset or power cycle for new config to take effect
rommon 4 > reset
Clearing bss
Enabling interrupts
Initializing TLB
Initializing cache
Exiting init
I followed the instructions on this document, uploaded a new version into the SUP through xmodem but still no luck:
http://www.cisco.com/en/US/products/hw/switches/ps700/products_tech_note09186a008015bfa1.shtml
Is there anything else I can do to recover from this behaviour?
Pedro Miguel Marques
arunas.usonis
Hi Pedro,
What IOS version you trying to boot ? I guess that you probably below required min memory which could be 256MB,
where you have only 128. And you need to have 256 on both - SUP & MSFC
Reg
Arunas
Hi Arunas,
Thanks for your reply.
This a CatOS supervisor. I am trying it to boot from cat6000-sup2.6-4-4a.bin which is approximately 6MB in size. So I don't think memory is the issue here.
After some more reading I saw that this might be a problem related with the NVRAM need to use the battery (cr-2430) on board, if the battery ran out, then the NVRAM can not store the data.
If this is the case then I think RMA is my only chance.
Nonetheless please share your thoughts on this one.
