Sup2 OS Conversion
wpalumbo06
I am embarking on the fateful journey to convert a SUP2 from CATOS to IOS and from what I have read so far, it's not a an easy process to navigate.  I am ready for the challenge but will gladly accept any tips from those who have already successfully done this:-)
31 Replies 31
From what we saw MSFC did not actually crash. It just did not boot and SP took the ownership back. So MSFC can't boot the image for some reason:
- IOS RP image portion not good
- formmating not correct
- HW problem
- defect
- flash bad sector
So we need to exclude all these posibilities.
One of the ways is to get disk0: from first SUP and try with that if not already tried. Other way - try to load back to old OS- hybrid and then format all disks under MSFC IOS.
One more way - just replace bottflash on MSFC and SP.
Unfortunately don't have universal way as it still not clear why MSFC does not boot.
Nik
HTH,
Niko
Nik,
I have tried using the PCMCIA flash from the working SUP with IOS and CATOS - no luck.  How would I replace the bootflash on the MSFC and SP?
OK, let me make sure I understand the process up to this point. If the switch boots into SP rommon and I type boot disk0:imagename, the switch then loads the image and successfully boots the SP...after which the process is handed off to the RP (which fails). So is the RP trying to load the same image that is specified in the boot disk0: command? If so, is there any other file needed to successfully boot the RP? If yes, what is it and how can I get it onto the switch?
glen.grant
   Did you check all  the nvram and flash requirements for the SXD code (check release notes)  .  Those are a lot bigger than the hybrid codes  and some of the early models do not have enough nvram and flash to change .  Also not all Supervisor 2's  were sold with an msfc board installed  and were layer 2 only .
Adding to Glen. This is right - that is why I was asking if MSFC was working in CATOS/hybrid mode. And that is why one of the idea to return to CATOS is to check if MSFC is workable. You can actually pull out the module to see if MSFC daughter board is present on top.
Regarding the image. IOS has a single image both for SP and RP. It has just to portions of sub-image. SP loads SP portion and when control is passed to RP - it is trying to load RP portion from same file. So file itself seems to be good as long as you also tried another flash.
Let's make sure that MSFC is fine and present - first by examining the sup card and 2 loading hybrid image on it. (putting CATOS back- can be done copying CATOS image on disk0 from working SUP ).
Nik,
HTH,
Niko
yes, the module is present and attempting to load CATOS results in the following error:
rommon 2 > boot slot0:cat6000-sup2.6-3-5.bin
Error : compressed image checksum is incorrect 0x250A1C5D
        Expected a checksum of 0x8AEA1116
*** System received a Software forced crash ***
signal= 0x17, code= 0x5, context= 0x0
PC = 0x800200d8, Cause = 0x20, Status Reg = 0x30419003
Well...it's working fine now???
I took the daughter boards off to reseat them and found one of the DIMMS on the SUP popped up out of the socket.  It looked to still be making contact but I reinserted it and then reinstalled the daughter cards and the switch still failed to boot on the next two attempts but did boot fine on the third attempt.  I rebooted two more times with no problem and then moved the SUP from slot 1 to slot 2 and the problem returned?  The SUP that has always worked fine has no problem in slot 2, so maybe the problematic SUP has an intermittent hardware problem?
Good News,
Do you have any logs from last booting attempts which faileed. Just in case we can see smth to decode for root cause. Possibly physical reseat cleared some issue with bad contacts. Anyway glad you sorted that out.
Nik
HTH,
Niko
Seems like different results every couple of reboots.  Here is the latest:
00:00:04: %SYS-3-LOGGER_FLUSHING: System pausing to ensure console debugging output.
00:00:03: %C6K_PLATFORM-5-MISMATCH: 'sup-bootflash' device programming algorithm mismatch detected on SP (module: 2), formatting is recommended.
00:00:04: %PFREDUN-6-ACTIVE: Initializing as ACTIVE processor
Active crashed three times, disabling auto-boot and dropping to rommon
%Software-forced reload
Unexpected exception, CPU signal 23, PC = 0x401A44D0
-Traceback= 401A44D0 401A223C 406AEFAC 406B00A8 406B1AE4 406A7BA8 406A7410 4017E15C 4017E148
$0 : 00000000, AT : 434A0000, v0 : 43FB0000, v1 : 40DE0000
a0 : 50BB64D8, a1 : 434AC1A8, a2 : 00000000, a3 : 40DB0000
t0 : 40198408, t1 : 3401FD01, t2 : 40198408, t3 : FFFF00FF
t4 : 40198408, t5 : 00000000, t6 : 00002045, t7 : 50C64078
s0 : 00000000, s1 : 00000000, s2 : 40DB0000, s3 : 40DC0000
s4 : 40C70000, s5 : 00000000, s6 : 40C70000, s7 : 43FB0000
t8 : 00000000, t9 : 00000000, k0 : 30419001, k1 : 30410000
gp : 434AC9E4, sp : 50C64090, s8 : 00000000, ra : 401A223C
EPC  : 401A44D0, ErrorEPC : 31EA5567, SREG     : 3401FD03
MDLO : 000000BF, MDHI     : 000002FC, BadVaddr : E6ADA4DB
Cause 00000024 (Code 0x9): Breakpoint exception
Writing crashinfo to bootflash:crashinfo_20111014-021742
0 packets (aggregate) dropped on throttled interfaces
=== Flushing messages (02:17:42 UTC Fri Oct 14 2011) ===
Buffered messages:
Queued messages:
00:00:05: %SYS-3-LOGGER_FLUSHING: System pausing to ensure console debugging output.
00:00:04: %SYS-3-LOGGER_FLUSHED: System was paused for 00:00:00 to ensure console debugging output.
00:00:06: %SYS-3-LOGGER_FLUSHING: System pausing to ensure console debugging output.
00:00:06: %SYS-3-LOGGER_FLUSHED: System was paused for 00:00:00 to ensure console debugging output.
00:00:06: %OIR-6-CONSOLE: Changing console ownership to switch processor
signal= 0x17, code= 0x24, context= 0x43fb5784
PC = 0x4019844c, Cause = 0x1020, Status Reg = 0x34018002
rommon 2 >
Hmmm...I just issued the PF_REDUN_CRASH_COUNT command and the SUP booted OK???  Anything I should check while the switch is up on the problematic SUP?
Seems it was crashing last times due to that variable grew again due to the old crashes.
As it up please check following file systems for crashinfo files:
bootslash:
sup-bootflash:
also check:
show eobc
show ipc status
to check the current communication between rp and sp
Nik
HTH,
Niko
I have recovered the crash file from sup-bootflash but theres nothing in there that makes any sense to me:-)
Here is the output from those commands:
6509-SUP2#sh eobc
Interface information:
Interface EOBC0/0 (idb = 0x5043E438)
Hardware is Mistral EOBC (revision 4)
Address is 0000.2200.0000 (bia 0000.2200.0000)
Encap size         = 14         hardware status  = 0x210840
IDB type           = 18         IDB state        = 4
Encap type         = 0x1        Span encap size  = 0
Error threshold    = 5000       Error count      = 0
Counters:
rxring             = 0x89D99C0  rx ring entries       = 512
rx_head            = 240        rx_tail               = 0
inputs             = 1639       rx_cumbytes           = 210432
hw inputs          = 0          hw rx_cumbytes        = 0
rx rate (bits/sec) = 6000       rx rate (packets/sec) = 7
rx_buf_unavail     = 0          rx input drops        = 0
rxr eobc shadow    = 0x435AAA00 txr eobc shadow       = 0x5052BCE0
txring             = 0x89DBA00  tx ring entries       = 0x200
tx_head            = 334        tx_tail               = 334
outputs            = 1225       tx_cumbytes           = 154109
hw outputs         = 0          hw tx_cumbytes        = 0
tx rate (bits/sec) = 6000       tx rate (packets/sec) = 5
tx_retry_error     = 0          tx_retry_count        = 0
tx_process_stopped = 0          tx total drops        = 0
Mistral Registers
soft_reset_cfg     = 0x10FFFF   dma_buffer_size_reg   = 0x000000
int_mask_hi        = 0x03FFFF   int_mask_lo           = 0xE7F13A59
rxdscp_cnt         = 512        txdscp_cnt            = 0
rxwork_dscp        = 0xA8E0     txwork_dscp           = 0xC480
mistral_eobc_ds    = 0x50440300 mistral_dma_register  = 0x30000000
mistral_glbl_reg   = 0x10020000
Misc. Global Registers:
global_cfg         = 0x20       mis_init_sts          = 0x8
dimm_parm_cfg_hi   = 0x00000566 dimm_parm_cfg_lo      = 0x42040F5A
tm_init_size_cfg   = 0x8000
6509-SUP2#
00:01:09: %DIAG-SP-6-RUN_MINIMUM: Module 2: Running Minimum Diagnostics...
00:01:14: %DIAG-SP-6-DIAG_OK: Module 2: Passed Online Diagnostics
00:01:15: %OIR-SP-6-INSCARD: Card inserted in slot 2, interfaces are now online
6509-SUP2#sh ipc status
                            IPC System Status
Time last IPC stat cleared : never
This processor is an IPC slave server.
Do not drop output of IPC frames for test purposes.
6000 IPC Message Headers Cached.
                                                    Rx Side     Tx Side
Total Frames                                             1781        2670           0          0
Total from Local Ports                                   1559        1274
Total Protocol Control Frames                             634         688
Total Frames Dropped                                        0           0
                             Service Usage
Total via Unreliable Connection-Less Service              459          23
Total via Unreliable Sequenced Connection-Less Svc          0           0
Total via Reliable Connection-Oriented Service            688         614
                      IPC Protocol Version 0
Total Acknowledgements                                    634         688
Total Negative Acknowledgements                             0           0
                             Device Drivers
Total via Local Driver                                      0           0
Total via Platform Driver                                1781        1345
Total Frames Dropped by Platform Drivers                    0           0
Total Frames Sent when media is quiesced                                0
                     Reliable Tx Statistics
Re-Transmission                                                         0
Re-Tx Timeout                                                           0
          Rx Errors                              Tx Errors
Unsupp IPC Proto Version          0  Tx Session Error                  0
Corrupt Frame                     0  Tx Seat Error                     0
Duplicate Frame                   0  Destination Unreachable           0
Out-of-Sequence Frame             0  Tx Test Drop                      0
Dest Port does Not Exist          0  Tx Driver Failed                  0
Rx IPC Msg Alloc Failed           0  Ctrl Frm Alloc Failed             0
Unable to Deliver Msg             0  Invalid Messages                  0
          Buffer Errors                          Misc Errors
IPC Msg Alloc                     0  IPC Open Port                     1
Emer IPC Msg Alloc                0  No HWQ                            0
IPC Frame PakType Alloc           0  Hardware Error                    0
IPC Frame MemD Alloc              0
          Tx Driver Errors
No Transport                      0
MTU Failure                       0
Dest does not Exist               0
EOBC and IPC communication seems to be fine.
You can attach crashinfo here - may be I can see/decode smth.
P.S. use "more sup-bootflash:FILE_NAME" ro get output on screen. you can save that to file.
Nik
HTH,
Niko
Here is the crashinfo:
=== Start of Crashinfo Collection (02:17:42 UTC Fri Oct 14 2011) ===
For image:
IOS (tm) c6s2p2_sp Software (c6s2p2_sp-PK9SV-M), Version 12.2(18)SXD7b, RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2006 by cisco Systems, Inc.
Compiled Fri 08-Dec-06 10:19 by ccai
========= Show Alignment =============================
No alignment data has been recorded.
No spurious memory references have been recorded.
========= Malloc and Free Traces=====================
MallocFree Trace: ixmallocfree=0x22  ptr=0x43FA4340
43FA4230: 50B938B8 409C0174 44E8D538 238B9564 44E8D538 401984D0 44E1BE48 20000614
43FA4250: 44E1BE48 4019D268 44E1C0A8 200004E4 44E1C0A8 40188AE0 50B95AF0 20000058
43FA4270: 50B95AF0 409C0174 44E1C168 20000484 44E1C168 40188AE0 44E1C228 20000424
43FA4290: 44E1C228 40188AE0 44E1C2E8 200003C4 44E1C2E8 40188AE0 50C65C78 279CD1C4
43FA42B0: 50C65C78 4072AC38 44E1C3A8 20000364 44E1C3A8 40188AE0 44E1C468 20000304
43FA42D0: 44E1C468 4030A744 50B95B40 20000030 50B95B40 4030A790 44E8ECE0 238B8990
43FA42F0: 44E8ECE0 401984D0 44E1C4F0 200002C0 44E1C4F0 4019D268 44E1C750 20000190
43FA4310: 44E1C750 40188AE0 44E1C810 20000130 44E1C810 409C0174 44E1C860 20000108
43FA4330: 44E1C860 40188AE0 50C75CB0 279C51A8 50C75CB0 4017EBAC 44E8D478 238B95C4
43FA4350: 44E8D478 40188AE0 50B95BD0 20000010 50B95BD0 4017D658 44E1C9E0 4019DBC0
43FA4370: 44E1B238 4019849C 44E1C9E0 60000048 50B95970 4019DBF0 50B95970 20000118
43FA4390: 50B95970 40188AE0 50B95A30 200000B8 50B95A30 40188AE0 44E1B238 20000C1C
43FA43B0: 44E1B238 40188AE0 44E1B2F8 20000BBC 44E1B2F8 402D076C 44E1B650 20000A10
43FA43D0: 44E1B650 402D077C 44E1B9A8 20000864 44E1B9A8 40188AE0 44E1BA68 20000804
43FA43F0: 44E1BA68 40188AE0 50C644D0 279CDD98 50C644D0 401984D0 44E1BB28 200007A4
43FA4410: 44E1BB28 4019D268 44E1BD88 20000674 44E1BD88 40188AE0 50B938B8 2000002C
========== Stack Trace========
========= Context ======================
Signal = 23, Code = 0x24, Uptime 00:00:04
========= Stack Dump ===========================================================
Stack Frame Pointer in Context is 0x50C64090, at process level
50C63C90: 50089910 43F90000 40A125B0        0 50089910 43F90000 40A125B0 400DC62C
50C63CB0:        0        0        1        1        2        0 50C63FDC 50C63DE8
50C63CD0:       40       40 50C63DE8        0        0        0 50C63F08 400F1A98
50C63CF0: 50C63DF0 40C67E80 409ED9E8 50C63E9C        0       40 50C63D60 50C63E9C
50C63D10: 50C63DF0 400E79A0        0        0        0 FFFFFFFF FFFFFFFF       20
50C63D30:        0        0 409ED9D0        7        0        0        0        0
50C63D50:        0        4       77 50C63FE9       77        0        0 FFFFFFFF
50C63D70:       77        0 50C63F08 400F1A98 50C63FF1        0 40A158AB        4
50C63D90:        0       77 50C63DE8 50C63DE8        0 400E79A0 50C63E9C        0
50C63DB0:        0 FFFFFFFF 400E91B4 400E90F8 FFFFFFFF FFFFFFFF 40A158A8 50C63DE8
50C63DD0:      7DD BFC170E4      7DC BFC169D0       16 BFC169D0 F0303A30 303A3034
50C63DF0:        2 BFC16BBC        0 BFC16D08 A0003C90 50C64030 BE000000 50C64030
50C63E10:        0 BFC16FEC BE000000 50C64030        0       2D BE000000 BFC17084
50C63E30:        0       2D 50C64000 50C63ED0 BFC15AA8 BFC15A98        0 40C69B5C
50C63E50: 34018003 50C63EB0 BFC22DE4 44860000 40C70000        0 BFC18168 FFFFFFFF
50C63E70: 34018003 50C63ED0       1B BFC170E4 40C70000        0 BFC18168 40E60000
50C63E90: F0C184D0 4025AF9C        7 50C63EF0 BFC171C0        0 50C63ED0        3
50C63EB0: BFC184D0        0        0 434A0000        0        0        0       30
50C63ED0: 40DB0000 BFC16D8C        0 434A0000        0       C9     FFFF BADBEEF0
50C63EF0: BFC22BA8       2D        0 50C64030        0        0 34018003 50C63F68
50C63F10: 40E60000 44860000 40C70000        0 BFC18168        0 FFFFFFFF FFFF00FF
50C63F30:        0 40198408 40DB0000 6F6E736F   C63F68        3        A 4025AF9C
50C63F50:        0        0        0        3 4025B024 BFC121F0        0        0
50C63F70:        0 434A0000        0        0        A 4025AF9C        0       30
50C63F90:        0        0 400E9F80        0        0 40DB0000        0       20
50C63FB0: FFFFFFFE 400E7BFC        0 3401C100 FFFFFFFF FFFF00FF        0 40198408
50C63FD0:        0        0        0     2045        0 50C64078        0 40E60000
50C63FF0:        0        3        0 40E60000        0 44860000        0        0
50C64010:        0 FFFFFFFF FFFFFFFF       20        0        1        0        0
50C64030:        0        0        0 30419001        0 30410000 FFFFFFFE        0
50C64050: 40E60000 40DC0000 40C70000        0 40C70000 43FB0000        0 400EA208
50C64070: 403179C0 4030A1AC 40A42798      2FC        0        0 40DB0000 401A21F0
50C64090:        0 40A4277C        0 40DB0000 40E60000        3 40E60000 44860000
50C640B0: 406AEFAC 406AEF8C        0 40C69D9C        0        A 44860000        0
50C640D0: 43F00000 406B00A8        0        0 406B174C FFFFFFFF 44860000 406B1AE4
50C640F0: FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF 44860000        0        0        0
50C64110:        0        0        0        0 406A7BA8 FFFFFFFF FFFFFFFF FFFFFFFF
50C64130: FFFFFFFF FFFFFFFF 406A7410 FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF
50C64150:        0 4017E15C FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF 4017E148 FFFFFFFF
50C64170: FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF
50C64190: FFFFFFFF FFFFFFFF FD0110DF 10DFFD01 AB1234CD       3E 44E8CFD0 40A426D0
50C641B0: 40188AE0 50C64260 50C62A0C 80000048        1 44078710        0        0
50C641D0:        0 DEADFEED 50C64230 44E8D190 50C642A0 50007780 50C641D8 43FB3620
50C641F0:      14D    90000        2        0 40C655B8 4019C738 40DBEBEC        0
50C64210:        0        0        0        0        0        0        0        0
50C64230: 44E8D190        0 50C64220 50C641D8        0 43FB6490        0  FFFFFFF
50C64250:  FFFFFFF        0 FD0110DF 10DFFD01 AB1234CD FFFFFFFE        0 40A3DFD4
50C64270: 40188AE0 50C64320 50C641B4 80000048        1 44078710        0        0
50C64290:        0 DEADFEED 50C642F0 448DBBF0 44E8D290 50C641E0 50C64298 43FB3620
50C642B0:      14E    90000        2        0 40A14BFC 4019C738 40DBEBEC        0
50C642D0:        0        0        0        0        0        0        0        0
50C642F0: 448DBBF0        0 50C642E0 50C64298        0 43FB6490        0  FFFFFFF
50C64310:  FFFFFFF        0 FD0110DF 10DFFD01 AB1234CD       20 50B93608 40A3DFD4
50C64330: 40188AE0 50C643E0 50C64274 80000048        1 44078710        0        0
50C64350:        0 DEADFEED 50C643B0 448DBAD0 50C64420 44E8CB78 50C64358 43FB3620
50C64370:      151    90000        2        0 40ACC33C 4019C738 40DBEBEC        0
50C64390:        0        0        0        0        0        0        0        0
50C643B0: 448DBAD0        0 50C643A0 50C64358        0 43FB6490        0  FFFFFFF
50C643D0:  FFFFFFF        0 FD0110DF 10DFFD01 AB1234CD       2D 44E35FE8 40A3DFD4
50C643F0: 40188AE0 50C644A0 50C64334 80000048        1 44078710        0        0
50C64410:        0 DEADFEED 50C64470 448DBA40 44E8D488 50C64360 50C64418 43FB3620
50C64430:      152    90000        2        0 44E35F98 4019C738 40DBEBEC        0
50C64450:        0        0        0        0        0        0        0        0
50C64470: 448DBA40        0 50C64460 50C64418        0 43FB6490        0  FFFFFFF
========= Process Level Info ===================================================
---- Current Process Block (at 0x44E8CFD0) ----
44E8CFA0: AB1234CD       3E 44E8CFD0 40A426B8 4019D268 44E8D200 44E8CF64 80000118
44E8CFC0:        1 440787A0 9CAF58D8 B3211E2F 50C62A28 8001FC28 406A73D8        0
44E8CFE0:        0        0        0        0        0        0        0        0
44E8D000:        0 50C64170        0 4017E148        0        0        0        0
44E8D020:    10000  1000000        0        0       3E        0        0        0
44E8D040:      320        0     1DE8        0        0        0        0      EE0
44E8D060:        0        0        0      EE8        0      EE8        0        1
44E8D080:        0 40C655B8        3       AB        0        0        0     1770
44E8D0A0:     1770 500047C8        0        0        0        0        0        0
44E8D0C0: 44E13A24 44E8CFD0 43FB56A0        0        0        0 434B86F0        0
44E8D0E0:        0        0     420A        0        0        0 44E8D0D0        0
44E8D100:        0        0     4290 44E8CFD0        0        0        0        0
44E8D120: 44E8D0D0 44E8CFD0        0        0    142D2        0        0        0
44E8D140: 44E8D0D0 44E8CFD0        0        0    242D2        0        0        0
44E8D160:        0        0        0 50C641D0        0        0        0        0
44E8D180:        0        0        0        0        0 50C64230 44E8D180 50C641D8
44E8D1A0:        0 43FB60A0        0        0        0        0        0  FFFFFFF
44E8D1C0:  FFFFFFF        0        0        0        0        0        0        0
44E8D1E0:        0 44E8D230        0        0        0 BEEFCAFE
---- Partial decode of process block ----
Pid 62: Process "PF_Init Process" stack 0x50C62A28 savedsp 0x8001FC28
Flags: analyze prefers_new
Status     0x00000000 Orig_ra   0x00000000 Routine    0x00000000 Signal 0
Caller_pc  0x00000000 Callee_pc 0x00000000 Dbg_events 0x00000000 State  0
Totmalloc  800        Totfree   0          Totgetbuf  0
Totretbuf  0          Edisms    0x0        Eparm 0x0
Elapsed    0x0        Ncalls    0x1        Ngiveups 0x0
Priority_q 3          Ticks_5s  171        Cpu_5sec   0        Cpu_1min 0
Cpu_5min   0          Stacksize 0x1770     Lowstack 0x1770
Ttyptr     0x500047C8 Mem_holding 0x1DE8     Thrash_count 0
Wakeup_reasons      0x0FFFFFFF  Default_wakeup_reasons 0x0FFFFFFF
Direct_wakeup_major 0x00000000  Direct_wakeup_minor 0x00000000
Regs s0-s8,ra at last suspend; a0,a1,sp from proc creation, PC unused:
     a0: 406A73D8  a1: 00000000  s0: 00000000  s1: 00000000  s2: 00000000
     s3: 00000000  s4: 00000000  s5: 00000000  s6: 00000000  s7: 00000000
     s8: 00000000  sp: 50C64170  PC: 00000000  ra: 4017E148
---- Current Process Stack (0x890 bytes used, out of 0x1770 available) ----
Current SP = 0x50C64090, saved SP = 0x8001FC28
50C63D98: 50C63DE8 50C63DE8        0 400E79A0 50C63E9C        0        0 FFFFFFFF
50C63DB8: 400E91B4 400E90F8 FFFFFFFF FFFFFFFF 40A158A8 50C63DE8      7DD BFC170E4
50C63DD8:      7DC BFC169D0       16 BFC169D0 F0303A30 303A3034        2 BFC16BBC
50C63DF8:        0 BFC16D08 A0003C90 50C64030 BE000000 50C64030        0 BFC16FEC
50C63E18: BE000000 50C64030        0       2D BE000000 BFC17084        0       2D
50C63E38: 50C64000 50C63ED0 BFC15AA8 BFC15A98        0 40C69B5C 34018003 50C63EB0
50C63E58: BFC22DE4 44860000 40C70000        0 BFC18168 FFFFFFFF 34018003 50C63ED0
50C63E78:       1B BFC170E4 40C70000        0 BFC18168 40E60000 F0C184D0 4025AF9C
50C63E98:        7 50C63EF0 BFC171C0        0 50C63ED0        3 BFC184D0        0
50C63EB8:        0 434A0000        0        0        0       30 40DB0000 BFC16D8C
50C63ED8:        0 434A0000        0       C9     FFFF BADBEEF0 BFC22BA8       2D
50C63EF8:        0 50C64030        0        0 34018003 50C63F68 40E60000 44860000
50C63F18: 40C70000        0 BFC18168        0 FFFFFFFF FFFF00FF        0 40198408
50C63F38: 40DB0000 6F6E736F   C63F68        3        A 4025AF9C        0        0
50C63F58:        0        3 4025B024 BFC121F0        0        0        0 434A0000
50C63F78:        0        0        A 4025AF9C        0       30        0        0
50C63F98: 400E9F80        0        0 40DB0000        0       20 FFFFFFFE 400E7BFC
50C63FB8:        0 3401C100 FFFFFFFF FFFF00FF        0 40198408        0        0
50C63FD8:        0     2045        0 50C64078        0 40E60000        0        3
50C63FF8:        0 40E60000        0 44860000        0        0        0 FFFFFFFF
50C64018: FFFFFFFF       20        0        1        0        0        0        0
50C64038:        0 30419001        0 30410000 FFFFFFFE        0 40E60000 40DC0000
50C64058: 40C70000        0 40C70000 43FB0000        0 400EA208 403179C0 4030A1AC
50C64078: 40A42798      2FC        0        0 40DB0000 401A21F0        0 40A4277C
50C64098:        0 40DB0000 40E60000        3 40E60000 44860000 406AEFAC 406AEF8C
50C640B8:        0 40C69D9C        0        A 44860000        0 43F00000 406B00A8
50C640D8:        0        0 406B174C FFFFFFFF 44860000 406B1AE4 FFFFFFFF FFFFFFFF
50C640F8: FFFFFFFF FFFFFFFF 44860000        0        0        0        0        0
50C64118:        0        0 406A7BA8 FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF
50C64138: 406A7410 FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF        0 4017E15C
50C64158: FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF 4017E148 FFFFFFFF FFFFFFFF FFFFFFFF
50C64178: FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF
========= Interrupt Level Stack Dump ===========================================
WARNING: Interrupt stack dumps are consistent ONLY for interrupts which
are blocked during exception handling.  Also register output is valid
ONLY for interrupts which store an r4k_context block on the stack.
---- Level 1 Interrupt stack (0x0 bytes used, out of 0x0 available) ----
intstacks[1]: base 0x448C9BA0 stack 0x0      routine 0xFFFFFFFF count 0xFFFFFFFF
              size 0x20       low   0x0        desc    0x448CBEC0
---- Level 2 Interrupt stack (0x0 bytes used, out of 0x0 available) ----
intstacks[2]: base 0x448CBF00 stack 0x0      routine 0xFFFFFFFF count 0xFFFFFFFF
              size 0x20       low   0x0        desc    0x448CE220
---- Level 3 Interrupt stack (0x180 bytes used, out of 0x0 available) ----
intstacks[3]: base 0x448CE260 stack 0x0      routine 0xFFFFFFFF count 0xFFFFFFFF
              size 0x20       low   0x0        desc    0x448D0580
448D0408: 1002009F 100200A7 40DD30E8 4025A024 FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF
448D0428:        0        4       76        3 40E60000 50C640C0 40C70000 40197FF0
448D0448: FFFFFFFF FFFFFFFF        0 434A0000        0 10060100        0        0
448D0468:        0        0        0     FD00        0 43F90000        0 40DB0000
448D0488:        0       20        0 3401FD01        0 3401C100 FFFFFFFF FFFF00FF
448D04A8:        0 40198408        0        0        0     2045        0 50C64078
448D04C8: FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF
448D04E8: FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF
448D0508:        0        0        0        0        0 30419001        0 30410000
448D0528: FFFFFFFF FFFFFFFF        0 50C63F90 FFFFFFFF FFFFFFFF        0 4025B0CC
448D0548: 3401FD03 FFFFFFFF        0       BF        0      2FC FFFFFFFF FFFFFFFF
448D0568: FFFFFFFF FFFFFFFF        0 401967CC FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF
    $0 : FFFFFFFF, AT : 434A0000, v0 : 10060100, v1 : 00000000
    a0 : 00000000, a1 : 0000FD00, a2 : 43F90000, a3 : 40DB0000
    t0 : 00000020, t1 : 3401FD01, t2 : 3401C100, t3 : FFFF00FF
    s0 : FFFFFFFF, s1 : FFFFFFFF, s2 : FFFFFFFF, s3 : FFFFFFFF
    s4 : FFFFFFFF, s5 : FFFFFFFF, s6 : FFFFFFFF, s7 : FFFFFFFF
    gp : FFFFFFFF, sp : 50C63F90, s8 : FFFFFFFF, ra : 4025B0CC
    EPC  : 401967CC, ErrorEPC : FFFFFFFF, SREG     : 3401FD03
    MDLO : 000000BF, MDHI     : 000002FC, BadVaddr : FFFFFFFF
---- Level 4 Interrupt stack (0x168 bytes used, out of 0x0 available) ----
intstacks[4]: base 0x448D3128 stack 0x0      routine 0xFFFFFFFF count 0xFFFFFFFF
              size 0x20       low   0x0        desc    0x448D5448
448D52E8: 40E60000        3 40E60000 44860000 40C70000        0 40C70000 43FB0000
448D5308:        0 4019819C FFFFFFFF FFFFFFFF        0 434A0000        0        0
448D5328:        0       47        0       30        0        0        0        0
448D5348:        0 40DB0000        0       20        0 3401FD01        0 3401C100
448D5368: FFFFFFFF FFFF00FF        0 40198408        0        0        0     2045
448D5388:        0 50C64078 FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF
448D53A8: FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF
448D53C8: FFFFFFFF FFFFFFFF        0        0        0        0        0 30419001
448D53E8:        0 30410000 FFFFFFFF FFFFFFFF        0 50C640A0 FFFFFFFF FFFFFFFF
448D5408:        0 40192200 3401FD03 FFFFFFFF        0       BF        0      2FC
448D5428: FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF        0 4019844C FFFFFFFF FFFFFFFF
448D5448: FFFFFFFF FFFFFFFF
    $0 : FFFFFFFF, AT : 434A0000, v0 : 00000000, v1 : 00000047
    a0 : 00000030, a1 : 00000000, a2 : 00000000, a3 : 40DB0000
    gp : FFFFFFFF, sp : 50C640A0, s8 : FFFFFFFF, ra : 40192200
    EPC  : 4019844C, ErrorEPC : FFFFFFFF, SREG     : 3401FD03
---- Level 5 Interrupt stack (0x0 bytes used, out of 0x0 available) ----
intstacks[5]: base 0x448D05C0 stack 0x0      routine 0xFFFFFFFF count 0xFFFFFFFF
              size 0x20       low   0x0        desc    0x448D28E0
---- Level 6 Interrupt stack (base 0x0, size 0x0) is invalid ----
---- Level 7 Interrupt stack (0x1A0 bytes used, out of 0x0 available) ----
intstacks[7]: base 0x448C7840 stack 0x0      routine 0xFFFFFFFF count 0xFFFFFFFF
              size 0x20       low   0x0        desc    0x448C9B60
448C99C8:        0      EE8       61        0 4016C6B8 FFFFFFFF FFFFFFFF FFFFFFFF
448C99E8:        0 50C64030 401979CC 4019793C FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF
448C9A08: 40196908       38 40197664 FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF
448C9A28: FFFFFFFF FFFFFFFF        0 434A0000        0    192C6        0 2ED2A21C
448C9A48:        0        0        0        0        0        8        0    F4240
448C9A68:        0        4        0      708        0        1        0 40A42930
448C9A88:        0 40A4292C        0 40DC2858        0 40DC2854        0 40DC2850
448C9AA8: FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF
448C9AC8: FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF
448C9AE8:        0 40DC2684        0        0        0 43FB3820        0        0
448C9B08: FFFFFFFF FFFFFFFF        0 40DC25D0 FFFFFFFF FFFFFFFF        0 401974C8
448C9B28: 34018003 FFFFFFFF        0    1E848        0        0 FFFFFFFF FFFFFFFF
448C9B48: FFFFFFFF FFFFFFFF        0 40197664 FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF
    $0 : FFFFFFFF, AT : 434A0000, v0 : 00000000, v1 : 00000000
    a0 : 4407BDD0, a1 : BAC9E3C4, a2 : 40DC25F8, a3 : 00000004
    t0 : 00000001, t1 : 40DC25F8, t2 : 40DC25F8, t3 : FFFF00FF
    t4 : 40198408, t5 : 40DC2858, t6 : 40DC2854, t7 : 40DC2850
    t8 : 40DC2684, t9 : 00000000, k0 : 43FB3820, k1 : 00000000
    gp : FFFFFFFF, sp : 40DC27A0, s8 : FFFFFFFF, ra : 400E7BFC
    EPC  : 400E7E2C, ErrorEPC : FFFFFFFF, SREG     : 34018003
    MDLO : 00000000, MDHI     : 00000004, BadVaddr : FFFFFFFF
---- Level 8 Interrupt stack (base 0x0, size 0x0) is invalid ----
---- Level 9 Interrupt stack (base 0x0, size 0x0) is invalid ----
========= Register Memory Dump =================================================
Reg00($0):        0 [Not RAM Addr]
Reg01(AT): 434A0000
Reg02(v0): 43FB0000
Reg03(v1): 40DE0000
Reg04(a0): 50BB64D8 [In malloc Block 0x50BB6380] [Last malloc Block 0x50BB62C0]
Reg05(a1): 434AC1A8
Reg06(a2):        0 [Not RAM Addr]
Reg07(a3): 40DB0000
Reg08(t0): 40198408
Reg09(t1): 3401FD01 [Not RAM Addr]
Reg10(t2): 40198408
Reg11(t3): FFFF00FF [Not RAM Addr]
Reg12(t4): 40198408
Reg13(t5):        0 [Not RAM Addr]
Reg14(t6):     2045 [Not RAM Addr]
Reg15(t7): 50C64078
Reg16(s0):        0 [Not RAM Addr]
Reg17(s1):        0 [Not RAM Addr]
Reg18(s2): 40DB0000
Reg19(s3): 40DC0000
Reg20(s4): 40C70000
Reg21(s5):        0 [Not RAM Addr]
Reg22(s6): 40C70000
Reg23(s7): 43FB0000
Reg24(t8):        0 [Not RAM Addr]
Reg25(t9):        0 [Not RAM Addr]
Reg26(k0): 30419001 [Not RAM Addr]
Reg27(k1): 30410000 [Not RAM Addr]
Reg28(gp): 434AC9E4
Reg29(sp): 50C64090
Reg30(s8):        0 [Not RAM Addr]
Reg31(ra): 401A223C
buffer check=0 sched_hc=0x0
---- block0  ptr=50C64030  is_malloc=0  length=0x260 ----
---- block1  ptr=434A0000  is_malloc=0  length=0x100 ----
4349FFC0: F0744B18 8811F495 77100001 F4A9F830 54407600 1000F274 5BE9F020  2C07605
4349FFE0:     F073 54477104   117181   1168E1   81FEFF 76000000 71040011 1081F074
434A0000: 5518F073 54FB7600    17104   111081 F0745518 18058005 60050001 F83054FB
434A0020: 76001000 F2745BE9 F02002E5 76050000 F07354FB 76000000 71040011 1081F074
434A0040: 55181805 80056005    1F830 54FB7600 1000F274 5BE9F020  30B7605     F073
434A0060: 54FB1006 80007104   111081 F0744B18 8811F495 F4956CE1 FFFF549B 76000003
434A0080: 76010002 71040011 1081F074 48AE8811 F4957710    1F4A9 F83054A3 76001000
434A00A0: F2745BE9 F0200331 76050000 76000000 71040011 1081F074 55187104   117181
434A00C0:   1168E1   81EEFF F07354FB 71040011 F7B871E1    10011 10F80011 F0100006
434A00E0: F84654E7 10F80011 F0100006 F845547E 10F80011 F0100003 F84654DB 10F80011
---- block2  ptr=43FB0000  is_malloc=0  length=0x100 ----
43FAFFC0:        0        0        0        0        0        0        0        0
43FAFFE0:        0        0        0        0        0        0        0        0
43FB0000:        0        0        0        0        0        0        0        0
43FB0020:        0        0        0        0        0        0        0        0
43FB0040:        0        0        0        0        0        0        0        0
43FB0060:        0        0        0        0        0        0        0        0
43FB0080:        0        0        0        0        0        0        0        0
43FB00A0:        0        0        0        0        0        0        0        0
43FB00C0:        0        0        0        0        0        0        0        0
43FB00E0:        0        0        0        0        0        0        0        0
---- block3  ptr=40DDFF8C  is_malloc=0  length=0x174 ----
40DDFF4C: 4035BA70 40DE1750   320000 4035BB24        0 3FFD0000 403512C8        0
40DDFF6C:        0        0 40DE1750 3FFF0000 40354264        0        0        0
40DDFF8C:        0 3FFE0000 4035155C 40DE1660    50000 40357800 40DE1660    A0000
40DDFFAC: 40357800 40DE1660   180000 4035826C 40DE1798   1A0000 40359EF0 40DE1780
40DDFFCC:   240000 4035E68C 40DE1780   250000 4035E9AC 40DE1990   400000 403572AC
40DDFFEC: 40DE1780   290000 40359880 40DE1780   2A0000 40359818 40DE1780   2B0000
40DE000C: 40359958 40DE1780   2C0000 40359AB0 40DE1780   2D0000 40359B28 40DE1780
40DE002C:   2E0000 40359BA0 40DE1780   350000 4035BBD8 40DE1780   360000 4035ACB0
40DE004C: 40DE1780   2F0000 40359C18 40DE1780   300000 40359C90 40DE1780   310000
40DE006C: 403582E0 40DE1798   370000 403583A8 40DE1660   3A0000 40358344 40DE1660
40DE008C:   380000 4035840C 40DE1660   430000 40357800 40DE1660   440000 40357800
40DE00AC: 40DE1660   470000 40357800 40DE1660   3B0000 40357AC0 40DE1780   330000
40DE00CC: 4035B9BC 40DE1780   340000 4035BA70 40DE1780   320000 4035BB24        0
40DE00EC: 3FFD0000 403515D8        0        0        0
---- block4  ptr=50BB6290  is_malloc=1  length=0x410 ----
50BB6250: FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF        0        0        0        0
50BB6270:        0 4017E15C FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF 4017E148 FFFFFFFF
50BB6290: FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF
50BB62B0: FFFFFFFF FFFFFFFF FD0110DF 10DFFD01 AB1234CD       2D 44E35FE8 40A426D0
50BB62D0: 40188AE0 50BB6380 50BB4B2C 80000048        1 44078710        0        0
50BB62F0:        0 DEADFEED 50BB6350 44E361A8 50007FC0 50BB4A10 50BB62F8 43FB3620
50BB6310:      11E    90000        2        0 44E35F98 4019C738 40DBEBEC        0
50BB6330:        0        0        0        0        0        0        0        0
50BB6350: 44E361A8        0 50BB6340 50BB62F8        0 43FB6490        0  FFFFFFF
50BB6370:  FFFFFFF        0 FD0110DF 10DFFD01 AB1234CD FFFFFFFE        0 5000E864
50BB6390: 4017F074 50BB66A0 50BB62D4 80000178        1 44078710        0        0
50BB63B0:        0 50BADA70 50C4B1C0        0 5000E828       1A       20    C0010
50BB63D0:        0        0        0        0       10    30000 440799B0 52656720
50BB63F0: 46756E63 74696F6E 20310000 50BB6488 50BB6688        0 50BB6488 50BB6498
50BB6410: 50BB64A8 50BB64B8 50BB64C8 50BB64D8 50BB64E8 50BB64F8 50BB6508 50BB6518
50BB6430: 50BB6528 50BB6538 50BB6548 50BB6558 50BB6568 50BB6578 50BB6588 50BB6598
50BB6450: 50BB65A8 50BB65B8 50BB65C8 50BB65D8 50BB65E8 50BB65F8 50BB6608 50BB6618
50BB6470: 50BB6628 50BB6638 50BB6648 50BB6658 50BB6668 50BB6678 50C4B358        0
50BB6490: 4030D9C8        0        0       4D 40306EE8        0 50C4B2B8        0
50BB64B0: 40306600        0 50BB6498       4C 40306244        0 50C4B848        0
50BB64D0: 4030A180        0 50BB64C8        0        0        0 50C75E48       17
50BB64F0: 403098D8        0        0        0 40304EDC        0        0        0
50BB6510: 40304E54        0        0        0 40304D9C        0 44D23880       45
50BB6530: 40302DF8        0 50C5CB50        0 40302BA8        0 50C4B6B8        0
50BB6550: 40301674        0 50C4B6C8        0 40301650        0 50BB64A8        0
50BB6570: 402FE4A8        0        0        0 40308F2C        0        0        0
50BB6590: 40308DF4        0 50BB6588        0        0        0 44E80840        0
50BB65B0: 40307D88        0        0        0 40307604        0        0        0
50BB65D0: 40307540        0        0        0 402FEA5C        0 50BB65D8        0
50BB65F0:        0        0        0        0 403076B0        0        0        0
50BB6610: 40307900        0 50B93150        0 402FFF78        0        0        0
50BB6630: 402988D4        0        0        0 402988AC        0 50BB6638        0
50BB6650:        0        0        0        0 402987F0        0 50BB6658        0
50BB6670:        0        0 50C75DE8       2E 409489CC        0        0        0
50BB6690:        0        0 FD0110DF 10DFFD01
---- block5  ptr=50BB62C0  is_malloc=1  length=0x100 ----
50BB6280: FFFFFFFF FFFFFFFF 4017E148 FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF
50BB62A0: FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FD0110DF 10DFFD01
50BB62C0: AB1234CD       2D 44E35FE8 40A426D0 40188AE0 50BB6380 50BB4B2C 80000048
50BB62E0:        1 44078710        0        0        0 DEADFEED 50BB6350 44E361A8
50BB6300: 50007FC0 50BB4A10 50BB62F8 43FB3620      11E    90000        2        0
50BB6320: 44E35F98 4019C738 40DBEBEC        0        0        0        0        0
50BB6340:        0        0        0        0 44E361A8        0 50BB6340 50BB62F8
50BB6360:        0 43FB6490        0  FFFFFFF  FFFFFFF        0 FD0110DF 10DFFD01
50BB6380: AB1234CD FFFFFFFE        0 5000E864 4017F074 50BB66A0 50BB62D4 80000178
50BB63A0:        1 44078710        0        0        0 50BADA70 50C4B1C0        0
---- block6  ptr=434AC1A8  is_malloc=0  length=0x100 ----
434AC168:        0        0 502457D0        0        0        0        0        0
434AC188:        0        0        0        0        0 4017EA00        0        0
434AC1A8: 434AB758 40A0EB68        0 5000EAF8 5000EAD8        0        0        0
434AC1C8:        0        0        0        0        0        0        0        0
434AC1E8:        0        0        0        0 50BB64D8        0        0        0
434AC208:        0 44B56ED8        0 44E80810 5000ED68        0        0        0
434AC228:        0        0 5000ED88        0        0        0        0 4017EA00
434AC248:        0 4017EA08 4017EA08 4017EA08 4017EA08 4017EA08 4017EA08 4017EA08
434AC268: 4017EA08 4017EA08 4017EA08 4017EA08 4017EA08 4017EA08 4017EA08 4017EA08
434AC288: 4017EA00 4017EA00 4017EA00 4017EA00 4017EA00 4017EA00 4017EA00 4017EA00
---- block7  ptr=40DAFFE4  is_malloc=0  length=0x11C ----
40DAFFA4: FF000000        0 40DAFF20 40DAFF90 400F25F0 40A0C208        0 FF000000
40DAFFC4:        0 40DAFF20 40DAFFAC 400F25F0 40A0C21C        0 FF000000        0
40DAFFE4: 40DAFF20 40DAFFC8 400F25F0 40A0C230        0        0        0 400F5564
40DB0004: 40A0C268        0 40DAFFF8 40D9EEC4 400F5870 40A0C270        0 FF000000
40DB0024:        0 40DB000C 40DAFFF8 400F25F0 40A0C2C8        0 FF000000        0
40DB0044: 40DB000C 40D9EEC4 400F25F0 40A0C320        0 FF000000        0 40DB0028
40DB0064: 40DB0044 400F25F0 40A0C334        0 40DB0060 40DAFFF8 400F839C        0
40DB0084:        0 40DB0074        0 400F8248 40A0C390        0 FF000000        0
40DB00A4: 40DB0088 40DAFFE4 400F244C 40A0C398        0        0        0 400F5564
40DB00C4: 40A0C3D0        0 FF000000        0 40DB00B8 40DB00A4 400F244C 40A0C3D8
40DB00E4:        0        0        0 400F5564 40A0C430        0 FF000000
---- block8  ptr=40198408  is_malloc=0  length=0x100 ----
401983C8: AC2C4B14 DFAC0060 DFAD0068 DFAE0070 DFAF0078 DFB800C0 DFB900C8 DFBF00F8
401983E8: DFBB00D8 DFBA00D0 DFA10008 DFBD00E8        F 42000018        0        0
40198408:     FD00 FF000000     F900 FF000000     F100 FF000000     E100 FF000000
40198428:     C100 FF000000     8100 FF000000     8100 FF000000     8000 FF000000
40198448:        C        0  3E00008        0  3E00008     1021 2CA50001 2C820021
40198468: 38420001  3E00008   A21025 2402FFFF AC820008 24020001 AC850000  3E00008
40198488: AC860004  3E00008   801021 27BDFFE8 AFBF0010  C05D954        0 8FBF0010
401984A8:  3E00008 27BD0018 27BDFFE0 AFB20018   C09021    51600 AFBF001C AFB10014
401984C8: AFB00010 8E450000  C05C23C    28E03   408021   10102B   11182B   431024
401984E8: 10400004  2002021 8E460000  C2702F1  2202821  2001021 8FBF001C 8FB20018
---- block9  ptr=40DC0000  is_malloc=0  length=0x100 ----
40DBFFC0: 715F7763 68675F6F 6E657368 6F740000        0        0 7472625F 70726F63
40DBFFE0: 715F6E6F 6368675F 6B696C6C 72657100        0        0 7472625F 63726561
40DC0000: 74650000        0        0        0        0        0 7472625F 70726F63
40DC0020: 715F6265 666F7265 5F636266        0        0        0 7472625F 70726F63
40DC0040: 715F6166 7465725F 63626600        0        0        0 7472625F 6362665F
40DC0060: 696E666F 5F77686C 31000000        0        0        0 7472625F 6362665F
40DC0080: 696E666F 5F77686C 32000000        0        0        0 7472625F 6362665F
40DC00A0: 696E666F 5F77686C 33000000        0        0        0 7472625F 6362665F
40DC00C0: 696E666F 5F656E64 72656D00        0        0        0 7472625F 66726565
40DC00E0: 72657100        0        0        0        0        0 7472625F 73636865
---- block10  ptr=40C70000  is_malloc=0  length=0x100 ----
40C6FFC0: 43484F56 45520000 46494E44 4D415354 45520000 5245494E 49545F43 4F4D504C
40C6FFE0: 45544500 52454455 4E5F4D4F 44450000 4950435F 5245494E 49545F43 4F4D504C
40C70000: 45544500 534C4350 20666169 6C656420 746F2067 6F206F6E 6C696E65        0
40C70020: 53757065 72766973 6F72206F 6E6C696E 65206469 61672066 61696C75 72650000
40C70040: 52502066 61696C65 6420746F 20626F6F 74000000 57616974 696E6720 666F7220
40C70060: 7265706C 7920746F 20495043 2046696E 644D6173 74657200 57616974 696E6720
40C70080: 666F7220 7265706C 7920746F 20537461 6E646279 20526561 64790000 4E6F6E65
40C700A0:        0 4F544845 52000000 554E4B4E 4F574E00 41435449 56450000 5354414E
40C700C0: 44425900 52505200 5250522D 504C5553        0 53534F00 50465F52 4544554E
40C700E0: 5F53505F 53574F56 45525F42 4547494E 5F544852        0 50465F52 4544554E
---- block11  ptr=434AC9E4  is_malloc=0  length=0x100 ----
434AC9A4:        0        0        0        0        0        0        0        0
434AC9C4:        0        0        0        0        0        0        0        0
434AC9E4:        0        0        0        0        0        0        0        0
434ACA04:        0        0        0        0        0        0        0        0
434ACA24:        0        0        0        0        0        0        0        0
434ACA44:        0        0        0        0        0        0        0        0
434ACA64:        0        0        0        0        0        0        0        0
434ACA84:        0        0        0        0        0        0        0        0
434ACAA4:        0        0        0        0        0        0        0        0
434ACAC4:        0        0        0        0        0        0        0        0
---- block12  ptr=401A223C  is_malloc=0  length=0x100 ----
401A21FC: 1460000D 2404FFFE 3C0540A4  C03A86A 24A52798 2A230004 50600001 24110003
401A221C:   112140   912023    42080   912021  C061CE4    420C0  C069132        0
401A223C: AE6033BC 8FBF0020 8FB3001C 8FB20018 8FB10014 8FB00010  3E00008 27BD0028
401A225C:   803821 80E20000  80688AA     4021    21603 2842003A 10400006    84100
401A227C:   E01021 80430000 24E70001  80688A8 2502FFD0   E01021 80430000 24E70001
401A229C: 2502FFA9   434021 80E20000 10400008 90E90000 2443FF9F 2C630006 2442FFD0
401A22BC: 2C42000A   621825 1460FFE9    91600 10E40004 24020001 ACC80000  3E00008
401A22DC: ACA70000  3E00008     1021 27BDFFE0   A03021 AFBF0018  C068897 27A50010
401A22FC: 8FBF0018  3E00008 27BD0020 27BDFFD0 AFB20028   A09021 AFB00020 27B00010
401A231C:  2002821 AFB10024   C08821 AFBF002C  C068897 27A60014 1040000D 8FA20010
---- block13  ptr=40E60000  is_malloc=0  length=0x100 ----
40E5FFC0: 400F244C 40C784D4        0 40E5FFB8 40D9EED8 400F2404        0        0
40E5FFE0: C15C0515 C15C0515        1        C        2 40C78550        1        0
40E60000:        0 406C9CF4    50000      1A4        0        0        0        0
40E60020: 400F55D0 406CA4A8        0 FF100000        0 40E60018 40D9EEB0 400F244C
40E60040: 40C78DF0        0 40E60034 40D9EED8 400F2404        0        0        0
40E60060:        0 400F55D0 406CA4C4        0 FF100000        0 40E6005C 40D9EEB0
40E60080: 400F244C 40C78E14        0 40E60078 40D9EED8 400F2404        0        0
40E600A0: C15C0515 C15C0515        1        C        2 40C78E0C        1        0
40E600C0:        1 406CA548    50000      1A5 434A4F78        2 42494E00        3
40E600E0: 48455800        4 524C4300        5 41434100        0        0        0
---- block14  ptr=44860000  is_malloc=0  length=0x100 ----
4485FFC0:        0        0        0        0        0        0        0        0
4485FFE0:        0        0        0        0        0        0        0        0
44860000:        0        0        0        0        0        0        0        0
44860020:        0        0        0        0        0        0        0        0
44860040:        0        0        0        0        0        0        0        0
44860060:        0        0        0        0        0        0        0        0
44860080:        0        0        0        0        0        0        0        0
448600A0:        0        0        0        0        0        0        0        0
448600C0:        0        0        0        0        0        0        0        0
448600E0:        0        0        0        0        0        0        0        0
---- block15  ptr=43F00000  is_malloc=0  length=0x100 ----
43EFFFC0:        0        0        0        0        0        0        0        0
43EFFFE0:        0        0        0        0        0        0        0        0
43F00000:        0        0        0        0        0        0        0        0
43F00020:        0        0        0        0        0        0        0        0
43F00040:        0        0        0        0        0        0        0        0
43F00060:        0        0        0        0        0        0        0        0
43F00080:        0        0        0        0        0        0        0        0
43F000A0:        0        0        0        0        0        0        0        0
43F000C0:        0        0        0        0        0        0        0        0
43F000E0:        0        0        0        0        0        0        0        0
---- block16  ptr=AB1234CC  is_malloc=0  length=0x100 ----
AB12348C:        0        0        0        0        0        0        0        0
AB1234AC:        0        0        0        0        0        0        0        0
AB1234CC:        0        0        0        0        0        0        0        0
AB1234EC:        0        0        0        0        0        0        0        0
AB12350C:        0        0        0        0        0        0        0        0
AB12352C:        0        0        0        0        0        0        0        0
AB12354C:        0        0        0        0        0        0        0        0
AB12356C:        0        0        0        0        0        0        0        0
AB12358C:        0        0        0        0        0        0        0        0
AB1235AC:        0        0        0        0        0        0        0        0
---- block17  ptr=44E8CF50  is_malloc=1  length=0x2B0 ----
44E8CF10:  FFFFFFF        0        0        0        0        0        0        0
44E8CF30:        0 44E8CF80        0        0        0 BEEFCAFE FD0110DF 10DFFD01
44E8CF50: AB1234CD FFFFFFFE        0 40A14BFC 409C0174 44E8CFA0 44E8CD04 80000010
44E8CF70:        1 440787A0 F9D07AC8 A2F6100F 50C61170        0        0        0
44E8CF90:        0        0 FD0110DF 10DFFD01 AB1234CD       3E 44E8CFD0 40A426B8
44E8CFB0: 4019D268 44E8D200 44E8CF64 80000118        1 440787A0 9CAF58D8 B3211E2F
44E8CFD0: 50C62A28 8001FC28 406A73D8        0        0        0        0        0
44E8CFF0:        0        0        0        0        0 50C64170        0 4017E148
44E8D010:        0        0        0        0    10000  1000000        0        0
44E8D030:       3E        0        0        0      320        0     1DE8        0
44E8D050:        0        0        0      EE0        0        0        0      EE8
44E8D070:        0      EE8        0        1        0 40C655B8        3       AB
44E8D090:        0        0        0     1770     1770 500047C8        0        0
44E8D0B0:        0        0        0        0 44E13A24 44E8CFD0 43FB56A0        0
44E8D0D0:        0        0 434B86F0        0        0        0     420A        0
44E8D0F0:        0        0 44E8D0D0        0        0        0     4290 44E8CFD0
44E8D110:        0        0        0        0 44E8D0D0 44E8CFD0        0        0
44E8D130:    142D2        0        0        0 44E8D0D0 44E8CFD0        0        0
44E8D150:    242D2        0        0        0        0        0        0 50C641D0
44E8D170:        0        0        0        0        0        0        0        0
44E8D190:        0 50C64230 44E8D180 50C641D8        0 43FB60A0        0        0
44E8D1B0:        0        0        0  FFFFFFF  FFFFFFF        0        0        0
44E8D1D0:        0        0        0        0        0 44E8D230        0        0
44E8D1F0:        0 BEEFCAFE FD0110DF 10DFFD01
---- block18  ptr=5518F070  is_malloc=0  length=0x100 ----
5518F030:        0        0        0        0        0        0        0        0
5518F050:        0        0        0        0        0        0        0        0
5518F070:        0        0        0        0        0        0        0        0
5518F090:        0        0        0        0        0        0        0        0
5518F0B0:        0        0        0        0        0        0        0        0
5518F0D0:        0        0        0        0        0        0        0        0
5518F0F0:        0        0        0        0        0        0        0        0
5518F110:        0        0        0        0        0        0        0        0
5518F130:        0        0        0        0        0        0        0        0
5518F150:        0        0        0        0        0        0        0        0
---- block19  ptr=54FB7600  is_malloc=0  length=0x100 ----
54FB75C0:        0        0        0        0        0        0        0        0
54FB75E0:        0        0        0        0        0        0        0        0
54FB7600:        0        0        0        0        0        0        0        0
54FB7620:        0        0        0        0        0        0        0        0
54FB7640:        0        0        0        0        0        0        0        0
54FB7660:        0        0        0        0        0        0        0        0
54FB7680:        0        0        0        0        0        0        0        0
54FB76A0:        0        0        0        0        0        0        0        0
54FB76C0:        0        0        0        0        0        0        0        0
54FB76E0:        0        0        0        0        0        0        0        0
---- block20  ptr=55181804  is_malloc=0  length=0x100 ----
551817C4:        0        0        0        0        0        0        0        0
551817E4:        0        0        0        0        0        0        0        0
55181804:        0        0        0        0        0        0        0        0
55181824:        0        0        0        0        0        0        0        0
55181844:        0        0        0        0        0        0        0        0
55181864:        0        0        0        0        0        0        0        0
55181884:        0        0        0        0        0        0        0        0
551818A4:        0        0        0        0        0        0        0        0
551818C4:        0        0        0        0        0        0        0        0
551818E4:        0        0        0        0        0        0        0        0
---- block21  ptr=80056004  is_malloc=0  length=0x100 ----
80055FC4:  3E00008 2442FE78 3C02409E  3E00008 2442FE88 3C02409E  3E00008 2442FE9C
80055FE4: 3C02409E  3E00008 2442FEA0 3C02409E  3E00008 2442FEA8 3C02409E  3E00008
80056004: 2442FEB8 3C02409E  3E00008 2442FEC0 3C02409E  3E00008 2442FECC 3C02409E
80056024:  3E00008 2442FEDC 3C02409E  3E00008 2442FEEC 3C02409E  3E00008 2442FF04
80056044: 27BDFFD0 AFB60028   80B021 3C04409E 2484FF4C AFBF002C AFB50024 AFB40020
80056064: AFB3001C AFB20018 AFB10014  C03A7E8 AFB00010  C03A8DF     2021 3C15409E
80056084: 24140001 3C1340DB 3C0240DA 24429E84 24510020 241201BC  C0157D8 8E240004
800560A4: 8E250000 8E260008 26A4FF64  C03A7E8   403821 56D40009 2652FFFF 8E6558DC
800560C4: 24040004 8E300000  C05FC86 24A50014   40F809  2002021 2652FFFF  641FFEE
800560E4: 2631001C  C03A923        0 8FBF002C 8FB60028 8FB50024 8FB40020 8FB3001C
---- block22  ptr=5BE9F020  is_malloc=0  length=0x100 ----
5BE9EFE0:        0        0        0        0        0        0        0        0
5BE9F000:        0        0        0        0        0        0        0        0
5BE9F020:        0        0        0        0        0        0        0        0
5BE9F040:        0        0        0        0        0        0        0        0
5BE9F060:        0        0        0        0        0        0        0        0
5BE9F080:        0        0        0        0        0        0        0        0
5BE9F0A0:        0        0        0        0        0        0        0        0
5BE9F0C0:        0        0        0        0        0        0        0        0
5BE9F0E0:        0        0        0        0        0        0        0        0
5BE9F100:        0        0        0        0        0        0        0        0
---- block23  ptr=40DE1780  is_malloc=0  length=0x100 ----
40DE1740:        0        0        0        0 40AE2BE0 40DDFDAC        6        0
40DE1760:        0        0 40AE2BE8 40DDFF74        1        0        0        0
40DE1780: 40AE2BF0 40DDFF8C        6        0        0        0 40AE2BFC 40DE0100
40DE17A0:        1        0        0        0 40AE2C0C 40DE0118        4        0
40DE17C0:        0        0 40AE2C18 40DE028C        1        0        0        0
40DE17E0: 40AE2C28 40DE02A4        4        0        0        0 40AE2C3C 40DE03AC
40DE1800:        1        0        0        0 40AE2C50 40DE03C4        6        0
40DE1820:        0        0 40AE2C60 40DE0544        1        0        0        0
40DE1840: 40AE2C70 40DE055C        6        0        0        0 40AE2C80 40DE06E8
40DE1860:        1        0        0        0 40AE2C90 40DE0700        6        0
---- block24  ptr=40DE1660  is_malloc=0  length=0x100 ----
40DE1620:        2        0        0        0 40AE2B44 40DDF848        0        0
40DE1640:        0        0 40AE2B54 40DDF860        1        0        0        0
40DE1660: 40AE2B60 40DDF878        6        0        0        0 40AE2B68 40DDFA64
40DE1680:        1        0        0        0 40AE2B7C 40DDFA7C        0        0
40DE16A0:        0        0 40AE2B90 40DDFAA0        1        0        0        0
40DE16C0: 40AE2BA0 40DDFAB8        1        0        0        0 40AE2BA8 40DDFAD0
40DE16E0:        2        0        0        0 40AE2BB4 40DDFB90        4        0
40DE1700:        0        0 40AE2BBC 40DDFD4C        1        0        0        0
40DE1720: 40AE2BC8 40DDFD64        0        0        0        0 40AE2BD4 40DDFD88
---- block25  ptr=5000E738  is_malloc=1  length=0x6D8 ----
5000E6F8: FFFFFFFF FFFFFFFF 4017E148 FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF
5000E718: FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FD0110DF 10DFFD01
5000E738: AB1234CD        3 448E0698 40A426D0 40188AE0 5000E7F8 5000B834 80000048
5000E758:        1 44078710        0        0        0 DEADFEED 5000E7C8 448E0858
5000E778: 50008620 434B3018 5000E770 43FB3620       28    90000        2        0
5000E798: 40A14BFC 4019C738 40DBEBEC        0        0        0        0        0
5000E7B8:        0        0        0        0 448E0858        0 5000E7B8 5000E770
5000E7D8:        0 43FB6490        0  FFFFFFF  FFFFFFF        0 FD0110DF 10DFFD01
5000E7F8: AB1234CD FFFFFFFE        0 40A3C494 4017EA6C 5000EE10 5000E74C 800002F4
5000E818:        1 44078710        0        0 448E0948 50C75CB0        0        0
5000E838: 5001F748       1A       46    C0010        0      30B      30B        1
5000E858:       10    10000 440799B0 52656720 46756E63 74696F6E 20310000 5000E998
5000E878: 5000EDF8        0 5000E998 5000E9A8 5000E9B8 5000E9C8 5000E9D8 5000E9E8
5000E898: 5000E9F8 5000EA08 5000EA18 5000EA28 5000EA38 5000EA48 5000EA58 5000EA68
5000E8B8: 5000EA78 5000EA88 5000EA98 5000EAA8 5000EAB8 5000EAC8 5000EAD8 5000EAE8
5000E8D8: 5000EAF8 5000EB08 5000EB18 5000EB28 5000EB38 5000EB48 5000EB58 5000EB68
5000E8F8: 5000EB78 5000EB88 5000EB98 5000EBA8 5000EBB8 5000EBC8 5000EBD8 5000EBE8
5000E918: 5000EBF8 5000EC08 5000EC18 5000EC28 5000EC38 5000EC48 5000EC58 5000EC68
5000E938: 5000EC78 5000EC88 5000EC98 5000ECA8 5000ECB8 5000ECC8 5000ECD8 5000ECE8
5000E958: 5000ECF8 5000ED08 5000ED18 5000ED28 5000ED38 5000ED48 5000ED58 5000ED68
5000E978: 5000ED78 5000ED88 5000ED98 5000EDA8 5000EDB8 5000EDC8 5000EDD8 5000EDE8
5000E998: 5001FD08        0        0        0        0        0 4059D2FC        0
5000E9B8: 5000E9A8        0        0        0        0        0 4059D194        0
5000E9D8: 5000E9C8        0        0        0        0        0 4059D108        0
5000E9F8: 5000E9E8        0        0        0        0        0 4059D37C        0
5000EA18: 5000EA08        0        0        0        0        0 4059D0B8        0
5000EA38: 5000EA28        0        0        0        0        0 4059D068        0
5000EA58: 5000EA48        0        0        0        0        0 4059CF3C        0
5000EA78: 5000EA68        0        0        0        0        0 4059CE74        0
5000EA98: 5000EA88        0        0        0 44B56E48        0 40697200        0
5000EAB8: 5000EAA8        0        0        0        0        0 40693D8C        0
5000EAD8: 5000EAC8        0        0        0        0        0 40693C68        0
5000EAF8: 5000EAE8        1        0        0 50245880        0 4069A7C8        0
5000EB18: 5000EB08        0        0        0 50C5CA80        0 40693BA8        0
5000EB38: 5000EB28        0        0        0        0        0 40139FC0        0
5000EB58: 5000EB48        0        0        0        0        0 401414BC        0
5000EB78: 5000EB68        0 4013D1D0        0 5000EB78        0        0        0
5000EB98: 44C90E98        0 40138488        0 5000EB98        0        0        0
5000EBB8: 44C90E88        0 4013835C        0 5000EBB8        0        0        0
5000EBD8: 44C90EA8        0 40136574        0 5000EBD8        0        0        0
5000EBF8:        0        0 401362B8        0 5000EBF8        0        0        0
5000EC18:        0        0 401CA094        0 5000EC18        0        0        0
5000EC38:        0        0 4013B898        0 5000EC38        0        0        0
5000EC58:        0        0 4013B010        0 5000EC58        0        0        0
5000EC78:        0        3 4013D4B8        0        0        0 4009D220        0
5000EC98: 5000EC88        0        0        0 44C90F68        0 40145B44        0
5000ECB8: 5000ECA8        0        0        0 5001F9B8        0 406A99F4        0
5000ECD8: 5000ECC8        0        0        0 44D23930        0 406A98A4        0
5000ECF8: 5000ECE8        0        0        0 50C75E18       24 406A9360        0
5000ED18:        0        0 406A904C        0 5000ED18        0        0        0
5000ED38:        0        0 406A8F70        0 5000ED38        0        0        0
5000ED58:        0        0 406A87B4        0 5000ED58        0        0        0
5000ED78:        0        0 406A8B50        0 5000ED78        0        0        0
5000ED98:        0        0 40624980        0 5000ED98        0        0        0
5000EDB8:        0        0 406244D8        0 5000EDB8        0        0        0
5000EDD8:        0        0 402F4258        0 5000EDD8        0        0        0
5000EDF8:        0        0        0        0 FD0110DF 10DFFD01
---- block26  ptr=50BB66A0  is_malloc=1  length=0x100 ----
50BB6660: 402987F0        0 50BB6658        0        0        0 50C75DE8       2E
50BB6680: 409489CC        0        0        0        0        0 FD0110DF 10DFFD01
50BB66A0: AB1234CD FFFFFFFE        0 40A14BFC 401A6314 50BB6700 50BB6394 80000018
50BB66C0:        1 44078710        0        0        0        5 736C6F74 30000000
50BB66E0:        0        0        0        0        0        0 FD0110DF 10DFFD01
50BB6700: AB1234CD FFFFFFFE        0 40A14BFC 401A6314 50BB6760 50BB66B4 80000018
50BB6720:        1 44078710        0        0        0        9 626F6F74 666C6173
50BB6740: 68000000        0        0        0        0        0 FD0110DF 10DFFD01
50BB6760: AB1234CD FFFFFFFE        0 40A14BFC 4029E9BC 50BB7798 50BB6714 80000804
50BB6780:        1 44078710        0        0 E5370062   2E0062   69000F   E56E00
---- block27  ptr=80000018  is_malloc=0  length=0x260 ----
80000000: 44A11000 44BA0000 44BB0800 3C018000 34210084 8C2101C0 401A6800 401B6000
80000020:        0 AF9B815C   200008 337BFF00        0        0        0        0
80000040:        0        0        0        0        0        0        0        0
80000060:        0        0        0        0        0        0        0        0
80000080: 44A11000 44BA0000 44BB0800 3C018000 34210088 8C2101C0 401A6800 401B6000
800000A0:        0 AF9B815C   200008 337BFF00        0        0        0        0
800000C0:        0        0        0        0        0        0        0        0
800000E0:        0        0        0        0        0        0        0        0
80000100: 44A12800 44BA1800 44BB2000 10000051        0 40016000        0 241AFFFE
80000120:   3AD824 409B6000        0 241AFFFB  37AD824 409B6000        0 AF81815C
80000140: 3C018000 34210080 8C2101C0 401A6800 401B6000   200008 337BFF00        0
80000160:        0        0        0        0        0        0        0        0
80000180: 44A11000 44BA0000 44BB0800 401A6800        0 3C018000 335B007C   3B0825
800001A0: 8C2101C0 401B6000        0 AF9B815C   200008 337BFF00        0        0
800001C0: 40195AFC 40195A84 40195A84 40195A84 40195A84 40195A84 40195A84 40195A84
800001E0: BFC12110 40195A84 40195A84 40195A84 40195A84 40195A84 40195A84 40195A84
80000200: 40195A84 40195A84 40195A84 40195A84 40195A84 40195A84 40195A84 40195A84
80000220: 40195A84 40195A84 40195A84 40195A84 40195A84 40195A84 40195A84 40195A84
80000240: 40195988 401959DC 40195A30        0 40DC33D8 401A7800 3C1B00FF 377BFF00
80000260:  35BD024   1AD202 241B0027 175B000D        0 405AD000        0        0
80000280:        0        0 44BA3000 405AD800        0        0        0        0
---- block28  ptr=44078710  is_malloc=0  length=0x100 ----
440786D0: 439B7FA0        0 40A89910 40D90000 434A51E0        0  27151E0        4
440786F0:        C        2        1        0        0        0        0        0
44078710: 439B7FF8 440787A0 44078710 43FB34F0        0 440787B0 44078710 440799B8
44078730:        0        0 40A89990 50000000 60000000        0 10000000        C
44078750:        2        1        1        0 440799B0        0        0        0
44078770:        0        0        0        0        0        0        0        0
44078790:        0        0        0        0 44078710 44079780 440787A0 43FB34F0
440787B0: 44078720        0 440787A0 440799B8 439B7FA0        0 40A8991C 448C23A0
440787D0: 4C000000        0  773DC60        4        2        2        1        0
440787F0: 440799B0        0        0        0 40A899B4        3 44078650 44078650
---- block29  ptr=50BAD9B8  is_malloc=1  length=0x3A8 ----
50BAD978:        0        0        0        0 44E2EB98        0 50BAD978 50BAD930
50BAD998:        0 43FB6490        0  FFFFFFF  FFFFFFF        0 FD0110DF 10DFFD01
50BAD9B8: AB1234CD FFFFFFFE        0 40A14BFC 40695C80 50BADA40 50BAD90C 8000002C
50BAD9D8:        1 44078710        0        0      515      143 43617436 6B205374
50BAD9F8: 61727475 7020436F 6E666967 2053796E 63000000        0 406B599C 406B599C
50BADA18:        0        B FFFFFFFF        0        0        0        0 44E849A0
50BADA38: FD0110DF 10DFFD01 AB1234CD FFFFFFFE        0 5000E864 4017EBAC 50BADD60
50BADA58: 50BAD9CC 80000178        1 44078710        0        0        0 44E2EC88
50BADA78: 50BB63B0        0 5000E828       1A       20    C0010        0        0
50BADA98:        0        0       10    30000 440799B0 52656720 46756E63 74696F6E
50BADAB8: 20310000 50BADB48 50BADD48        0 50BADB48 50BADB58 50BADB68 50BADB78
50BADAD8: 50BADB88 50BADB98 50BADBA8 50BADBB8 50BADBC8 50BADBD8 50BADBE8 50BADBF8
50BADAF8: 50BADC08 50BADC18 50BADC28 50BADC38 50BADC48 50BADC58 50BADC68 50BADC78
50BADB18: 50BADC88 50BADC98 50BADCA8 50BADCB8 50BADCC8 50BADCD8 50BADCE8 50BADCF8
50BADB38: 50BADD08 50BADD18 50BADD28 50BADD38 50C75DD8        D 40948828        0
50BADB58:        0        0 40946980        0        0        0 4094687C        0
50BADB78: 50BADB68        0        0        0 50C4B408        0 409466AC        0
50BADB98: 50BADB58        0 40946800        0        0        0 409467CC        0
50BADBB8: 50BADBA8        0        0        0        0        0 409466C8        0
50BADBD8: 50BADBC8        0        0        0 50C4B3F8        0 4092C640        0
50BADBF8:        0        0 4092BE78        0 50BADBF8        0        0        0
50BADC18:        0        0 4092BDBC        0 50BADC18        0        0        0
50BADC38:        0        0 4092BDBC        0 50B96628       24 4092BE8C        0
50BADC58:        0        0 409105E8        0 50BADC58        0        0        0
50BADC78:        0        0 409104F4        0 50BADC78        0        0        0
50BADC98:        0        0 40728DA4        0 50BADC98        0        0        0
50BADCB8: 50BB6548        0 40729170        0 50BB6558        0 40729148        0
50BADCD8: 50C4B368        0 407299FC        0 50C4B3E8        0 407298AC        0
50BADCF8: 50BADCE8        0        0        0 50C4B818        0 40729778        0
50BADD18: 50C4B488        0 40729740        0 44E807D0        0 40729904        0
50BADD38:        0        0 40722DF8        0        0        0        0        0
50BADD58: FD0110DF 10DFFD01
---- block30  ptr=44E35F68  is_malloc=1  length=0x2B0 ----
44E35F28: 409C0174 44E35F68 44E35CCC 80000010        1 440787A0 A7E94BB2 90762BDD
44E35F48: 44E35C98        0        0        0        0        0 FD0110DF 10DFFD01
44E35F68: AB1234CD FFFFFFFE        0 40A14BFC 4030A790 44E35FB8 44E35F2C 80000010
44E35F88:        1 440787A0 B139AA8D 7653FF0C 52504320 72665F73 65745F64 65627567
44E35FA8: 5F666C61 67000000 FD0110DF 10DFFD01 AB1234CD       2D 44E35FE8 40A426B8
44E35FC8: 4019D268 44E36218 44E35F7C 80000118        1 440787A0 8CE7C717 A02794D5
44E35FE8: 50BB4B48 50BB61A0 4030BD94        0 43FB0000 50C64410        0        0
44E36008:        0        0        0        0        0 50BB6290        0 40187DE4
44E36028:        0        0        0        0    10000  1000000  1000000        4
44E36048:       2D 403071B8 40187CD8        0       C0        0     1B88        0
44E36068:        0        0        0      CD8        0        0        0      EE0
44E36088:        0      EE0        0        1        0 44E35F98        2        0
44E360A8:        0        0        0     1770     1770 500047C8        0        0
44E360C8:        0        0 50BB4AC0 50C4BC8C 44E2EAC4 44E35FE8 43FB58E0        0
44E360E8:        0        0 434B86F0        0        0        0     420A        0
44E36108:        0        0 44E360E8        0        0        0     4290 44E35FE8
44E36128:        0        0        0        0 44E360E8 44E35FE8        0        0
44E36148:    142D2        0        0        0 44E360E8 44E35FE8        0        0
44E36168:    242D2        0        0 50BB62F0 50BB62F0        1        0 50C64410
44E36188:        0        0        0        0        0        0        0        0
44E361A8:        0 50BB6350 44E36198 50BB62F8        0 43FB60A0        0        0
44E361C8:        0        0        0        4  FFFFFFF        0        0        0
44E361E8:        0        0        0        0        0 44E36248        0        0
44E36208:        0 BEEFCAFE FD0110DF 10DFFD01
---- block31  ptr=50BB4A90  is_malloc=1  length=0xA00 ----
50BB4A50:        0        0        0        0 44E35EA8        0 50BB4A50 50BB4A08
50BB4A70:        0 43FB6490        0  FFFFFFF  FFFFFFF        0 FD0110DF 10DFFD01
50BB4A90: AB1234CD FFFFFFFE        0 40A14BFC 4030A744 50BB4B18 50BB49E4 8000002C
50BB4AB0:        1 44078710        0        0 44E1C468 72665F73 65745F64 65627567
50BB4AD0: 5F666C61 67000000        0        0        0        0        0        0
50BB4AF0:        0        0        0        0        0 409487E8 FFFF0000       2D
50BB4B10: FD0110DF 10DFFD01 AB1234CD       2D 44E35FE8 40A426C0 401984D0 50BB62C0
50BB4B30: 50BB4AA4 80000BBC        1 44078710        0        0 FFFFFFFF FFFFFFFF
50BB4B50: FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF
50BB4B70: FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF
50BB4B90: FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF
50BB4BB0: FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF
50BB4BD0: FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF
50BB4BF0: FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF
50BB4C10: FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF
50BB4C30: FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF
50BB4C50: FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF
50BB4C70: FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF
50BB4C90: FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF
50BB4CB0: FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF
50BB4CD0: FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF
50BB4CF0: FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF
50BB4D10: FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF
50BB4D30: FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF
50BB4D50: FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF
50BB4D70: FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF
50BB4D90: FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF
50BB4DB0: FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF
50BB4DD0: FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF
50BB4DF0: FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF
50BB4E10: FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF
50BB4E30: FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF
50BB4E50: FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF
50BB4E70: FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF
50BB4E90: FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF
50BB4EB0: FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF
50BB4ED0: FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF
50BB4EF0: FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF
50BB4F10: FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF
50BB4F30: FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF
50BB4F50: FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF
50BB4F70: FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF
50BB4F90: FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF
50BB4FB0: FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF
50BB4FD0: FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF
50BB4FF0: FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF
50BB5010: FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF
50BB5030: FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF
50BB5050: FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF
50BB5070: FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF
50BB5090: FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF
50BB50B0: FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF
50BB50D0: FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF
50BB50F0: FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF
50BB5110: FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF
50BB5130: FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF
50BB5150: FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF
50BB5170: FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF
50BB5190: FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF
50BB51B0: FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF
50BB51D0: FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF
50BB51F0: FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF
50BB5210: FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF
50BB5230: FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF
50BB5250: FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF
50BB5270: FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF
50BB5290: FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF
50BB52B0: FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF
50BB52D0: FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF
50BB52F0: FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF
50BB5310: FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF
50BB5330: FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF
50BB5350: FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF
50BB5370: FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF
50BB5390: FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF
50BB53B0: FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF
50BB53D0: FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF
50BB53F0: FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF
50BB5410: FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF
50BB5430: FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF
50BB5450: FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF
50BB5470: FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF
---- block32  ptr=80000048  is_malloc=0  length=0x100 ----
80000008: 44BB0800 3C018000 34210084 8C2101C0 401A6800 401B6000        0 AF9B815C
80000028:   200008 337BFF00        0        0        0        0        0        0
80000048:        0        0        0        0        0        0        0        0
80000068:        0        0        0        0        0        0 44A11000 44BA0000
80000088: 44BB0800 3C018000 34210088 8C2101C0 401A6800 401B6000        0 AF9B815C
800000A8:   200008 337BFF00        0        0        0        0        0        0
800000C8:        0        0        0        0        0        0        0        0
800000E8:        0        0        0        0        0        0 44A12800 44BA1800
80000108: 44BB2000 10000051        0 40016000        0 241AFFFE   3AD824 409B6000
80000128:        0 241AFFFB  37AD824 409B6000        0 AF81815C 3C018000 34210080
---- block33  ptr=50007FC0  is_malloc=0  length=0x100 ----
50007F80: 40AA7850 4019C738 40DBEBEC        0 40AA7850        4        0        0
50007FA0:        0        0 50007F48 50008008 50007FA8 43FB3D00        0        0
50007FC0: 50007F60 50BB6300 50007FB8 43FB3620      11F    90000        0        0
50007FE0: 40AA783C 4019C738 40DBEBEC        0 40AA783C        4        0        0
50008000:        0        0 50007FA8 50008068 50008008 43FB3D00        0        0
50008020: 44E17350 44E2C4C8 50008018 43FB3620      114    90000        0        0
50008040: 40C6792C 4019C738 40DBEBEC        0 40C6792C        4        0        0
50008060:        0        0 50008008 500080C8 50008068 43FB3D00        0        0
50008080: 44E21230 44E1E258 50008078 43FB3620      10D    90000        0        0
500080A0: 40BD53F4 4019C738 40DBEBEC        0 40BD53F4        4        0        0
---- block34  ptr=50BB49D0  is_malloc=1  length=0x100 ----
50BB4990: FFFFFFFF FFFFFFFF 4017E148 FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF
50BB49B0: FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FD0110DF 10DFFD01
50BB49D0: AB1234CD       2C 44E35CE8 40A426D0 40188AE0 50BB4A90 50BB323C 80000048
50BB49F0:        1 44078710        0        0        0 DEADFEED 50BB4A60 448DB4D0
50BB4A10: 50BB6300 44E17200 50BB4A08 43FB3620      11D    90000        3        0
50BB4A30: 40D53DF4 4019C738 40DBEBEC        0        0        0        0        0
---- block35  ptr=434AB758  is_malloc=0  length=0x100 ----
434AB718:        0        0 44B0BC38        0        0        0        0        0
434AB738:        0        0        0        0        0        0        0        0
434AB758: 434AC398 409EC940        0 4017EA00 4017EA00        0        0        0
434AB778:        0        0        0        0        0        0        0        0
434AB798:        0        0        0        0        0        0        0        0
434AB7B8:        0        0        0        0        0        0        0        0
434AB7D8:        0        0        0        0        0        0        0        0
434AB7F8:        0        0        0        0        0        0        0        0
434AB818:        0        0        0        0        0        0        0        0
434AB838:        0        0        0        0        0        0        0        0
---- block36  ptr=44B56C20  is_malloc=1  length=0x320 ----
44B56BE0: DEE6BE4F CCC7196E        0        0    1869F       2C       30        0
44B56C00:        0        0        0        0        0 50251A80 FD0110DF 10DFFD01
44B56C20: AB1234CD FFFFFFFE        0 5000E864 4017F074 44B56F40 44B56BCC 80000178
44B56C40:        1 440787A0 C18624BD 5FA8980E        0 44B0E580 44C90CC0        0
44B56C60: 5000E828       1A       20    C0010        0        0        0        0
44B56C80:       10    30000 440799B0 52656720 46756E63 74696F6E 20310000 44B56D28
44B56CA0: 44B56F28        0 44B56D28 44B56D38 44B56D48 44B56D58 44B56D68 44B56D78
44B56CC0: 44B56D88 44B56D98 44B56DA8 44B56DB8 44B56DC8 44B56DD8 44B56DE8 44B56DF8
44B56CE0: 44B56E08 44B56E18 44B56E28 44B56E38 44B56E48 44B56E58 44B56E68 44B56E78
44B56D00: 44B56E88 44B56E98 44B56EA8 44B56EB8 44B56EC8 44B56ED8 44B56EE8 44B56EF8
44B56D20: 44B56F08 44B56F18        0        0 4072DFEC        0 44B56D28        0
44B56D40:        0        0        0        0 4072F4E0        0 44B56D48        0
44B56D60:        0        0 44C90F78        0 4072E938        0 44C90F88        0
44B56D80: 4072E914        0 44B56D68        0 406F0EB0        0 44B56D78        0
44B56DA0: 406F0E8C        0 44C90E38        0 406F0E08        0 44B56DA8        0
44B56DC0:        0        0        0        0 406F03FC        0 44B56DC8        0
44B56DE0:        0        0 50B95548        0 405C227C        0 44B56DE8        0
44B56E00:        0        0 50BADBE8        0 405C0A38        0 44B56E08        0
44B56E20:        0        0        0        0 405C0A5C        0 44B56E28        0
44B56E40:        0        0 50A97BD8        0 405C129C        0        0        0
44B56E60: 403AE92C        0 44B56E58        0        0        0        0        0
44B56E80: 403AE8A8        0 44B56E78        0        0        0 44B56D88        0
44B56EA0: 402CBB04        0 44B56D98        0 402CBA90        0        0        8
44B56EC0: 402CC110        0        0        0 402D01E8        0 44B56EC8        0
44B56EE0:        0        0        0        0 402B7418        0 44B56EE8        0
44B56F00:        0        0        0        0 402C7020        0        0        2
44B56F20: 4025BFC8        0        0        0        0        0 FD0110DF 10DFFD01
---- block37  ptr=44E80558  is_malloc=1  length=0x320 ----
44E80518:        0        0        0        0 50C4BD60        0 44E80518 44E804D0
44E80538:        0 43FB6490        0  FFFFFFF  FFFFFFF        0 FD0110DF 10DFFD01
44E80558: AB1234CD FFFFFFFE        0 5000E864 4017EBAC 44E80878 44E804AC 80000178
44E80578:        1 440787A0 B105D644 F4B2E626        0 50C4B5D0 50C5C998        0
44E80598: 5000E828       1A       20    C0010        0        0        0        0
44E805B8:       10    30000 440799B0 52656720 46756E63 74696F6E 20310000 44E80660
44E805D8: 44E80860        0 44E80660 44E80670 44E80680 44E80690 44E806A0 44E806B0
44E805F8: 44E806C0 44E806D0 44E806E0 44E806F0 44E80700 44E80710 44E80720 44E80730
44E80618: 44E80740 44E80750 44E80760 44E80770 44E80780 44E80790 44E807A0 44E807B0
44E80638: 44E807C0 44E807D0 44E807E0 44E807F0 44E80800 44E80810 44E80820 44E80830
44E80658: 44E80840 44E80850        0        0 4050F07C        0 44E80660        0
44E80678:        0        0        0        0 402E91B4        0 50C5CB70        0
44E80698: 406B80D8        0 50C5CB80        0 406B80B4        0        0        0
44E806B8: 406B7070        0 44E806B0        0        0        0        0        0
44E806D8: 406B7BEC        0        0        0 406B7B98        0 50C4B758      14A
44E806F8: 406B7C68        0 50C4B7E8      14A 402E7C98        0        0        0
44E80718: 406B770C        0 44E80710        0        0        0        0        0
44E80738: 406B7548        0 50C5CBE0        0 406B7608        0        0        0
44E80758: 405C7434        0 44E80750        0        0        0        0      204
44E80778: 405C742C        0        0        0 405A7B18        0 44E80780        0
44E80798:        0        0        0        0 405A62B8        0        0        0
44E807B8: 405A48D4        0        0        0 405A55B0        0 44E80680        0
44E807D8: 405A5420        0        0        0 405A526C        0 44E807E0        0
44E807F8:        0        0 50C75EE8        0 4057A884        0 44E80800        0
44E80818:        0        0 44E80690        0 406A0FD0        0 44E806A0        0
44E80838: 406A0F90        0 50C5CBA0        0 4031D7B8        0 50C5CAB0        0
44E80858: 4031CA0C        0        0        0        0        0 FD0110DF 10DFFD01
---- block38  ptr=40D9EEB0  is_malloc=0  length=0x114 ----
40D9EE70: 409EFF24 409EFF14 409EFF04 409EFEF4 409EFEE8 409F06F4 409F06E4 409F06D4
40D9EE90: 409F06C0 409F06A4 409F0690 409F0730 409F0724 409F071C 409F0714 409F0704
40D9EEB0:        0        0 400F2160        0        0        0        0 400F2188
40D9EED0:        0        0        0        0 400F2168        0        0        0
40D9EEF0:        0 400F2160        0        0 40D9EEB0 40DAB94C 400F2404        0
40D9EF10:        0 40D9EF00 40D9EEC4 400F2404        0        0        0        0
40D9EF30: 400F55D0 400E6D7C        0 FF000000        0 40D9EF28 40D9EEC4 400F244C
40D9EF50: 409F0CF8        0 FF000000        0 40D9EF44 40D9EF14 400F244C 409F0D28
40D9EF70:        0        0        0 400F5564 409F0D50        0 FF100000        0
40D9EF90: 40D9EF74 40D9EF60 400F244C 409F0D58        0        0        0 400F55D0
40D9EFB0: 400D8CB8        0 40D9EFA4        0 400F6A98
---- block39  ptr=5F636264  is_malloc=0  length=0x100 ----
5F636224:        0        0        0        0        0        0        0        0
5F636244:        0        0        0        0        0        0        0        0
5F636264:        0        0        0        0        0        0        0        0
5F636284:        0        0        0        0        0        0        0        0
5F6362A4:        0        0        0        0        0        0        0        0
5F6362C4:        0        0        0        0        0        0        0        0
5F6362E4:        0        0        0        0        0        0        0        0
5F636304:        0        0        0        0        0        0        0        0
5F636324:        0        0        0        0        0        0        0        0
5F636344:        0        0        0        0        0        0        0        0
---- block40  ptr=5F77686C  is_malloc=0  length=0x100 ----
5F77682C:        0        0        0        0        0        0        0        0
5F77684C:        0        0        0        0        0        0        0        0
5F77686C:        0        0        0        0        0        0        0        0
5F77688C:        0        0        0        0        0        0        0        0
5F7768AC:        0        0        0        0        0        0        0        0
5F7768CC:        0        0        0        0        0        0        0        0
5F7768EC:        0        0        0        0        0        0        0        0
5F77690C:        0        0        0        0        0        0        0        0
5F77692C:        0        0        0        0        0        0        0        0
5F77694C:        0        0        0        0        0        0        0        0
---- block41  ptr=5F656E64  is_malloc=0  length=0x100 ----
5F656E24:        0        0        0        0        0        0        0        0
5F656E44:        0        0        0        0        0        0        0        0
5F656E64:        0        0        0        0        0        0        0        0
5F656E84:        0        0        0        0        0        0        0        0
5F656EA4:        0        0        0        0        0        0        0        0
5F656EC4:        0        0        0        0        0        0        0        0
5F656EE4:        0        0        0        0        0        0        0        0
5F656F04:        0        0        0        0        0        0        0        0
5F656F24:        0        0        0        0        0        0        0        0
5F656F44:        0        0        0        0        0        0        0        0
---- block42  ptr=45544500  is_malloc=0  length=0x100 ----
455444C0:  D74F23A C5FFF7C0 FFF7D0FF  3B3050C DA9943F1 7F07FC7F  FFD3F50 B0B3402F
455444E0: AF53FCDF  1FF77D0 FF037FB3 628C61BE E650FCDF  1FF77D0 FFC7CC10 3038470E
45544500: 857F07F8 77D0FFC7 6C1230F8 F70F9C0A FF4EF0EF 24FF63AC F5887D0C E3BD53F1
45544520: 7F27FCDF 496EC798 BE0F3AD2 86C65873 6287B392 E7B87FD2 A9F0EF04 FF4EC688
45544540: 31AF47E3 1BF1EE43 CEFB5E85 FFBDE0DF 49FE3F0C 97C78A3C C1FE21F3 C3BD4AFD
45544560: B317F5CF 5EDAC187 DF08E361  CDAEB52 3050FFEC CD26C6EF FEC7F311 B9DCABC4
45544580: BF7DC679 5F1D64FF 284DC1A2 CDEE8B51 B036E160 1CFC4898 EBB1CC3D F629FD9F
455445A0: 7DA883F7 F9F6FDD9 C79AF6BE 8DB48BB1 D6B13AF6 D1AEC732 F7DBA7D4 7FFB50FF
455445C0: ED2BE7F5 82968E25  FFB95FA 6F3FEABF FD21C478 3E1A03B5 81FD636A C77EA5FE
455445E0: DBEFC4E1 ABFFEC1F  B3EFDF1 665E57A9 6034E128 22469280 C1FA62FF  BFF18E9
---- block43  ptr=534C4350  is_malloc=0  length=0x100 ----
534C4310:        0        0        0        0        0        0        0        0
534C4330:        0        0        0        0        0        0        0        0
534C4350:        0        0        0        0        0        0        0        0
534C4370:        0        0        0        0        0        0        0        0
534C4390:        0        0        0        0        0        0        0        0
534C43B0:        0        0        0        0        0        0        0        0
534C43D0:        0        0        0        0        0        0        0        0
534C43F0:        0        0        0        0        0        0        0        0
534C4410:        0        0        0        0        0        0        0        0
534C4430:        0        0        0        0        0        0        0        0
---- block44  ptr=53757064  is_malloc=0  length=0x100 ----
53757024:        0        0        0        0        0        0        0        0
53757044:        0        0        0        0        0        0        0        0
53757064:        0        0        0        0        0        0        0        0
53757084:        0        0        0        0        0        0        0        0
537570A4:        0        0        0        0        0        0        0        0
537570C4:        0        0        0        0        0        0        0        0
537570E4:        0        0        0        0        0        0        0        0
53757104:        0        0        0        0        0        0        0        0
53757124:        0        0        0        0        0        0        0        0
53757144:        0        0        0        0        0        0        0        0
---- block45  ptr=52502064  is_malloc=0  length=0x100 ----
52502024:        0        0        0        0        0        0        0        0
52502044:        0        0        0        0        0        0        0        0
52502064:        0        0        0        0        0        0        0        0
52502084:        0        0        0        0        0        0        0        0
525020A4:        0        0        0        0        0        0        0        0
525020C4:        0        0        0        0        0        0        0        0
525020E4:        0        0        0        0        0        0        0        0
52502104:        0        0        0        0        0        0        0        0
52502124:        0        0        0        0        0        0        0        0
52502144:        0        0        0        0        0        0        0        0
---- block46  ptr=57616974  is_malloc=0  length=0x100 ----
57616934:        0        0        0        0        0        0        0        0
57616954:        0        0        0        0        0        0        0        0
57616974:        0        0        0        0        0        0        0        0
57616994:        0        0        0        0        0        0        0        0
576169B4:        0        0        0        0        0        0        0        0
576169D4:        0        0        0        0        0        0        0        0
576169F4:        0        0        0        0        0        0        0        0
57616A14:        0        0        0        0        0        0        0        0
57616A34:        0        0        0        0        0        0        0        0
57616A54:        0        0        0        0        0        0        0        0
---- block47  ptr=80E20000  is_malloc=0  length=0x100 ----
80E1FFC0:        0        0 400F5564 40C1D838        0 40E1FFC0 40D9EEC4 400F5870
80E1FFE0: 40C1D840        0 11000000        0 40E1FFD4 40D9EEC4 400F244C 40C1D860
80E20000:        0 40E1FFF0 40D9EEC4 400F5DB4 40C1D884        0 11000000        0
80E20020: 40E20004 40D9EEC4 400F244C 40C1D894        0 11000000        0 40E20020
80E20040: 40D9EEC4 400F244C 40C1D8A0        0        0        0 400F5564 40C1D8C0
80E20060:        0 40E20050 40D9EEC4 400F5870 40C1D8C8        0 11000000        0
80E20080: 40E20064 40D9EEC4 400F244C 40C1D8DC        0 40E20080 40D9EEC4 400F5DB4
80E200A0: 40C1D8E8        0 11000000        0 40E20094 40D9EEC4 400F244C 40C1D8F8
80E200C0:        0 11000000        0 40E200B0 40E2003C 400F244C 40C1D904        0
80E200E0:        0        0 400F5564 40C1D92C        0 40E200E0 40D9EEC4 400F5870
---- block48  ptr=80430000  is_malloc=0  length=0x100 ----
8042FFC0: 24A529F8 3C0440B5 24842A58  C03748A  2002821  810C009        0 8E239E18
8042FFE0: 24422D54  2021021 14600005 A0400000 3C024451 8C437E38 1060000A        0
80430000: 3C0440B5 24840290 3C0540B5  C03748A 24A529F8 3C0440B5 24842A7C  C03748A
80430020:  2002821  C041A97  2402021 8FBF001C 8FB20018 8FB10014 8FB00010  3E00008
80430040: 27BD0020 3C02445A 8C439E18 27BDFFE0 AFB10014   808821 AFBF0018 14600005
80430060: AFB00010 3C024451 8C437E38 1060000B 24040017 3C0440B5 24840290 3C0540B5
80430080:  C03748A 24A52AA4 3C0440B5 24842AC0  C03748A  2202821 24040017 2625FFFF
804300A0: 30A500FF     3021  C0B5B37 2407002A   408021 12000014  2202821  2002021
804300C0: 8E020024 3C064043 24C6FEB8 24030017 24070009 A0430003 24030007 A0400002
804300E0: A0470010 A0400013 A0430014 A0400015  C0B6A6B A0430016 14400004 8FBF0018
---- block49  ptr=434A4F78  is_malloc=0  length=0x100 ----
434A4F38:        0        0        0        0        0        0        0        0
434A4F58:        0        0        0        0        0        0        0        0
434A4F78:        0        0        0        0        0        0        0        0
434A4F98:        0        0        0        0        0        0        0        0
434A4FB8:        0        0        0        0        0        0        0        0
434A4FD8:        0  1000000        0        0        0        0        0   200000
434A4FF8:        0        0        0        0        0        0        0        0
434A5018:        0        0        0        0        0        0        0        0
434A5038:        0        0        0        0        0        0        0        0
434A5058:        0        0        0        0        0        0        0        0
---- block50  ptr=42494E00  is_malloc=0  length=0x100 ----
42494DC0: C33AE4AF 6BAF0C4A 223DC3BA 968E96A7 E4D35236 743DFD66 E97D03C6 371B7D38
42494DE0: C4B07EDF 46989F1A 9359DC0F 667C9626 7E32B414 DF975B5C FDB99E33 27E426B5
42494E00: 454AD547 637F063A  A1970C1 B85C2753 95D169F2 5E676953 33FD1220 EFD532C6
42494E20: 73B4D018 68694D6C 257DE3A6 74BF5D69 E962D0D2 2F808E52 36499AB9 6E64A857
42494E40: 5E4CD3F7 DABD595A 1AD4B5E3 5E09826E  60BFD1F 8166042D FD6836B4 F4959F81
42494E60: 9636EB7E 77CE47C2 B3B19D48 67EB075A 3847ED11 B8F74A79 7DCCCED9 548DF6A1
42494E80: CED994F6 C3BB3A67 11EF4C79 E76B3A5A 91CA0CFD 26BEC9F2 7C92617E CBD468BE
42494EA0: 6FB202BF 64943B2A 52B26064 A791112E E4D9CEB4 928FBACC FD9B5B78 6E61F8D9
42494EC0: 23E0DB5E FD1CDF69 17C27D36 866DDC2F D1579D7A 7EEBCFFC 923E19C8 F7BAB20B
42494EE0: 6D0A4706 78FF3778 27D40B32 91CABB5D 1BA937CF 75A746D7 EDEE23EC DDCDE8C7
---- block51  ptr=48455800  is_malloc=0  length=0x100 ----
484557C0:        0        0        0        0        0        0        0        0
484557E0:        0        0        0        0        0        0        0        0
48455800:        0        0        0        0        0        0        0        0
48455820:        0        0        0        0        0        0        0        0
48455840:        0        0        0        0        0        0        0        0
48455860:        0        0        0        0        0        0        0        0
48455880:        0        0        0        0        0        0        0        0
484558A0:        0        0        0        0        0        0        0        0
484558C0:        0        0        0        0        0        0        0        0
484558E0:        0        0        0        0        0        0        0        0
---- block52  ptr=524C4300  is_malloc=0  length=0x100 ----
524C42C0:        0        0        0        0        0        0        0        0
524C42E0:        0        0        0        0        0        0        0        0
524C4300:        0        0        0        0        0        0        0        0
524C4320:        0        0        0        0        0        0        0        0
524C4340:        0        0        0        0        0        0        0        0
524C4360:        0        0        0        0        0        0        0        0
524C4380:        0        0        0        0        0        0        0        0
524C43A0:        0        0        0        0        0        0        0        0
524C43C0:        0        0        0        0        0        0        0        0
524C43E0:        0        0        0        0        0        0        0        0
---- block53  ptr=41434100  is_malloc=0  length=0x100 ----
414340C0: 9E7AEE34 F6D42C87 46B679DD 71EF2C97 ECBDC8B6 A0837F29 F2086DCC D2EFDA1D
414340E0: EA464F70 AC81E3FB 3B5C7154 F0CFEB22 1979A7DB F6BBADA5 70FFBBCD 8ED3071D
41434100: 5CED45CE E58B3AE7 F23B068B 1F731D63 2B105B3C 2563EAEC 33C4E366 FCB1BC51
41434120: C0333A25 381EB5B0 FBECC992 7E9296FD F58C2F1C 603FBF5A F8B1B2AC  6DEC019
41434140: A2438CFD 2FF69938 BA70CFB6 4DB8867D  8DFA423 C647E6F9 C7A783F4 9B688FE7
41434160: 9B628BBF C73313C7 E349261B 3C3789BF 8DC8E599 47491E37 1B3DDC96 5721F861
41434180: 2EBE29ED 3EFBACFC C7BE80E6 EE844B76 4E407626 F5DEE014 E6D41CFC FD781E4C
414341A0: C89E83CA FD079D97 FDAA1D57 A4EBA076 CCA0FDB2 47F82039 7A2BC9B3 D534F727
414341C0: B44CA3F9 3D45F746 BB5494F7  EDF5665 ADF3ACB3 9C9FEA82 4C9272E1 374B657B
414341E0: E13B8B98 3D8D13D9 9BEE509D 9B805181 DFE28BDB 89DFA44F 21767325 F86DF78B
---- block54  ptr=44E8D200  is_malloc=1  length=0x100 ----
44E8D1E0:        0 44E8D230        0        0        0 BEEFCAFE FD0110DF 10DFFD01
44E8D200: AB1234CD FFFFFFFE        0 40A14BFC 409C0174 44E8D250 44E8CFB4 80000010
44E8D220:        1 440787A0 D0F3523C CFB8E279 44E8CF80        0        0        0
44E8D240:        0        0 FD0110DF 10DFFD01 AB1234CD       16 50A97690 40A3DFD4
44E8D260: 40188AE0 44E8D310 44E8D214 80000048        1 440787A0 AC07D9BF 96E67C7F
44E8D280:        0 DEADFEED 44E8D2E0 448DBB60 44E8CB78 50C642A0 44E8D288 43FB3620
44E8D2A0:      14F    90000        2        0 50A97640 4019C738 40DBEBEC        0
44E8D2C0:        0        0        0        0        0        0        0        0
44E8D2E0: 448DBB60        0 44E8D2D0 44E8D288        0 43FB6490        0  FFFFFFF
---- block55  ptr=50C629F8  is_malloc=1  length=0xA00 ----
50C629B8:        0        0        0        0 44E8CEE0        0 50C629B8 50C62970
50C629D8:        0 43FB6490        0  FFFFFFF  FFFFFFF        0 FD0110DF 10DFFD01
50C629F8: AB1234CD       3E 44E8CFD0 40A426C0 401984D0 50C641A0 50C6294C 80000BBC
50C62A18:        1 44078710        0        0 FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF
50C62A38: FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF
50C62A58: FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF
50C62A78: FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF
50C62A98: FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF
50C62AB8: FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF
50C62AD8: FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF
50C62AF8: FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF
50C62B18: FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF
50C62B38: FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF
50C62B58: FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF
50C62B78: FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF
50C62B98: FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF
50C62BB8: FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF
50C62BD8: FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF
50C62BF8: FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF
50C62C18: FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF
50C62C38: FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF
50C62C58: FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF
50C62C78: FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF
50C62C98: FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF
50C62CB8: FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF
50C62CD8: FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF
50C62CF8: FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF
50C62D18: FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF
50C62D38: FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF
50C62D58: FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF
50C62D78: FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF
50C62D98: FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF
50C62DB8: FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF
50C62DD8: FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF
50C62DF8: FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF
50C62E18: FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF
50C62E38: FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF
50C62E58: FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF
50C62E78: FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF
50C62E98: FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF
50C62EB8: FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF
50C62ED8: FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF
50C62EF8: FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF
50C62F18: FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF
50C62F38: FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF
50C62F58: FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF
50C62F78: FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF
50C62F98: FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF
50C62FB8: FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF
50C62FD8: FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF
50C62FF8: FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF
50C63018: FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF
50C63038: FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF
50C63058: FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF
50C63078: FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF
50C63098: FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF
50C630B8: FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF
50C630D8: FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF
50C630F8: FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF
50C63118: FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF
50C63138: FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF
50C63158: FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF
50C63178: FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF
50C63198: FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF
50C631B8: FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF
50C631D8: FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF
50C631F8: FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF
50C63218: FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF
50C63238: FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF
50C63258: FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF
50C63278: FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF
50C63298: FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF
50C632B8: FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF
50C632D8: FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF
50C632F8: FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF
50C63318: FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF
50C63338: FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF
50C63358: FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF
50C63378: FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF
50C63398: FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF
50C633B8: FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF
50C633D8: FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF
---- block56  ptr=8001FC28  is_malloc=0  length=0x100 ----
8001FBE8: 4019C3F0 43FB0000 440799B0 4017D658 50B95BA0 50B95BD0        0 40172148
8001FC08: 44A742A2 31EA5567     17A8 44E1B208 4019C4AC        0     17A8 44E1B208
8001FC28:      260 50B95940 4019C4AC 401768B8      260 50B95940 40DC0000 440799B0
8001FC48: 4019E3C0 44E8CFD0 43FB0000 43FB0000 43FB0000        0        0 40A40000
8001FC68: 43FB0000 44E8D0BC        0      EE8        0      EE8 43FB0000 43FB0000
8001FC88: 4019DBF8 4019DBAC 44E8CFD0 4019E384        0        0 43FB0000 8001FCE0
8001FCA8: 40A40000 40A40000 43FB5980 8001FD60        0        0 4019F800      EE8
8001FCC8: FFFFFFFF 8001FDF8        0       20        0       28        0 3401C101
8001FCE8:        0 34018100 FFFFFFFF FFFF00FF        0 40198408        0 448E4490
8001FD08:        0 448E448C        0 448E4488        0 44810000        A 4025AF9C
---- block57  ptr=50004788  is_malloc=1  length=0xA00 ----
50004748: 409C0174 50004788 500046FC 80000010        1 44078710        0        0
50004768: 50004718        0        0        0        0        0 FD0110DF 10DFFD01
50004788: AB1234CD FFFFFFFE        0 40A18224 400EDD08 50005878 5000474C 80000860
500047A8:        1 44078710        0        0 43534364 72303139 32390000        0
500047C8:        1        0        0        0        0        0        0        0
500047E8:        0        0        0        0        0 440784F0 440784F0 440784F0
50004808:        0        0 43F8ECB0        0        0        0     4200        0
50004828:        0        0        0        0        0        0        0        0
50004848:        0        0        0        0        0        0        0        0
50004868:        0        0        0        0        0        0        0        0
50004888:        0        0        4     1388        0 FFFFFFFF FFFFFFFF        0
500048A8:        0        0        0        0        0        0        0        0
500048C8:        0        0        0        0        0        0        0        0
500048E8:        0       32        0        0        0        0       32        0
50004908:        0        0        0        0        0        0        0        0
50004928:        0        0        0        0        0        0        0        0
50004948:        0        0        0        0        0        0        0        0
50004968:        0        0        0        0        0        0        0        0
50004988:        0        0        0        0        0        0        0        0
500049A8:        0        0        0        0        0        0        0        0
500049C8:        0        0        0        0        0        0        0        0
500049E8:        0        0        0        0        0        0        0        0
50004A08:        0        0        0        0        0        0        0        0
50004A28:        0        0        0        0        0        0        0        0
50004A48:        0        0        0        0        0        0        0        0
50004A68:        0        0        0        0        0        0        0        0
50004A88:        0        0        0        0        0        0        0        0
50004AA8:        0        0        0        0        0        0        0        0
50004AC8:        0        0        0        0        0        0        0        0
50004AE8:        0        0        0        0        0        0        0        0
50004B08:        0        0        0        0        0        0        0        0
50004B28:        0        0        0        0        0        0        0        0
50004B48:        0        0        0        0        0        0        0        0
50004B68:        0        0        0        0        0        0        0        0
50004B88:        0        0        0        0        0        0        0        0
50004BA8:        0        0        0        0        0        0        0        0
50004BC8:        0        0        0        0        0        0        0        0
50004BE8:        0        0        0        0        0        0        0        0
50004C08:        0        0        0        0        0        0        0        0
50004C28:        0        0        0        0        0        0        0        0
50004C48:        0        0        0        0        0        0        0        0
50004C68:        0        0        0        0        0        0        0        0
50004C88:        0        0        0        0        0        0        0        0
50004CA8:        0        0        0        0        0        0        0        0
50004CC8:        0        0        0        0        0        0        0        0
50004CE8:        0        0        0        0        0        0        0        0
50004D08:        0        0        0        0        0        0        0        0
50004D28:        0        0        0        0        0        0        0        0
50004D48:        0        0        0        0        0        0        0        0
50004D68:        0        0        0        0        0        0        0        0
50004D88:        0        0        0        0        0        0        0        0
50004DA8:        0        0        0        0        0        0        0        0
50004DC8:        0        0        0        0        0        0        0        0
50004DE8:        0        0        0        0        0        0        0        0
50004E08:        0        0        0        0        0        0        0        0
50004E28:        0        0        0        0        0        0        0        0
50004E48:        0        0        0        0        0        0        0        0
50004E68:        0        0        0        0        0        0        0        0
50004E88:    F0005     4E20        0        0 FFFFFFFF        D        0        0
50004EA8:        0        0        0        0        0        0        0 FFFFFFFF
50004EC8:        0       40        0        0        0        0        0        0
50004EE8:        0        0        0        0        0        0        2       13
50004F08:       11       50       18       1E FFFFFFFF        0        0        0
50004F28: FFFFFFFF        0        0        0        0        8 FFFFFFFF FFFFFFFF
50004F48: FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF        4 FFFFFFFF FFFFFFFF       7F
50004F68:       15       17       12 FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF
50004F88: FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF       18        0  1000000
50004FA8:  1000000        0      100    10001  1000000        0        0        0
50004FC8:        0        0        0        0        0        0        0        0
50004FE8:        0        0        0        0        0        0        0        0
50005008:        0        0        0        0        0        1        0 FFFFFFFF
50005028:  1010000        0        0        0        0        0        0        0
50005048:   FF7F7F        1        1        A        1        0        0        0
50005068:        0       14        0        0        0        0        0        0
50005088:       1E        0   20092D 2E2F3A40 5F000000        0        0        0
500050A8:        0        0        0        0        0        0        0        0
500050C8:        0        0        0        0        0        0        0        0
500050E8:        0        0        0        0        0        0        0        0
50005108:        0        0        0        0        0        0        0        0
50005128:        0        0        0        0        0        0        0        0
50005148:        0        0        0        0        0        0        0        0
50005168:        0        0        0        0        0        0        0        0
---- block58  ptr=44E13908  is_malloc=1  length=0x260 ----
44E138C8:        0 FF000000        0 FF000000        0 FF000000        0 FF000000
44E138E8:        0 FF000000        0 FF000000        0        0 FD0110DF 10DFFD01
44E13908: AB1234CD       1E 44E13938 40A426B8 4019D268 44E13B68 44E13824 80000118
44E13928:        1 440787A0 4AFCF0E3 34E794EF 50B916E0 50B92D88 402DCF38        0
44E13948: 43FB0000 50B92E88        0        0        0        0 50B92DE4 50B92DE0
44E13968: 439D0000 50B92E28        0 40187D40        0        0        0        0
44E13988:    10000  1000100        0        3       1E 402DCF94 40187CD8        0
44E139A8:        0        0     1AC8        0        0        0        0      B24
44E139C8:        0        0        0      EE4        0      EE4        0        1
44E139E8:        0 40ABDCBC        3        0        0        0        0     1770
44E13A08:     1770 500047C8        0        0        0        0        0 44E8D0BC
44E13A28: 44C8FA6C 44E13938 43FB56A0        0        0        0 434B86F0        0
44E13A48:        0        0     420A        0        0        0 44E13A38        0
44E13A68:        0        0     4290 44E13938        0        0        0        0
44E13A88: 44E13A38 44E13938        0        0    142D2        0        0        0
44E13AA8: 44E13A38 44E13938        0        0    242D2        0        0        0
44E13AC8:        0        0        0 50B92E88        0        0        0        0
44E13AE8:        0        0        0        0 448DB650 50B92EE8 44E13AE8 50B92E90
44E13B08:        0 43FB60A0        0        0        0        0        0  FFFFFFF
44E13B28:  FFFFFFF        0        0        0        0        0        0        0
44E13B48:        0 44E13B98        0        0        0 BEEFCAFE FD0110DF 10DFFD01
---- block59  ptr=56D40008  is_malloc=0  length=0x100 ----
56D3FFC8:        0        0        0        0        0        0        0        0
56D3FFE8:        0        0        0        0        0        0        0        0
56D40008:        0        0        0        0        0        0        0        0
56D40028:        0        0        0        0        0        0        0        0
56D40048:        0        0        0        0        0        0        0        0
56D40068:        0        0        0        0        0        0        0        0
56D40088:        0        0        0        0        0        0        0        0
56D400A8:        0        0        0        0        0        0        0        0
56D400C8:        0        0        0        0        0        0        0        0
56D400E8:        0        0        0        0        0        0        0        0
---- block60  ptr=40DE0100  is_malloc=0  length=0x100 ----
40DE00C0: 40357AC0 40DE1780   330000 4035B9BC 40DE1780   340000 4035BA70 40DE1780
40DE00E0:   320000 4035BB24        0 3FFD0000 403515D8        0        0        0
40DE0100: 40DE1780 3FFF0000 4035011C        0        0        0 40DE1660    10000
40DE0120: 40357E60 40DE1660    30000 40357A90 40DE1660    50000 40357A90 40DE1660
40DE0140:    A0000 40357A90 40DE1660   180000 40357A90 40DE1660   1A0000 40357A90
40DE0160: 40DE17B0   240000 4035E68C 40DE17B0   250000 4035E9AC 40DE1660   1D0000
40DE0180: 40357A90 40DE17B0   200000 4035011C 40DE1660   220000 40357A90 40DE1948
40DE01A0:   400000 40357A90 40DE17B0   290000 40359880 40DE17B0   2A0000 40359818
40DE01C0: 40DE17B0   2B0000 40359958 40DE17B0   2C0000 40359AB0 40DE17B0   2D0000
40DE01E0: 40359B28 40DE17B0   2E0000 40359BA0 40DE17B0   2F0000 40359C18 40DE17B0
---- block61  ptr=40DE028C  is_malloc=0  length=0x100 ----
40DE024C: 40357A90 40DE1660   470000 40357A90 40DE1690   3B0000 40357A90 40DE1690
40DE026C:   3C0000 40357A90        0 3FFD0000 40350884        0        0        0
40DE028C: 40DE17B0 3FFF0000 40354288        0        0        0 40DE1660    50000
40DE02AC: 40357A90 40DE1660    A0000 40357A90 40DE1660   180000 4035826C 40DE17F8
40DE02CC:   1A0000 40359EF0 40DE17E0   240000 4035E68C 40DE17E0   250000 4035E9AC
40DE02EC: 40DE1990   400000 403572AC 40DE17E0   290000 40359880 40DE17E0   2A0000
40DE030C: 40359818 40DE17E0   2B0000 40359958 40DE17E0   2C0000 40359AB0 40DE17E0
40DE032C:   2D0000 40359B28 40DE17E0   2E0000 40359BA0 40DE17E0   2F0000 40359C18
40DE034C: 40DE17E0   300000 40359C90 40DE17E0   310000 403535BC 40DE1660   370000
40DE036C: 40357800 40DE17F8   3A0000 403583A8 40DE1660   380000 4035840C 40DE1660
---- block62  ptr=40DE03AC  is_malloc=0  length=0x100 ----
40DE038C:   3B0000 40357AC0        0 3FFD0000 40350884        0        0        0
40DE03AC: 40DE17E0 3FFF0000 4035011C        0        0        0        0 3FFE0000
40DE03CC: 403513D4 40DE1660    10000 40357C60 40DE1660    30000 40357898 40DE1660
40DE03EC:    50000 40357898 40DE1660    A0000 40357898 40DE1660   180000 40357898
40DE040C: 40DE1660   1A0000 40357898 40DE1810   240000 4035E68C 40DE1810   250000
40DE042C: 4035E9AC 40DE1810   200000 403519F4 40DE1948   400000 40357898 40DE1810
40DE044C:   290000 40359880 40DE1810   2A0000 40359818 40DE1810   2B0000 40359958
40DE046C: 40DE1810   2C0000 40359AB0 40DE1810   2D0000 40359B28 40DE1810   2E0000
40DE048C: 40359BA0 40DE1810   350000 4035BBD8 40DE1810   360000 4035ACB0 40DE1810
---- block63  ptr=40DE0544  is_malloc=0  length=0x100 ----
40DE0504: 40357898 40DE1810   330000 4035B9BC 40DE1810   340000 4035BA70 40DE1810
40DE0524:   320000 4035BB24        0 3FFD0000 40351450        0        0        0
40DE0544: 40DE1810 3FFF0000 40354264        0        0        0        0 3FFE0000
40DE0564: 40351FE8 40DE1660    10000 40357D58 40DE1660    30000 40357B44 40DE1660
40DE0584:    50000 40357B44 40DE1660    A0000 40357B44 40DE1660   180000 40357B44
40DE05A4: 40DE1660   1A0000 40357B44 40DE1840   240000 4035E68C 40DE1840   250000
40DE05C4: 4035E9AC 40DE1660   1D0000 40357B44 40DE1840   200000 403519F4 40DE1660
40DE05E4:   220000 40357B44 40DE1948   400000 40357B44 40DE1840   290000 40359880
40DE0604: 40DE1840   2B0000 40359958 40DE1840   2C0000 40359AB0 40DE1840   2D0000
40DE0624: 40359B28 40DE1840   2E0000 40359BA0 40DE1840   2F0000 40359C18 40DE1840
---- block64  ptr=40DE06E8  is_malloc=0  length=0x100 ----
40DE06A8: 40357B44 40DE1840   330000 4035B9BC 40DE1840   340000 4035BA70 40DE1840
40DE06C8:   320000 4035BB24        0 3FFD0000 40352064        0        0        0
40DE06E8: 40DE1840 3FFF0000 40354264        0        0        0        0 3FFE0000
40DE0708: 403520F8 40DE1660    10000 40357D58 40DE1660    30000 40357C04 40DE1660
40DE0728:    50000 40357C04 40DE1660    A0000 40357C04 40DE1660   180000 40357C04
40DE0748: 40DE1660   1A0000 40357C04 40DE1870   200000 403519F4 40DE1948   400000
40DE0768: 40357C04 40DE1870   290000 40359880 40DE1870   2B0000 40359958 40DE1870
40DE0788:   2C0000 40359AB0 40DE1870   2D0000 40359B28 40DE1870   2F0000 40359C18
40DE07A8: 40DE1870   300000 40359C90 40DE1870   310000 403535BC 40DE1888   370000
40DE07C8: 40353EF4 40DE1660   3A0000 40357C04 40DE1660   380000 40357C04 40DE1660
---- block65  ptr=40DDF878  is_malloc=0  length=0x100 ----
40DDF838: 403519F4        0        0        0 40DE1648   1F0000 403519F4        0
40DDF858:        0        0 40DE1660 3FFF0000 403542AC        0        0        0
40DDF878:        0 3FFE0000 40350E60 40DE15B8    10000 4035495C 40DE15B8    30000
40DDF898: 4035495C 40DE15B8    50000 40354858 40DE15B8    60000 4035495C 40DE15B8
40DDF8B8:    A0000 4035495C 40DE15A0   180000 4035495C 40DE16F0   1D0000 40355430
40DDF8D8: 40DE16A8   200000 40355990 40DE1678   220000 40355AFC 40DE1660   190000
40DDF8F8: 4035924C 40DE15B8   1A0000 4035495C 40DE1660   240000 4035E534 40DE1660
40DDF918:   260000 4035EBCC 40DE15B8   400000 4035495C 40DE15B8   410000 4035495C
40DDF938: 40DE1660   290000 40359880 40DE1660   2A0000 40359818 40DE1660   2B0000
40DDF958: 40359958 40DE1660   2C0000 40359AB0 40DE1660   2D0000 40359B28 40DE1660
---- block66  ptr=40DDFA64  is_malloc=0  length=0x100 ----
40DDFA24: 4035495C 40DE1648   3E0000 4035495C 40DE1648   3F0000 4035495C 40DE1660
40DDFA44:   320000 4035BB24        0 3FFD0000 40350EB4        0        0        0
40DDFA64: 40DE1660 3FFF0000 403542AC        0        0        0 40DE1660   3C0000
40DDFA84: 40350BE4 40DE1660   3B0000 40350BE4        0        0        0 40DE16D8
40DDFAA4: 3FFF0000 403519F4        0        0        0 40DE16D8 3FFF0000 4035495C
40DDFAC4:        0        0        0        0 3FFE0000 40354A60 40DE1750    D0000
40DDFAE4: 40356C38 40DE1810    E0000 40356EC4 40DE1840    F0000 40357010 40DE1870
40DDFB04:   100000 40357164 40DE1780   140000 40356C38 40DE17B0   130000 40356D90
40DDFB24: 40DE17E0   170000 40356D90 40DE18A0   110000 40358550 40DE18D0   150000
40DDFB44: 40358550 40DE1900   120000 403590F0 40DE1918   160000 403590F0 40DE1A20
---- block67  ptr=40DDFB90  is_malloc=0  length=0x100 ----
40DDFB50: 403590F0 40DE1918   160000 403590F0 40DE1A20   430000 4035AC2C 40DE1A38
40DDFB70:   440000 4035B230 40DE1A50   470000 4035D560        0        0        0
40DDFB90: 40DE1660    10000 403562CC 40DE1660    30000 403562CC 40DE1660    50000
40DDFBB0: 403562CC 40DE1660    A0000 403562CC 40DE1660   180000 4035661C 40DE16F0
40DDFBD0:   190000 4035924C 40DE1660   210000 40356948 40DE1660   1A0000 403562CC
40DDFBF0: 40DE16F0   240000 4035E68C 40DE16F0   250000 4035E9AC 40DE1660   400000
40DDFC10: 403562CC 40DE16F0   290000 40359880 40DE16F0   2A0000 40359818 40DE16F0
40DDFC30:   2B0000 40359958 40DE16F0   2C0000 40359AB0 40DE16F0   2D0000 40359B28
40DDFC50: 40DE16F0   2E0000 40359BA0 40DE16F0   350000 4035BBD8 40DE16F0   360000
40DDFC70: 4035ACB0 40DE16F0   2F0000 40359C18 40DE16F0   300000 40359C90 40DE16F0
---- block68  ptr=40DDFD4C  is_malloc=0  length=0x100 ----
40DDFD0C: 40356174 40DE1660   3F0000 40356174 40DE16F0   320000 4035BB24 40DE1738
40DDFD2C:   3D0000 40356BCC        0 3FFD0000 40350884        0        0        0
40DDFD4C: 40DE16F0 3FFF0000 4035011C        0        0        0 40DE16F0   280000
40DDFD6C: 4035011C 40DE1690   3B0000 40356174        0        0        0 40DE16F0
40DDFD8C:   280000 4035011C 40DE1708   3D0000 40358B1C        0        0        0
40DDFDAC:        0 3FFE0000 4035124C 40DE1660    10000 40357C60 40DE1660    30000
40DDFDCC: 40357800 40DE1660    50000 40357800 40DE1660    60000 40357800 40DE1660
40DDFDEC:    A0000 40357800 40DE1660   180000 40357800 40DE1660   1A0000 40357800
40DDFE0C: 40DE1750   240000 4035E68C 40DE1750   250000 4035E9AC 40DE1660   1D0000
40DDFE2C: 40357800 40DE1750   200000 4035011C 40DE1660   220000 40357800 40DE1948
---- block69  ptr=5000EE10  is_malloc=1  length=0x618 ----
5000EDD0:        0        0        0        0 402F4258        0 5000EDD8        0
5000EDF0:        0        0        0        0        0        0 FD0110DF 10DFFD01
5000EE10: AB1234CD FFFFFFFE        0 40A3C4B8 4017EAC4 5000F428 5000E80C 800002F4
5000EE30:        1 44078710        0        0 448E11E8        0        0        0
5000EE50:        0       1E       46   100010       46        0        0       46
5000EE70:       10    10000 440799B0 52656720 46756E63 74696F6E 20430000 5000EFB0
5000EE90: 5000F410        0 5000EFB0 5000EFC0 5000EFD0 5000EFE0 5000EFF0 5000F000
5000EEB0: 5000F010 5000F020 5000F030 5000F040 5000F050 5000F060 5000F070 5000F080
5000EED0: 5000F090 5000F0A0 5000F0B0 5000F0C0 5000F0D0 5000F0E0 5000F0F0 5000F100
5000EEF0: 5000F110 5000F120 5000F130 5000F140 5000F150 5000F160 5000F170 5000F180
5000EF10: 5000F190 5000F1A0 5000F1B0 5000F1C0 5000F1D0 5000F1E0 5000F1F0 5000F200
5000EF30: 5000F210 5000F220 5000F230 5000F240 5000F250 5000F260 5000F270 5000F280
5000EF50: 5000F290 5000F2A0 5000F2B0 5000F2C0 5000F2D0 5000F2E0 5000F2F0 5000F300
5000EF70: 5000F310 5000F320 5000F330 5000F340 5000F350 5000F360 5000F370 5000F380
5000EF90: 5000F390 5000F3A0 5000F3B0 5000F3C0 5000F3D0 5000F3E0 5000F3F0 5000F400
5000EFB0:        0        0        0        0        0        0        0        0
5000EFD0:        0        0        0        0        0        0        0        0
5000EFF0:        0        0        0        0        0        0        0        0
5000F010:        0        0        0        0        0        0        0        0
5000F030:        0        0        0        0        0        0        0        0
5000F050:        0        0        0        0        0        0        0        0
5000F070:        0        0        0        0        0        0        0        0
5000F090:        0        0        0        0        0        0        0        0
5000F0B0:        0        0        0        0        0        0        0        0
5000F0D0:        0        0        0        0        0        0        0        0
5000F0F0:        0        0        0        0        0        0        0        0
5000F110:        0        0        0        0        0        0        0        0
5000F130:        0        0        0        0        0        0        0        0
5000F150:        0        0        0        0        0        0        0        0
5000F170:        0        0        0        0        0        0        0        0
5000F190:        0        0        0        0        0        0        0        0
5000F1B0:        0        0        0        0        0        0        0        0
5000F1D0:        0        0        0        0        0        0        0        0
5000F1F0:        0        0        0        0        0        0        0        0
5000F210:        0        0        0        0        0        0        0        0
5000F230:        0        0        0        0        0        0        0        0
5000F250:        0        0        0        0        0        0        0        0
5000F270:        0        0        0        0        0        0        0        0
5000F290:        0        0        0        0        0        0        0        0
5000F2B0:        0        0        0        0        0        0        0        0
5000F2D0:        0        0        0        0        0        0        0        0
5000F2F0:        0        0        0        0        0        0        0        0
5000F310:        0        0        0        0        0        0        0        0
5000F330:        0        0        0        0        0        0        0        0
5000F350:        0        0        0        0        0        0        0        0
5000F370:        0        0        0        0        0        0        0        0
5000F390:        0        0        0        0        0        0        0        0
5000F3B0:        0        0        0        0        0        0        0        0
5000F3D0:        0        0        0        0        0        0        0        0
5000F3F0:        0        0        0        0        0        0        0        0
5000F410:        0        0        0        0 FD0110DF 10DFFD01
---- block70  ptr=800002F4  is_malloc=0  length=0x100 ----
800002B4:        0        0        0        0        0        0        0        0
800002D4:        0        0        0        0        0        0        0        0
800002F4:        0        0        0        0        0        0        0        0
80000314:        0        0        0        0        0        0        0        0
80000334:        0        0        0        0        0        0        0        0
80000354:        0        0        0        0        0        0        0        0
80000374:        0        0        0        0        0        0        0        0
80000394:        0        0        0        0        0        0        0        0
800003B4:        0        0        0        0        0        0        0        0
800003D4:        0        0        0        0        0        0        0        0
---- block71  ptr=448E0918  is_malloc=1  length=0x618 ----
448E08D8: 409C0174 448E0918 448E067C 80000010        1 440787A0  D0D0D0D  D0D0D0D
448E08F8: 50009988        9        0        0        0        0 FD0110DF 10DFFD01
448E0918: AB1234CD FFFFFFFE        0 40A3C4A4 4017EA98 448E0F30 448E08DC 800002F4
448E0938:        1 440787A0  D0D0D0D  D0D0D0D 5000EE40        0        0        0
448E0958:        0       1E       46   100010       39        D        D       39
448E0978:       10    10000 440799B0 52656720 46756E63 74696F6E 20690000 448E0AB8
448E0998: 448E0F18        0 448E0AB8 448E0AC8 448E0AD8 448E0AE8 448E0AF8 448E0B08
448E09B8: 448E0B18 448E0B28 448E0B38 448E0B48 448E0B58 448E0B68 448E0B78 448E0B88
448E09D8: 448E0B98 448E0BA8 448E0BB8 448E0BC8 448E0BD8 448E0BE8 448E0BF8 448E0C08
448E09F8: 448E0C18 448E0C28 448E0C38 448E0C48 448E0C58 448E0C68 448E0C78 448E0C88
448E0A18: 448E0C98 448E0CA8 448E0CB8 448E0CC8 448E0CD8 448E0CE8 448E0CF8 448E0D08
448E0A38: 448E0D18 448E0D28 448E0D38 448E0D48 448E0D58 448E0D68 448E0D78 448E0D88
448E0A58: 448E0D98 448E0DA8 448E0DB8 448E0DC8 448E0DD8 448E0DE8 448E0DF8 448E0E08
448E0A78: 448E0E18 448E0E28 448E0E38 448E0E48 448E0E58 448E0E68 448E0E78 448E0E88
448E0A98: 448E0E98 448E0EA8 448E0EB8 448E0EC8 448E0ED8 448E0EE8 448E0EF8 448E0F08
448E0AB8:        0        0        0        0        0        0        0        0
448E0AD8:        0        0        0        0        0        0        0        0
448E0AF8:        0        0        0        0        0        0        0        0
448E0B18:        0        0        0        0        0        0        0        0
448E0B38:        0        0        0        0        0        0        0        0
448E0B58:        0        0        0        0        0        0        0        0
448E0B78:        0        0        0        0        0        0        0        0
448E0B98:        0        0        0        0        0        0        0        0
448E0BB8:        0        0        0        0        0        0        0        0
448E0BD8:        0        0        0        0        0        0        0        0
448E0BF8:        0        0        0        0        0        0        0        0
448E0C18:        0        0        0        0        0        0        0        0
448E0C38:        0        0        0        0        0        0        0        0
448E0C58:        0        0        0        0        0        0        0        0
448E0C78:        0        0        0        0        0        0        0        0
448E0C98:        0        0        0        0        0        0        0        0
448E0CB8:        0        0        0        0        0        0        0        0
448E0CD8:        0        0        0        0        0        0        0        0
448E0CF8:        0        0        0        0        0        0        0        0
448E0D18:        0        0        0        0        0        0        0        0
448E0D38:        0        0        0        0        0        0        0        0
448E0D58:        0        0        0        0        0        0        0        0
448E0D78:        0        0        0        0        0        0        0        0
448E0D98:        0        0        0        0        0        0        0        0
448E0DB8:        0        0        0        0        0        0        0        0
448E0DD8:        0        0        0        0        0        0        0        0
448E0DF8:        0        0        0        0        0        0        0        0
448E0E18:        0        0        0        0        0        0        0        0
448E0E38:        0        0        0        0        0        0 40317A08        0
448E0E58:        0 448E0E68 402594EC        0 448E0E58 448E0E88 400C0FD0        0
448E0E78:        0 448E0E98 40861F04        0 448E0E68 448E0ED8 406F0D78        0
448E0E98: 448E0E78 448E0EA8 4018C9C0        0 448E0E98 448E0EB8 400D5104        0
448E0EB8: 448E0EA8 448E0EC8 400D5014        0 448E0EB8 448E0EE8 400D9070        0
448E0ED8: 448E0E88        0 400D96F4        0 448E0EC8 448E0EF8 40105CCC        0
448E0EF8: 448E0EE8 448E0F08 4010B03C        0 448E0EF8        0 4010A26C        0
448E0F18:        0        0        0        0 FD0110DF 10DFFD01
---- block72  ptr=50C75C80  is_malloc=1  length=0x320 ----
50C75C40:        0        0        0        0        0        0        0        0
50C75C60:        0        0        0        0        0        0 FD0110DF 10DFFD01
50C75C80: AB1234CD       3E 44E8CFD0 5000E864 4017EBAC 50C75FA0 50C65C5C 80000178
50C75CA0:        1 44078710        0        0        0 50C5C998 5000E828        0
50C75CC0: 5000E828       1A       20    C0010        1        0        0        0
50C75CE0:       10    30000 440799B0 52656720 46756E63 74696F6E 20310000 50C75D88
50C75D00: 50C75F88        0 50C75D88 50C75D98 50C75DA8 50C75DB8 50C75DC8 50C75DD8
50C75D20: 50C75DE8 50C75DF8 50C75E08 50C75E18 50C75E28 50C75E38 50C75E48 50C75E58
50C75D40: 50C75E68 50C75E78 50C75E88 50C75E98 50C75EA8 50C75EB8 50C75EC8 50C75ED8
50C75D60: 50C75EE8 50C75EF8 50C75F08 50C75F18 50C75F28 50C75F38 50C75F48 50C75F58
50C75D80: 50C75F68 50C75F78        0        0        0        0 5000ED08       20
50C75DA0: 409490F4        0        0        0 406AD6B0        0 50C75E08       2A
50C75DC0: 40949248        0        0        0 406B1E3C        0 50C75E68        F
50C75DE0: 406A9AE0        0        0       30 406AE430        0 50BB6678       2C
50C75E00: 406B1384        0 50C75DF8       2B 406B12D0        0 44D239C0       25
50C75E20: 406B1208        0 50C75D98       1F 406A88D4        0 50BB64E8       16
50C75E40: 406AEB68        0 50C75E28       1B 4094931C        0 50C75E38       15
50C75E60: 409492B4        0 50C75E58       10 406B2C1C        0 50BADB48        7
50C75E80: 406AE588        0 50C75E78        6 406ADFC0        0 50C75E88        5
50C75EA0: 406AE4B8        0 50C75E98        4 406ADA9C        0        0        0
50C75EC0: 406AF01C        0        0        0 406B12C8        0 50C75EC8        0
50C75EE0:        0        0        0        0 406AFC08        0        0        0
50C75F00: 406AFBCC        0 50C75EF8        0        0        0        0        0
50C75F20: 406B1098        0 50C75F18        0        0        0        0        0
50C75F40: 406B0E80        0 50C75F38        0        0        0        0        0
50C75F60: 406B0D34        0 50C75F58        0        0        0        0        0
50C75F80: 406AF6D0        0        0        0        0        0 FD0110DF 10DFFD01
---- block73  ptr=5001F718  is_malloc=1  length=0x618 ----
5001F6D8:        0        0        0        0 40696654        0        0        B
5001F6F8: FFFFFFFF        0        0        0        0 44E808A8 FD0110DF 10DFFD01
5001F718: AB1234CD FFFFFFFE        0 5000E864 4017EBAC 5001FD30 5001F6A4 800002F4
5001F738:        1 44078710        0        0        0        0 50245658        0
5001F758: 5000E828       1A       46    C0010        0        0        0        0
5001F778:       10    30000 440799B0 52656720 46756E63 74696F6E 20310000 5001F8B8
5001F798: 5001FD18        0 5001F8B8 5001F8C8 5001F8D8 5001F8E8 5001F8F8 5001F908
5001F7B8: 5001F918 5001F928 5001F938 5001F948 5001F958 5001F968 5001F978 5001F988
5001F7D8: 5001F998 5001F9A8 5001F9B8 5001F9C8 5001F9D8 5001F9E8 5001F9F8 5001FA08
5001F7F8: 5001FA18 5001FA28 5001FA38 5001FA48 5001FA58 5001FA68 5001FA78 5001FA88
5001F818: 5001FA98 5001FAA8 5001FAB8 5001FAC8 5001FAD8 5001FAE8 5001FAF8 5001FB08
5001F838: 5001FB18 5001FB28 5001FB38 5001FB48 5001FB58 5001FB68 5001FB78 5001FB88
5001F858: 5001FB98 5001FBA8 5001FBB8 5001FBC8 5001FBD8 5001FBE8 5001FBF8 5001FC08
5001F878: 5001FC18 5001FC28 5001FC38 5001FC48 5001FC58 5001FC68 5001FC78 5001FC88
5001F898: 5001FC98 5001FCA8 5001FCB8 5001FCC8 5001FCD8 5001FCE8 5001FCF8 5001FD08
5001F8B8: 50245920        0        0        0        0        0 400883F4        0
5001F8D8:        0        0 400CE50C        0 5001F8D8        0 400CE2FC        0
5001F8F8: 5001F8E8        0 400CE49C        0 5001F8F8        0 400CE3B0        0
5001F918: 5001F908        0 400CE350        0 5001F918        0        0        0
5001F938: 50BADC38        0 400DA74C        0 5001F938        0 400DA310        0
5001F958: 5001F948        0 400DA1D0        0 5001F958        0 400D9FE4        0
5001F978: 5001F968        0        0        0        0        0 400DBC60        0
5001F998: 5001F988        0        0        0 502457F0        0 401084B8        0
5001F9B8: 50A97B78        0 4025E4A0        0 44D23910        0 4025E510        0
5001F9D8: 5001F9C8        0        0        0 44B56F08        0 40133B44        0
5001F9F8: 5001F9E8        0        0        0 5001F9A8        0 400A9CA4        0
5001FA18: 50245800        0 400A9C7C        0 5001FA08        0 4008F9FC        0
5001FA38: 5001FA18        0 4008F9D8        0 5001FA28        0 40090484        0
5001FA58: 5001FA38        0 40090460        0 5001F8C8        0 400E3870        0
5001FA78: 5001FA68        0        0        0 5001FA48        0 4059FD28        0
5001FA98: 5001FA88        0        0        0 5001FA58        0 4059FD04        0
5001FAB8: 5001FAA8        0        0        0 50B95598       21 4059F140        0
5001FAD8:        0        0 4059E5AC        0 5001FAD8        0        0        0
5001FAF8:        0        0 4059E698        0 5001FAF8        0        0        0
5001FB18:        0        0 4059E4F4        0 5001FB18        0        0        0
5001FB38:        0        0 4059E400        0 5001FB38        0        0        0
5001FB58: 44D238F0        0 4059E8A0        0 5001FB58        0        0        0
5001FB78: 44D23900        0 4059E850        0 5001FB78        0        0        0
5001FB98:        0        7 4059EFB0        0        0        0 4059EC9C        0
5001FBB8: 5001FBA8        0        0        0        0        0 4059EC2C        0
5001FBD8: 5001FBC8        0        0        0        0        0 4059EA28        0
5001FBF8: 5001FBE8        0        0        0        0        0 4059E828        0
5001FC18: 5001FC08        0        0        0        0        0 4059E800        0
5001FC38: 5001FC28        0        0        0        0        0 4059E7D8        0
5001FC58: 5001FC48        0        0        0        0        0 4059E770        0
5001FC78: 5001FC68        0        0        0        0        0 4059E38C        0
5001FC98: 5001FC88        0        0        0        0        0 4059E320        0
5001FCB8: 5001FCA8        0        0        0        0        0 4059CEC4        0
5001FCD8: 5001FCC8        0        0        0        0        0 4059D488        0
5001FCF8: 5001FCE8        0        0        0        0        0 4059D434        0
5001FD18:        0        0        0        0 FD0110DF 10DFFD01
---- block74  ptr=50BB7798  is_malloc=1  length=0xA00 ----
50BB7758:        0        0        0        0        0        0        0        0
50BB7778:        0        0        0        0        0        0 FD0110DF 10DFFD01
50BB7798: AB1234CD FFFFFFFE        0 40A14BFC 4029E9E8 50BC5BD0 50BB6774 80007204
50BB77B8:        1 44078710        0        0 2F000000        0       11        0
50BB77D8:        0        0        0        0        0      256        0        0
50BB77F8:        0        0  C80000C        0        0        0        0        0
50BB7818:        0        0        0        0        0        0        0        0
50BB7838:        0        0        0        0        0        0        0        0
50BB7858:        0        0        0        0        0        0        0        0
50BB7878:        0        0        0        0        0        0        0        0
50BB7898:        0        0        0        0        0        0        0        0
50BB78B8:        0        0        0        0        0        0        0        0
50BB78D8:        0        0        0        0        0        0        0        0
50BB78F8:        0        0        0        0        0        0        0        0
50BB7918:        0        0        0        0        0        0        0        0
50BB7938:        0        0        0        0        0        0        0        1
50BB7958:        0        0        0        0        0        0        0        0
50BB7978:        0        0        0        0        0        0 43364B32 32327E31
50BB7998: 42494E20    E7198 4B3F4C3F     583C 3A430002  25A141C        0        0
50BB79B8:        0        0        0        0        0        0        0        0
50BB79D8:        0        0        0        0        0        0        0        0
50BB79F8:        0  3000000      256   E00000 63366B32 32322D70 6B397376 2D6D7A2E
50BB7A18: 3132322D 31382E53 58443762 2E62696E        0        0        0        0
50BB7A38:        0        0        0        0        0        0        0        0
50BB7A58:        0        0        0        0        0        0        0        0
50BB7A78:        0        0        0        0        0        0        0        0
50BB7A98:        0        0        0        0        0        0        0        0
50BB7AB8:        0        0        0        0        0        0        0        0
50BB7AD8:        0        0        0        0        0        0        0        0
50BB7AF8:        0        0        0        0        0        0        0        0
50BB7B18:        0        1        1        0        0        0        0        0
50BB7B38:        0        0        0        0    20000    20000        0        0
50BB7B58:        0        0        0        0        0        0        0        0
50BB7B78:        0        0        0        0        0        0        0        0
50BB7B98:        0        0        0        0        0        0        0        0
50BB7BB8:        0        0        0        0        0        0        0        0
50BB7BD8:        0        0        0        0        0        0        0        0
50BB7BF8:        0        0        0        0        0        0        0        0
50BB7C18:        0        0        0        0        0        0        0        0
50BB7C38:        0        0        0        0        0        0        0        0
50BB7C58:        0        0        0        0        0        0        0        0
50BB7C78:        0        0        0        0        0        0        0        0
50BB7C98:        0        0        0        0        0        0        0        0
50BB7CB8:        0        0        0        0        0        0        0        0
50BB7CD8:        0        0        0        0        0        0        0        0
50BB7CF8:        0        0        0        0        0        0        0        0
50BB7D18:        0        0        0        0        0        0        0        0
50BB7D38:        0        0        0        0        0        0        0        0
50BB7D58:        0        0        0        0        0        0        0        0
50BB7D78:        0        0        0        0        0        0        0        0
50BB7D98:        0        0        0        0        0        0        0        0
50BB7DB8:        0        0        0        0        0        0        0        0
50BB7DD8:        0        0        0        0        0        0        0        0
50BB7DF8:        0        0        0        0        0        0        0        0
50BB7E18:        0        0        0        0        0        0        0        0
50BB7E38:        0        0        0        0        0        0        0        0
50BB7E58:        0        0        0        0        0        0        0        0
50BB7E78:        0        0        0        0        0        0        0        0
50BB7E98:        0        0        0        0        0        0        0        0
50BB7EB8:        0        0        0        0        0        0        0        0
50BB7ED8:        0        0        0        0        0        0        0        0
50BB7EF8:        0        0        0        0        0        0        0        0
50BB7F18:        0        0        0        0        0        0        0        0
50BB7F38:        0        0        0        0        0        0        0        0
50BB7F58:        0        0        0        0        0        0        0        0
50BB7F78:        0        0        0        0        0        0        0        0
50BB7F98:        0        0        0        0        0        0        0        0
50BB7FB8:        0        0        0        0        0        0        0        0
50BB7FD8:        0        0        0        0        0        0        0        0
50BB7FF8:        0        0        0        0        0        0        0        0
50BB8018:        0        0        0        0        0        0        0        0
50BB8038:        0        0        0        0        0        0        0        0
50BB8058:        0        0        0        0        0        0        0        0
50BB8078:        0        0        0        0        0        0        0        0
50BB8098:        0        0        0        0        0        0        0        0
50BB80B8:        0        0        0        0        0        0        0        0
50BB80D8:        0        0        0        0        0        0        0        0
50BB80F8:        0        0        0        0        0        0        0        0
50BB8118:        0        0        0        0        0        0        0        0
50BB8138:        0        0        0        0        0        0        0        0
50BB8158:        0        0        0        0        0        0        0        0
50BB8178:        0        0        0        0        0        0        0        0
---- block75  ptr=80000804  is_malloc=0  length=0x100 ----
800007C4:        0        0        0        0        0        0        0        0
800007E4:        0        0        0        0        0        0        0        0
80000804:        0        0        0        0        0        0        0        0
80000824:        0        0        0        0        0        0        0        0
80000844:        0        0        0        0        0        0        0        0
80000864:        0        0        0        0        0        0        0        0
80000884:        0        0        0        0        0        0        0        0
800008A4:        0        0        0        0        0        0        0        0
800008C4:        0        0        0        0        0        0        0        0
800008E4:        0        0        0        0        0        0        0        0
---- block76  ptr=44A10E90  is_malloc=1  length=0x320 ----
44A10E50:        0        0        0        0        0        0        0        0
44A10E70:        0        0        0        0        0        0 FD0110DF 10DFFD01
44A10E90: AB1234CD FFFFFFFE        0 40A1AAD0 401053A4 44A111B0 44A10B84 80000178
44A10EB0:        1 440787A0 A32AB65F 93B8AE01 5014ED50        0        0        0
44A10ED0:        0        0 FFFF0000        0  81BD664  81BD6E8        0        0
44A10EF0:        0  81BD6E8        0        0        0        0        0        0
44A10F10:        0        0        0        0        0        0        0        0
44A10F30:        0        0        0        0        0        0        0        0
44A10F50:        0        0        0        0        0        0        0        0
44A10F70:        0        0        0        0        0        0    10000 448E7930
44A10F90:        0        0        0        0        0        0        0        0
44A10FB0:        0        0        0        0        0      858        0        0
44A10FD0:        0        0        0        0        0        0        0        0
44A10FF0:        0        0        0        0        0        0        0        0
44A11010:        0        0        0        0        0        0        0        0
44A11030:        0        0        0        0        0        0        0        0
44A11050:        0        0        0        0        0        0        0        0
44A11070:        0        0        0        0        0        0        0        0
44A11090:        0        0        0        0        0        0        0        0
44A110B0:        0        0        0        0        0        0 FFFFFFFF FFFFFFFF
44A110D0: FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF        0
44A110F0:        0        0        0        0        0        0        0        0
44A11110:        0        0        0        0        0        0        0        0
44A11130:        0        0        0        0        0        0        0        0
44A11150:        0        0        0        0        0        0        0        0
44A11170:        0        0        0        0        0        0        0        0
44A11190:        0        0        0        0        0        0 FD0110DF 10DFFD01
---- block77  ptr=44BA0000  is_malloc=0  length=0x100 ----
44B9FFC0:        0        0        0 44B9D8B8 44B9FF30        0        0        0
44B9FFE0:        0        0        0        0        0        0        0        0
44BA0000:        0        0        0        0        0        0        0        0
44BA0020:        0        0        0     8000        0        0        0        0
44BA0040:        0        0        0        0        0        0        0        0
44BA0060:        0        0        0 44B9D8B8 44B9FFD0        0        0        0
44BA0080:        0        0        0        0        0        0        0        0
44BA00A0:        0        0        0        0        0        0        0        0
44BA00C0:        0        0        0     8000        0        0        0        0
44BA00E0:        0        0        0        0        0        0        0        0
---- block78  ptr=44BB0800  is_malloc=0  length=0x100 ----
44BB07C0:        0        0        0        0        0        0        0        0
44BB07E0:        0     8000        0        0        0        0        0        0
44BB0800:        0        0        0        0        0        0        0        0
44BB0820:        0 44BAD8F0 44BB0788        0        0        0        0        0
44BB0840:        0        0        0        0        0        0        0        0
44BB0860:        0        0        0        0        0        0        0        0
44BB0880:        0     8000        0        0        0        0        0        0
44BB08A0:        0        0        0        0        0        0        0        0
44BB08C0:        0 44BAD8F0 44BB0828        0        0        0        0        0
44BB08E0:        0        0        0        0        0        0        0        0
---- block79  ptr=44A12790  is_malloc=1  length=0x320 ----
44A12750:        0        0        0        0        0        0        0        0
44A12770:        0        0        0        0        0        0 FD0110DF 10DFFD01
44A12790: AB1234CD FFFFFFFE        0 40A1AAD0 401053A4 44A12AB0 44A12484 80000178
44A127B0:        1 440787A0 EB6635FB 449FA089 50150650        0        0        0
44A127D0:        0        0 FFFF0000        0  81BF864  81BF8E8        0        0
44A127F0:        0  81BF8E8        0        0        0        0        0        0
44A12810:        0        0        0        0        0        0        0        0
44A12830:        0        0        0        0        0        0        0        0
44A12850:        0        0        0        0        0        0        0        0
44A12870:        0        0        0        0        0        0    10000 448E7930
44A12890:        0        0        0        0        0        0        0        0
44A128B0:        0        0        0        0        0      85C        0        0
44A128D0:        0        0        0        0        0        0        0        0
44A128F0:        0        0        0        0        0        0        0        0
44A12910:        0        0        0        0        0        0        0        0
44A12930:        0        0        0        0        0        0        0        0
44A12950:        0        0        0        0        0        0        0        0
44A12970:        0        0        0        0        0        0        0        0
44A12990:        0        0        0        0        0        0        0        0
44A129B0:        0        0        0        0        0        0 FFFFFFFF FFFFFFFF
44A129D0: FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF        0
44A129F0:        0        0        0        0        0        0        0        0
44A12A10:        0        0        0        0        0        0        0        0
44A12A30:        0        0        0        0        0        0        0        0
44A12A50:        0        0        0        0        0        0        0        0
44A12A70:        0        0        0        0        0        0        0        0
44A12A90:        0        0        0        0        0        0 FD0110DF 10DFFD01
---- block80  ptr=44BA1800  is_malloc=0  length=0x100 ----
44BA17C0:        0        0        0        0        0        0        0        0
44BA17E0:        0        0        0     8000        0        0        0        0
44BA1800:        0        0        0        0        0        0        0        0
44BA1820:        0        0        0 44B9D8B8 44BA1790        0        0        0
44BA1840:        0        0        0        0        0        0        0        0
44BA1860:        0        0        0        0        0        0        0        0
44BA1880:        0        0        0     8000        0        0        0        0
44BA18A0:        0        0        0        0        0        0        0        0
44BA18C0:        0        0        0 44B9D8B8 44BA1830        0        0        0
44BA18E0:        0        0        0        0        0        0        0        0
---- block81  ptr=439B7FF8  is_malloc=0  length=0x100 ----
439B7FB8:        0        0        0        0 40A89900 40000000 4C000000        0
439B7FD8:  C000000        C        2        1        1        0        0        0
439B7FF8: 439B8050 44078710 439B7FF8 43FB34F0        0        0        0        0
439B8018:        0 439B7FA0 40A8999C 80000000 8C000000 40000000  C000000        4
439B8038:        2        3        1        0        0        0        0 439B7FF8
439B8058: 439B8050 43FB34F0        0        0        0        0        0 439B7FA0
439B8078: 40A899A4 A0000000 AC000000 40000000  C000000        4        2        3
439B8098:        1        0        0        0        0        0        0        0
439B80B8:        0        0        0        0        0        0        0        0
439B80D8:        0        0        0        0        0        0        0        0
---- block82  ptr=43FB34F0  is_malloc=0  length=0x100 ----
43FB34B0: 43FB34A0 43FB3620        B    10000        0        0 40A425F0 4019C580
43FB34D0: 40DBEBEC        0 448D3128        0 50A97AB8        0        0        0
43FB34F0: 44078640 439B8050 440799C0        0 43FB34F0 43FB3620        1    10000
43FB3510:        9        0 40A3BF98 401674FC 40DBEBEC        0 448D5AA0        0
43FB3530:        0 50008EA8        0  10624DC        1        0        0        0
43FB3550:        0 440799B0        0 44078800        0        0 440799B0        0
43FB3570: 440799B0 440799B0        0        0        0        0        0        7
43FB3590:        0 50A974D8 44B56DB8 44C90E08 44B0E808        0 4017EA08 4017EA08
43FB35B0:        0       18        0        0        0        0 43FB39C8 43FB34A8
43FB35D0: 43FB35C0 43FB3620        C    10000        0        0 40A42604 4019C580
---- block83  ptr=440799B0  is_malloc=0  length=0x108 ----
44079970:        0        0        0        0        0        0        0        0
44079990:        0        0        0        0        0        0        0        0
440799B0: 40A89924        1 440787B0 44078720 44078810 43FB34F8 440799B8 43FB3620
440799D0:        2    10000        2        0 40A89924 401674FC 40DBEBEC        0
440799F0:  B27CE7C    70000  B27CE7C  FFFFFD0 1773DC60        8        0        0
44079A10:        0        0 448C23A0        0        0    18000     8000        0
44079A30:        0        0        0        0        0        0        0 44079C74
44079A50: 44079E90       13       10        0       10        0       37 44079A70
44079A70:        0        0        0        0        0 44079A6C        0        0
44079A90:        0       38       11       38       38       5F 44079AAC        0
44079AB0:        0        0
---- block84  ptr=50000000  is_malloc=1  length=0xA00 ----
50000000: AB1234CD FFFFFFFE        0 40A3E164 409BFEA4 50003238 44E9046C 80001904
50000020:        1 44078710        0        0        0        0        0        0
50000040:        0        0        0        0        0        0        0        0
50000060:        0        0        0        0        0        0        0        0
50000080:        0        0        0        0        0        0        0        0
500000A0:        0        0        0        0        0        0        0        0
500000C0:        0        0        0        0        0        0        0        0
500000E0:        0        0        0        0        0        0        0        0
50000100:        0        0        0        0        0        0        0        0
50000120:        0        0        0        0        0        0        0        0
50000140:        0        0        0        0        0        0        0        0
50000160:        0        0        0        0        0        0        0        0
50000180:        0        0        0        0        0        0        0        0
500001A0:        0        0        0        0        0        0        0        0
500001C0:        0        0        0        0        0        0        0        0
500001E0:        0        0        0        0        0        0        0        0
50000200:        0        0        0        0        0        0        0        0
50000220:        0        0        0        0        0        0        0        0
50000240:        0        0        0        0        0        0        0        0
50000260:        0        0        0        0        0        0        0        0
50000280:        0        0        0        0        0        0        0        0
500002A0:        0        0        0        0        0        0        0        0
500002C0:        0        0        0        0        0        0        0        0
500002E0:        0        0        0        0        0        0        0        0
50000300:        0        0        0        0        0        0        0        0
50000320:        0        0        0        0        0        0        0        0
50000340:        0        0        0        0        0        0        0        0
50000360:        0        0        0        0        0        0        0        0
50000380:        0        0        0        0        0        0        0        0
500003A0:        0        0        0        0        0        0        0        0
500003C0:        0        0        0        0        0        0        0        0
500003E0:        0        0        0        0        0        0        0        0
50000400:        0        0        0        0        0        0        0        0
50000420:        0        0        0        0        0        0        0        0
50000440:        0        0        0        0        0        0        0        0
50000460:        0        0        0        0        0        0        0        0
50000480:        0        0        0        0        0        0        0        0
500004A0:        0        0        0        0        0        0        0        0
500004C0:        0        0        0        0        0        0        0        0
500004E0:        0        0        0        0        0        0        0        0
50000500:        0        0        0        0        0        0        0        0
50000520:        0        0        0        0        0        0        0        0
50000540:        0        0        0        0        0        0        0        0
50000560:        0        0        0        0        0        0        0        0
50000580:        0        0        0        0        0        0        0        0
500005A0:        0        0        0        0        0        0        0        0
500005C0:        0        0        0        0        0        0        0        0
500005E0:        0        0        0        0        0        0        0        0
50000600:        0        0        0        0        0        0        0        0
50000620:        0        0        0        0        0        0        0        0
50000640:        0        0        0        0        0        0        0        0
50000660:        0        0        0        0        0        0        0        0
50000680:        0        0        0        0        0        0        0        0
500006A0:        0        0        0        0        0        0        0        0
500006C0:        0        0        0        0        0        0        0        0
500006E0:        0        0        0        0        0        0        0        0
50000700:        0        0        0        0        0        0        0        0
50000720:        0        0        0        0        0        0        0        0
50000740:        0        0        0        0        0        0        0        0
50000760:        0        0        0        0        0        0        0        0
50000780:        0        0        0        0        0        0        0        0
500007A0:        0        0        0        0        0        0        0        0
500007C0:        0        0        0        0        0        0        0        0
500007E0:        0        0        0        0        0        0        0        0
50000800:        0        0        0        0        0        0        0        0
50000820:        0        0        0        0        0        0        0        0
50000840:        0        0        0        0        0        0        0        0
50000860:        0        0        0        0        0        0        0        0
50000880:        0        0        0        0        0        0        0        0
500008A0:        0        0        0        0        0        0        0        0
500008C0:        0        0        0        0        0        0        0        0
500008E0:        0        0        0        0        0        0        0        0
50000900:        0        0        0        0        0        0        0        0
50000920:        0        0        0        0        0        0        0        0
50000940:        0        0        0        0        0        0        0        0
50000960:        0        0        0        0        0        0        0        0
50000980:        0        0        0        0        0        0        0        0
500009A0:        0        0        0        0        0        0        0        0
500009C0:        0        0        0        0        0        0        0        0
500009E0:        0        0        0        0        0        0        0        0
50000A00:        0        0        0        0        0        0        0        0
50000A20:        0        0        0        0        0        0        0        0
---- block85  ptr=44079780  is_malloc=0  length=0x100 ----
44079740:        0        0        0        0        0        0        0        0
44079760:        0        0        0        0        0  89DFA90        0        0
44079780: 440787A0 440786B0 44079780 43FB34F0        0        0        0        0
440797A0: 439B7FA0        0 40A89918 434A51E0 448C23A0        0  141D1C0        4
440797C0:        D        2        1        0        0        0        0        0
440797E0:        0        0        0        0        0        0        0        0
44079800:        0        0        0        0        0        0        0        0
44079820:        0        0        0        0        0        0        0        0
44079840:        0        0        0        0        0        0        0        0
44079860:        0        0        0        0        0        0        0        0
---- block86  ptr=50BADD60  is_malloc=1  length=0x260 ----
50BADD20: 40729740        0 44E807D0        0 40729904        0        0        0
50BADD40: 40722DF8        0        0        0        0        0 FD0110DF 10DFFD01
50BADD60: AB1234CD       29 50BADD90 40A426B8 4019D268 50BADFC0 50BADA54 80000118
50BADD80:        1 44078710        0        0 44E2EFA8 44E30638 4072AC08        0
50BADDA0: 43FB0000 44E1C3A8        0        0        0        0        0        0
50BADDC0:        0 44E306F0        0 40187DE4        0        0        0        0
50BADDE0:    10000  1000000        0        4       29 403071B8 40187CD8        0
50BADE00:    100F8        0    11BC0        0        0        0        0      CD4
50BADE20:        0        0        0      EE4        0      EE4        0        1
50BADE40:        0 40CAAAE4        3        0        0        0        0     1770
50BADE60:     1770 500047C8        0        0        0        0        0 50BAE12C
50BADE80: 50B9626C 50BADD90 43FB58E0        0        0        0 434B86F0        0
50BADEA0:        0        0     420A        0        0        0 50BADE90        0
50BADEC0:        0        0     4290 50BADD90        0        0        0        0
50BADEE0: 50BADE90 50BADD90        0        0    142D2        0        0        0
50BADF00: 50BADE90 50BADD90        0        0    242D2        0        0 44E30750
50BADF20: 44E30750        1        0 44E1C3A8        0        0        0        0
50BADF40:        0        0        0        0 448DB560 44E307B0 50BADF40 44E30758
50BADF60:        0 43FB60A0        0        0        0        0        0        4
50BADF80:  FFFFFFF        0        0        0        0        0        0        0
50BADFA0:        0 50BADFF0        0        0        0 BEEFCAFE FD0110DF 10DFFD01
---- block87  ptr=44E2EC58  is_malloc=1  length=0x320 ----
44E2EC18: 409C0174 44E2EC58 44E2E9BC 80000010        1 440787A0 79AB2DFA 1BE2FEAA
44E2EC38: 44E2ABD8        0        0        0        0        0 FD0110DF 10DFFD01
44E2EC58: AB1234CD FFFFFFFE        0 5000E864 4017EBAC 44E2EF78 44E2EC1C 80000178
44E2EC78:        1 440787A0 8C356807 FB0BEFBC        0 50B96430 50BADA70        0
44E2EC98: 5000E828       1A       20    C0010        0        0        0        0
44E2ECB8:       10    30000 440799B0 52656720 46756E63 74696F6E 20310000 44E2ED60
44E2ECD8: 44E2EF60        0 44E2ED60 44E2ED70 44E2ED80 44E2ED90 44E2EDA0 44E2EDB0
44E2ECF8: 44E2EDC0 44E2EDD0 44E2EDE0 44E2EDF0 44E2EE00 44E2EE10 44E2EE20 44E2EE30
44E2ED18: 44E2EE40 44E2EE50 44E2EE60 44E2EE70 44E2EE80 44E2EE90 44E2EEA0 44E2EEB0
44E2ED38: 44E2EEC0 44E2EED0 44E2EEE0 44E2EEF0 44E2EF00 44E2EF10 44E2EF20 44E2EF30
44E2ED58: 44E2EF40 44E2EF50        0        0 40722D18        0 50BADD38        0
44E2ED78: 406E9344        0 44E2ED60        0 406E934C        0 50BADCD8        0
44E2ED98: 406E8A10        0 44E806D0        0 406E8A68        0        0        0
44E2EDB8: 406E8AA0        0 44E2EDB0        0        0        0 44E2ED80        0
44E2EDD8: 406E8930        0 44E2ED90        0 406E8630        0 44E2EDA0        0
44E2EDF8: 406E8688        0 44E2EDF0        0        0        0 44E2EDD0        0
44E2EE18: 406E8550        0 44E2EE10        0 406E8230        0 44E806E0        0
44E2EE38: 406E7C84        0 44E2ED70        0 406E7C18        0 44E2EE20        0
44E2EE58: 406E7A8C        0 44E2EE30        0 406E7778        0 44E2EE60        0
44E2EE78:        0        0 44E2EE40        0 406E772C        0 44E2EE50        0
44E2EE98: 406E7638        0 44E2EE80        0 406E7380        0 44E2EEA0        0
44E2EEB8:        0        0 44E2EE90        0 406E72A0        0        0        0
44E2EED8: 406E54A8        0 44E2EED0        0        0        0        0        0
44E2EEF8: 406E5064        0 44E2EEF0        0        0        0        0        0
44E2EF18: 406E4F38        0 44E2EF10        0        0        0        0        0
44E2EF38: 406E4E60        0 44E2EF30        0        0        0        0        0
44E2EF58: 406E4DD0        0        0        0        0        0 FD0110DF 10DFFD01
---- block88  ptr=52656720  is_malloc=0  length=0x100 ----
526566E0:        0        0        0        0        0        0        0        0
52656700:        0        0        0        0        0        0        0        0
52656720:        0        0        0        0        0        0        0        0
52656740:        0        0        0        0        0        0        0        0
52656760:        0        0        0        0        0        0        0        0
52656780:        0        0        0        0        0        0        0        0
526567A0:        0        0        0        0        0        0        0        0
526567C0:        0        0        0        0        0        0        0        0
526567E0:        0        0        0        0        0        0        0        0
52656800:        0        0        0        0        0        0        0        0
---- block89  ptr=46756E60  is_malloc=0  length=0x100 ----
46756E20: 9042EFF7 15A889AC  6E6CB23 AE8F2E66 A593EA45 862DE792 DCD7A418 E50C0188
46756E40: 38F5D911 68E53878 9C06A21B F537CCFD 6996BA28 D49902D6 5AD009AE 7A00CB9D
46756E60: 4C2187EF 9AF9DEB7 9ED99F57 8579559E 9A3437D4 8E2285DF A810B79F  52C22EE
46756E80: 3D6D0822 CFEF5D25 A3D3A745  7BB5727 F5AB695C 8FA9E82B E519CB4F B18489AA
46756EA0: D03AE8EB CEF9869D D16B9199 EF6E4DFF 264418C0 85C46419 9B87DEBC 15B43C5D
46756EC0: A1338630 F5A7FE4C 1901BB3B 7565A645 1FFA8BF6 61672441 34A1D49D 459D9CAB
46756EE0:  F194A29 8D8EC313 42385A3E 40BC6D68 5FBCED71 D0FD8FE3 4CF7F873  8E7108E
46756F00: 227E05C2 6A847684 6D080314 3722EE74 B167D41A 9393852C 9D100CA5 61EEBB50
46756F20: AA98E662 2B00BEA8 98789E17 98D5E569 6BF460FC 5C395FD3 CA15CBD4 52957C0A
46756F40: 81E1B366 135C1E39 E22B2AC4 7CCDF091 C41E36FA 89AC45C5 E776B4C5 E71237E2
---- block90  ptr=50C4B190  is_malloc=1  length=0x320 ----
50C4B150: 409C0174 50C4B190 50C4AEF4 80000010        1 44078710        0        0
50C4B170: 50C4AEC0        0        0        0        0        0 FD0110DF 10DFFD01
50C4B190: AB1234CD FFFFFFFE        0 5000E864 4017EBAC 50C4B4B0 50C4B154 80000178
50C4B1B0:        1 44078710        0        0        0 50BB63B0 50C4B5D0        0
50C4B1D0: 5000E828       1A       20    C0010        0        0        0        0
50C4B1F0:       10    30000 440799B0 52656720 46756E63 74696F6E 20310000 50C4B298
50C4B210: 50C4B498        0 50C4B298 50C4B2A8 50C4B2B8 50C4B2C8 50C4B2D8 50C4B2E8
50C4B230: 50C4B2F8 50C4B308 50C4B318 50C4B328 50C4B338 50C4B348 50C4B358 50C4B368
50C4B250: 50C4B378 50C4B388 50C4B398 50C4B3A8 50C4B3B8 50C4B3C8 50C4B3D8 50C4B3E8
50C4B270: 50C4B3F8 50C4B408 50C4B418 50C4B428 50C4B438 50C4B448 50C4B458 50C4B468
50C4B290: 50C4B478 50C4B488        0        0 403188A0        0 50C4B298        0
50C4B2B0:        0        0        0        0 403158B0        0        0        0
50C4B2D0: 403157FC        0        0        0 4031579C        0 50C4B2D8        0
50C4B2F0:        0        0        0        0 40315738        0        0        0
50C4B310: 40316D7C        0 50C4B308        0        0        0 50C4B2F8        0
50C4B330: 40316D7C        0 50C4B328        0        0        0 44E80730        0
50C4B350: 403156D8        0 44E80740        0 403155CC        0        0        0
50C4B370: 403149AC        0        0        0 40315560        0 50C4B378        0
50C4B390:        0        0        0        0 40316804        0 50C4B398        0
50C4B3B0:        0        0 44E807C0        0 40316804        0 50C4B3B8        0
50C4B3D0: 403154F4        0 50C4B3C8        0        0        0        0        0
50C4B3F0: 40315488        0 50C4B6F8        0 40317EA8        0 50C75DA8        0
50C4B410: 40316F38        0        0        0 402E7318        0 50C4B418        0
50C4B430: 40315AA0        0        0        0 40315A38        0        0        0
50C4B450: 406A4D6C        0 50C4B448        0        0        0 50C4B808        0
50C4B470: 406A64C8        0 50C4B468        0        0        0 50C4B348        0
50C4B490: 4030DB68        0        0        0        0        0 FD0110DF 10DFFD01
---- block91  ptr=44E36218  is_malloc=1  length=0x100 ----
44E361D8:  FFFFFFF        0        0        0        0        0        0        0
44E361F8:        0 44E36248        0        0        0 BEEFCAFE FD0110DF 10DFFD01
44E36218: AB1234CD FFFFFFFE        0 40A14BFC 409C0174 44E36268 44E35FCC 80000010
44E36238:        1 440787A0 F9F0B29C EFBA49E4 44E35F48        0        0        0
44E36258:        0        0 FD0110DF 10DFFD01 AB1234CD FFFFFFFE        0 40A14BFC
44E36278: 401A62E0 44E362C8 44E3622C 80000018        1 440787A0 9EE7F59E E784E779
44E36298: 50BB66D0 40DD538C      42B    1001D        0        0        0       47
44E362B8:        0        0 FD0110DF 10DFFD01 AB1234CD FFFFFFFE        0 40A14BFC
44E362D8: 401A62E0 44E36328 44E3627C 80000018        1 440787A0 F869FD3D E0F9BE63
44E362F8: 50BB6730 40DD538C      423    1001D    10000        0        0       47
---- block92  ptr=A02794D4  is_malloc=0  length=0x100 ----
A0279494:  809E528 2C540001 2414FFFF 3C0240DD 8C435564 10600019 3C0440DD 3C0240DD
A02794B4: 8C43556C 3C022001   621824 10600013 8C845560 3C0340DD 8C625568   82102A
A02794D4: 1040000F  2801021 18800008 3C1240A9 3C1140A9   808021  C03A7E8 2624479C
A02794F4: 2610FFFF 1600FFFC        0 264447C8  2602821  C03A7E8  2803021  2801021
A0279514: 8FBF0024 8FB40020 8FB3001C 8FB20018 8FB10014 8FB00010  3E00008 27BD0028
A0279534: 27BDFFE8   803021 2CA20007 AFBF0014 10400039 AFB00010 3C0240A9 244247E0
A0279554:    51880   621821 8C640000   800008        0 24020001 10C2002D 28C20002
A0279574: 5040001A 24020002 54C0002C 2402FFFC  C09E279        0   408021 36040010
A0279594:  C09E273 3084FFFF  C09E273 3204FFEF  809E58C     1021 14C00020     1021
A02795B4:     2021     2821  C09D729 24060002  809E58C     1021  4C00015 28C20002
---- block93  ptr=50BB61A0  is_malloc=0  length=0x100 ----
50BB6160: 43FB0000 4019DDE8        0        1 448DBA30        0 43FB0000        1
50BB6180: 439D00D0 40DE0000 43FB0000 50C64410        0        0 40187D00 40187CB4
50BB61A0:        0        0        4        1 403071B8        0 403071B8 40188E88
50BB61C0: 4018992C FFFFFFFF 439D00D0 40DE0000        0        0 403071C0 40307190
50BB61E0: 448D75A8 40DE0000        0        0        0 403072DC FFFFFFFF FFFFFFFF
50BB6200:        0 4018AA3C 4030BAD8 4030BFFC FFFFFFFF FFFFFFFF        0        0
50BB6220:        0 4030BE24 FFFFFFFF FFFFFFFF 50BB6240 50BB62F0 FFFFFFFF FFFFFFFF
50BB6240: 50BB4AC0 FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF
50BB6260:        0        0        0        0        0 4017E15C FFFFFFFF FFFFFFFF
50BB6280: FFFFFFFF FFFFFFFF 4017E148 FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF
---- block94  ptr=50C643E0  is_malloc=1  length=0x100 ----
50C643A0:        0        0        0        0 448DBAD0        0 50C643A0 50C64358
50C643C0:        0 43FB6490        0  FFFFFFF  FFFFFFF        0 FD0110DF 10DFFD01
50C643E0: AB1234CD       2D 44E35FE8 40A3DFD4 40188AE0 50C644A0 50C64334 80000048
50C64400:        1 44078710        0        0        0 DEADFEED 50C64470 448DBA40
50C64420: 44E8D488 50C64360 50C64418 43FB3620      152    90000        2        0
50C64440: 44E35F98 4019C738 40DBEBEC        0        0        0        0        0
50C64460:        0        0        0        0 448DBA40        0 50C64460 50C64418
50C64480:        0 43FB6490        0  FFFFFFF  FFFFFFF        0 FD0110DF 10DFFD01
50C644A0: AB1234CD       23 44E1BB28 40A426C0 401984D0 50C65C48 50C643F4 80000BBC
50C644C0:        1 44078710        0        0 FFFFFFFF FFFFFFFF FFFFFFFF FFFFFFFF
---- block95  ptr=50C4BB70  is_malloc=1  length=0x260 ----
50C4BB30: 409C0174 50C4BB70 50C4B8D4 80000010        1 44078710        0        0
50C4BB50: 50C4B170        0        0        0        0        0 FD0110DF 10DFFD01
50C4BB70: AB1234CD       39 50C4BBA0 40A426B8 4019D268 50C4BDD0 50C4BB34 80000118
50C4BB90:        1 44078710        0        0 44E7ED20 44E803B0 4031D574        0
50C4BBB0: 43FB0000 44E804C8        0        0        0        0 44E80408 44140000
50C4BBD0: 44140000 44E80468        0 40187DE4        0        0        0        0
50C4BBF0:    10000  1000000        0        4       39 4031D5D0 40187CD8        0
50C4BC10:        0        0     1AC8        0        0        0        0      E54
50C4BC30:        0        0        0      EE0        0      EE0        0        1
50C4BC50:        0 40AD3588        2        0        0        0        0     1770
50C4BC70:     1770 500047C8        0        0        0        0        0 50C5C184
50C4BC90: 44E360D4 50C4BBA0 43FB58E0        0 44BFDB08 50C4B9F0 434B86F0 50C4BCC0
50C4BCB0:        0     16B0     420E        0        0 50C4BCC0 50C4BCA0 44143D20
50C4BCD0:        0     16B0     4296 50C4BBA0        0        0        0        0
50C4BCF0: 50C4BCA0 50C4BBA0        0        0    142D2        0        0        0
50C4BD10: 50C4BCA0 50C4BBA0        0        0    242D2        0 44143D20        0
50C4BD30:        0        0        0 44E804C8        0        0        0        0
50C4BD50:        0        0        0        0 448DBA10 44E80528 50C4BD50 44E804D0
50C4BD70:        0 43FB60A0        0        0        0        0        0  FFFFFFF
50C4BD90:  FFFFFFF        0        0        0        0        0        0        0
50C4BDB0:        0 50C4BE00        0        0        0 BEEFCAFE FD0110DF 10DFFD01
--------- show redundancy --------
Switchovers this system has experienced          : 0
Last switchover reason                           : None.
Uptime since this supervisor switched to active  : 0 minutes
Total system uptime from reload                  : 0 minutes
Standby is NOT ready to take over
--------- show buffers --------
Buffer elements:
     500 in free list (500 max allowed)
     4 hits, 0 misses, 0 created
Public buffer pools:
Small buffers, 104 bytes (total 1024, permanent 1024):
     1024 in free list (128 min, 2048 max allowed)
     0 hits, 0 misses, 0 trims, 0 created
     0 failures (0 no memory)
Medium buffers, 256 bytes (total 3000, permanent 3000):
     3000 in free list (64 min, 3000 max allowed)
Middle buffers, 600 bytes (total 512, permanent 512):
     509 in free list (64 min, 1024 max allowed)
     3 hits, 0 misses, 0 trims, 0 created
Big buffers, 1536 bytes (total 1000, permanent 1000):
     1000 in free list (64 min, 1000 max allowed)
VeryBig buffers, 4520 bytes (total 10, permanent 10):
     10 in free list (0 min, 100 max allowed)
Large buffers, 5024 bytes (total 2, permanent 2):
     2 in free list (0 min, 10 max allowed)
Huge buffers, 18024 bytes (total 2, permanent 2):
     2 in free list (0 min, 4 max allowed)
Interface buffer pools:
EOBC0/0 buffers, 1524 bytes (total 2400, permanent 2400):
     1200 in free list (0 min, 2400 max allowed)
     1200 hits, 0 fallbacks
     1200 max cache size, 688 in cache
     1024 hits in cache, 0 misses in cache
IPC buffers, 4096 bytes (total 336, permanent 336):
     296 in free list (112 min, 1120 max allowed)
     40 hits, 0 fallbacks, 0 trims, 0 created
Private Huge IPC buffers, 18024 bytes (total 2, permanent 2):
     2 in free list (1 min, 4 max allowed)
Private Huge buffers, 65280 bytes (total 2, permanent 2):
Header pools:
--------- show buffer summary --------
Pool: Small
Non ipc/scp link type count: 0
Caller Summary
Pool: Medium
Caller Summary
Pool: Middle
Non ipc/scp link type count: 3
Caller Summary
    pc = 0x400DC564    count = 3
Pool: Big
Caller Summary
Pool: VeryBig
Caller Summary
Pool: Large
Caller Summary
Pool: Huge
Caller Summary
Pool: EOBC0/0
Non ipc/scp link type count: 1200
Caller Summary
    pc = 0x40105C9C    count = 1200
Pool: IPC
Non ipc/scp link type count: 40
Caller Summary
    pc = 0x402CFDC0    count = 40
Pool: Private Huge IPC
Caller Summary
Pool: Private Huge
Caller Summary
--------- show mem proc alloc totals --------
Allocator PC Summary for: Processor
    PC          Total   Count  Name
0x4014D7DC    7201152       2  Init
0x401053A4    6636000    8295  *Packet Header*
0x402C8F0C     983880      15  IPC Message He
0x402C7388     983880      15  IPC Message He
0x4095ACE0     516152       1  Init
0x401984D0     471920      70  Interrupt Stack
0x402FEDE8     432144       1  ICC async callback
0x401333B0     280144       1  IDB List Element Chunks
0x402C7F54     240000    3000  IPC Fragment
0x402C9DA8      87200      48  IPC Thread Slot
0x4069A838      72288       2  Redundancy Event Chunks
0x4029E9D4      69176       1  Init
0x4029ED3C      65592       1  PFS inode table
0x402C7E78      65592       1  IPC Message Header Cache
0x4087A09C      65592       1  ddb counters struct
0x4029ECE8      65592       1  DFS stream buffer
0x4069AE20      65592       1  CF Message Desc
0x4072AC38      65592       1  ACE ICC Msg Chunk
0x4029E9E8      58424       1  Init
0x402FDEF0      56144       1  ICC retry_async callback
0x400C34C0      49208       1  Init
0x4019D268      38912      64  Process
0x400D333C      32832       1  Init
0x4029EBEC      32824       1  PCMCIAFS LFN Node
0x409BD2A4      28864      41  Init
0x4016F420      23176       3  messages
0x40112DE4      22368       3  *Hardware IDB*
0x402C38C0      21632       8  IPC Port
0x402C7F04      20800     100  IPC Message
0x40188584      20112       2  Watched Queue
0x4016EE90      20056       1  Managed Chunk Queue Elements
0x400A4C6C      20056       1  Parse Nodes
0x400A4BE8      20056       1  Parseinfo Blocks
0x409C04F0      19136      26  *Init*
0x40166880      15600      10  List Elements
0x40188AE0      15552      81  Process Events
0x409BFEA4      12856       1  *Init*
0x402635F4      12344       1  Init
0x402C7F20      12056       1  IPC Frag Cache
0x4018A7C8      10056       1  Watched Queue
0x4018A820      10056       1  Watched Bitfield
0x4018A7F4      10056       1  Watched Boolean
0x4029EC40      10056       1  DFS Sector
0x4017EBAC       9560      11  Reg Function 1
0x400D9F80       8248       1  Init
0x401AC76C       7216       1  Pathents for parsing
0x40112E00       6816       3  *Software IDB*
0x4017EB1C       6400       8  Reg Function 1
0x4018CB98       6112       1  Alignment Data
0x409C0174       5680      70  *Init*
0x400A9AD0       5456      68  Parser Linkage
0x402C58E0       5440      40  IPC Seat
0x4018A878       5056       1  Watcher Info
0x401A74AC       5056       1  File Descriptors
0x4029EC94       5056       1  Super Dir entry
0x401679FC       5056       1  List Headers
0x402C9D7C       4992      48  IPC Thread
0x4010A590       4856       1  Pool Cache
0x40094868       4336       1  TTY data
0x400EDD08       4336       1  TTY data
0x4029E9BC       4152       1  Init
0x40133A10       4056       1  Packet Elements
0x40109F18       4032      12  Pool Info
0x402CA6A8       3992      49  IPC Name String
0x40163C6C       3056       1  aaa
0x4029EB98       3056       1  FDNODE
0x4087A0EC       2944       1  dialer_ckt_swt_pool
0x40305348       2944       1  ICC FC retry chunk
0x402DBB08       2232       9  Init
0x40258B80       2104       1  Init
0x40263624       2104       1  Init
0x40258B50       2104       1  Init
0x400F1554       2056       1  TTY Input Buf
0x400A9DA0       1680      15  Parser Mode
0x4017F074       1600       2  Reg Function 1
0x401679BC       1560       1  List Elements
0x4018A8D0       1560       1  Watcher Message Queue
0x4017EA98       1560       1  Reg Function iList
0x400A1B08       1560       1  String-DB owners
0x405A7D58       1560       1  FABMAN MSG CHUNK
0x406A6AE0       1560       1  EvtMgr Callback Chunk
0x4018A84C       1560       1  Watched Semaphore
0x4017EA6C       1560       1  Reg Function 12
0x4017EAC4       1560       1  Reg Function Caselist
0x400A1ADC       1560       1  String-DB entries
0x40695C80       1496      11  *Init*
0x400ABC10       1408      16  Parser Alias
0x4069C8AC       1344       6  Init
0x400ABC38       1280      16  Init
0x403054E0       1264       1  Init
0x400C130C       1240       1  GraphIt Client
0x400A9E10       1200      15  Parser Mode Q1
0x400A9E34       1200      15  Parser Mode Q2
0x400A99FC       1120      14  *Init*
0x4019CD78       1088       1  Process Array
0x400A1B4C       1080       1  String DB Hash Table
0x402D076C        856       1  IPC Seat Manager
0x402D077C        856       1  IPC Seat Manager
0x401A62E0        672       7  Init
0x401A6314        672       7  Init
0x402C38E8        640       8  IPC Name
0x4029EA30        624       3  Init
0x4023B8DC        568       1  Init
0x400F1584        568       1  TTY Output Buf
0x400E21CC        568       1  Init
0x400A1B34        560       1  String-DB handles
0x402BED60        552       1  IPC Global Info
0x402BED98        552       1  IPC Global Cache Info
0x4030F19C        520       5  Bundle IOS version
0x400BCB64        480       6  Cond Debug definition
0x4069D6A0        480       6  Init
0x4069D728        480       6  Init
0x400A4C40        480       1  Chain Cache Nodes
0x402C7EC8        456       1  IPC Msg Cache
0x4030A744        408       3  Init
0x400A4C14        400       1  tokenQ node
0x409AD1E8        400       5  Init
0x409AD224        400       5  Init
0x409AD200        400       5  Init
0x401A7D18        400       5  Init
0x4018A8A4        400       1  Watched Message Queue
0x40282500        392       1  Init
0x4030A790        384       4  Init
0x400223F4        344       1  Init
0x405C1414        320       2  LCC regstration
0x4017D6C4        312       1  Init
0x4068EB8C        312       1  rf proxy sp agent
0x4029EA54        264       3  Init
0x40259A18        232       1  Init
0x4026359C        232       1  Init
0x4069D500        216       1  Init
0x4014D7A4        208       2  Init
0x408932CC        192       1  Init
0x401A57C4        168       1  Process Signals
0x40103234        160       2  Init
0x402B5DD8        160       2  IPC Delayed Function
0x40103408        160       2  Init
0x402DC0A8        160       1  Init
0x408932A0        152       1  Init
0x402DC0BC        152       1  Init
0x402C9290        144       1  IPC Zone
0x4030F25C        120       1  Bundle IOS versions
0x400A2780        104       1  SDB Owner info
0x4014F428        104       1  Init
0x4014F458        104       1  Init
0x400E3EF8         96       1  Init
0x400E3FA4         96       1  Init
0x400813DC         96       1  Init
0x40081420         96       1  Init
0x40163BE0         96       1  CCA Component
0x408946C8         96       1  CLID Group
0x40079310         88       1  Init
0x400C34A4         88       1  Init
0x40894714         88       1  CLID Entry
0x401AFFF4         88       1  Init
0x40114550         80       1  Init
0x400E3CA4         80       1  Init
0x400E3D80         80       1  Init
0x4003D868         80       1  AAA PROMPT P1
0x408946F0         80       1  CG:Name
0x40894738         80       1  CE:Num
0x401144D4         80       1  Init
0x400E3B78         80       1  Init
0x400E3D00         80       1  Init
0x400E3DD0         80       1  Init
0x400E3EC4         80       1  Init
0x400E3F30         80       1  Init
0x400813B4         80       1  Init
0x400813F8         80       1  Init
0x4003D884         80       1  AAA PROMPT U1
0x400C1320         80       1  Init
0x4017D658         80       1  *Sched*
Processor Memory: total 393469024, free 374316280, used 19152744
IO Memory: total 67108864, free 56755552, used 10353312
--------- show eobc --------
Interface information:
    Interface EOBC0/0 (idb = 0x44D23B18)
    Hardware is Mistral EOBC (revision 4)
    Address is 0000.1200.0000 (bia 0000.1200.0000)
    Encap size         = 14         hardware status  = 0x210840
    IDB type           = 18         IDB state        = 4
    Encap type         = 0x1        Span encap size  = 0
    Error threshold    = 5000       Error count      = 0
Counters:
    rxring             = 0x89D99C0  rx ring entries       = 512
    rx_head            = 0          rx_tail               = 0
    inputs             = 0          rx_cumbytes           = 0
    hw inputs          = 0          hw rx_cumbytes        = 0
    rx rate (bits/sec) = 0          rx rate (packets/sec) = 0
    rx_buf_unavail     = 0          rx input drops        = 0
    rxr eobc shadow    = 0x50B90538 txr eobc shadow       = 0x44E113C0
    txring             = 0x89DBA00  tx ring entries       = 0x200
    tx_head            = 0          tx_tail               = 0
    outputs            = 0          tx_cumbytes           = 0
    hw outputs         = 0          hw tx_cumbytes        = 0
    tx rate (bits/sec) = 0          tx rate (packets/sec) = 0
    tx_retry_error     = 0          tx_retry_count        = 0
    tx_process_stopped = 0          tx total drops        = 0
Mistral Registers
    soft_reset_cfg     = 0x10FFFF   dma_buffer_size_reg   = 0x000000
    int_mask_hi        = 0x03FEFE   int_mask_lo           = 0x87F13A59
    rxdscp_cnt         = 512        txdscp_cnt            = 0
    rxwork_dscp        = 0x99C0     txwork_dscp           = 0xBA00
    mistral_eobc_ds    = 0x44D259E0 mistral_dma_register  = 0x30000000
    mistral_glbl_reg   = 0x10020000
Misc. Global Registers:
    global_cfg         = 0x0        mis_init_sts          = 0x8
    dimm_parm_cfg_hi   = 0x00000566 dimm_parm_cfg_lo      = 0x42040F5A
    tm_init_size_cfg   = 0x8000
--------- show scp status --------
Id Sap      Channel name    current/peak/retry/dropped/total  time(queue/process/ack)
0  0    SCP Unsolicited:0       0/    0/    0/      0/    0      0/   0/   0
--------- show ipc status --------
                            IPC System Status
Time last IPC stat cleared : never
This processor is the IPC master server.
Do not drop output of IPC frames for test purposes.
6000 IPC Message Headers Cached.
                                                    Rx Side     Tx Side
Total Frames                                                0           0           0          0
Total from Local Ports                                      0           0
Total Protocol Control Frames                               0           0
Total Frames Dropped                                        0           0
                             Service Usage
Total via Unreliable Connection-Less Service                0           0
Total via Unreliable Sequenced Connection-Less Svc          0           0
Total via Reliable Connection-Oriented Service              0           0
                      IPC Protocol Version 0
Total Acknowledgements                                      0           0
Total Negative Acknowledgements                             0           0
                             Device Drivers
Total via Local Driver                                      0           0
Total via Platform Driver                                   0           0
Total Frames Dropped by Platform Drivers                    0           0
Total Frames Sent when media is quiesced                                0
                     Reliable Tx Statistics
Re-Transmission                                                         0
Re-Tx Timeout                                                           0
          Rx Errors                              Tx Errors
Unsupp IPC Proto Version          0  Tx Session Error                  0
Corrupt Frame                     0  Tx Seat Error                     0
Duplicate Frame                   0  Destination Unreachable           0
Out-of-Sequence Frame             0  Tx Test Drop                      0
Dest Port does Not Exist          0  Tx Driver Failed                  0
Rx IPC Msg Alloc Failed           0  Ctrl Frm Alloc Failed             0
Unable to Deliver Msg             0  Invalid Messages                  0
          Buffer Errors                          Misc Errors
IPC Msg Alloc                     0  IPC Open Port                     1
Emer IPC Msg Alloc                0  No HWQ                            0
IPC Frame PakType Alloc           0  Hardware Error                    0
IPC Frame MemD Alloc              0
          Tx Driver Errors
No Transport                      0
MTU Failure                       0
Dest does not Exist               0
--------- show ipc rpc --------
                    IPC RPC Status
                                  Rx Side      Tx Side
Total RPC requests                         0            0
Total RPC replies                          0            0
                    IPC RPC Errors
No Pending RPC Request for Received RPC Reply           0
--------- show ipc queue --------
There are 0 IPC messages waiting for acknowledgement in the transmit queue.
There are 0 IPC messages waiting for a response.
There are 0 IPC messages waiting for additional fragments.
There are 0 IPC messages currently on the IPC inboundQ.
There are 0 IPC messages currently on the zone inboundQ.
Messages currently in use                     :         40
Message cache size                            :       6000
Maximum message cache usage                   :       6000
0  times message cache crossed      12000 [max]
There are 0 messages currently reserved for reply msg.
--------- show ipc port --------
There are 8 ports defined.
   10000.1     unicast    IPC Master:Zone
   10000.2     unicast    IPC Master:Echo
   10000.3     unicast    IPC Master:Control
   10000.4     unicast    Rf_Proxy:Server:2
   10000.5     unicast    Card2/1:Request
   10000.6     unicast    Card18:Request
   10000.7     unicast    Card2/1:Event
   10000.8     unicast    Card2/1:Exception
RPC packets: current/peak/total
--------- show ipc port open --------
There are 0 ports defined.
--------- show icc status --------
Class Name             Msgs Pending  Max Pending       Total
--------- show heartbeat settings --------
heartbeat interval            = 2
heartbeat warning interval    = 30
heartbeat fatal count         = 5
heartbeat interrupt interval  = 30
heartbeat interrupt max       = 5
ignore rx                     = no
ignore tx                     = no
--------- show heartbeat --------
Out of buffers          = 0
EOBC tx failures        = 0
Negative clock updates  = 0
Fatal errors            = 0
Last heartbeat sched    = 4908
Last heartbeat sent     = 4908
Scheduler history [PF_Init Process 0%/0% (00:00:04.892 100%/85%)] [PF_Init Process 00:00:04.908] [rf task 00:00:04.908] [ECC correctable process 00:00:04.908]
--------- show ibc --------
    Interface IBC0/0(idb 0x44E84B58)
    Hardware is Mistral IBC (revision 4)
    5 minute rx rate 0 bits/sec, 0 packets/sec
    5 minute tx rate 0 bits/sec, 0 packets/sec
    0 packets input, 0 bytes
    0 broadcasts received
    0 packets output, 0 bytes
    0 broadcasts sent
    0 Packets CEF Switched, 0 Packets Fast Switched
    0 Packets SLB Switched, 0 Packets CWAN Switched
    IBC resets   = 0
MISTRAL ERROR COUNTERS
    System address timeouts  = 0     BUS errors     = 0
    IBC Address timeouts     = 0 (addr 0x0)
    Page CRC errors          = 0     IBL CRC errors = 0
    ECC Correctable errors   = 0
    Packets with padding removed (0/0/0)   = 0
    Packets expanded (0/0)   = 0
    Packets attempted tail end expansion > 1 page and were dropped = 0
    IP packets dropped with frag offset of 1 = 0
0 packets (aggregate) dropped on throttled interfaces    Hazard Illegal packet length     = 0     Illegal Offset       = 0
    Hazard Packet underflow          = 0     Packet Overflow      = 0
    IBL fill hang count              = 0     Unencapsed packets   = 0
DMA Instance Details:
    DMA Instance       = 0x44E868C8    RX Pak          = 0x44D233D0
    Receive Ring       = 0x089DCA40    Receive Shadow  = 0x50C5D5E8
    Receive Tail       = 0             Receive Head     = 0
    Receive Count      = 0
    Transmit Ring      = 0x089DEA80    Transmit Shadow = 0x44E869B0
    Transmit Tail      = 0             Transmit Head   = 0
    Transmit Count     = 0
MISTRAL REGISTERS:
    soft_reset_cfg     = 0x0010FFFF  gmac_status        = 0x0
    (Inband Gig interface not syncronized)
MISC GLOBAL REGISTERS:
    global_cfg         = 0x00000000  mis_init_sts       = 0x8
    tm_init_size_cfg   = 0x00008000  sysad_timeout_cfg  = 0x08
FAST SWITCHING ASSISTANT HARDWARE REGISTERS:
    send_router_cfg    = 0x00000000  send_bridge_cfg    = 0x0000
    ibl_cfg            = 0xE
    obl_sem_req        = 0x00000001  obl_sem_sts        = 0x0
INBAND DMA REGISTERS:
    rxdma: sts         = 0x00000000  base               = 0x0000
    rxdscp_cnt         = 0
    txdma: sts         = 0x00000000   base              = 0x0000
    txdscp_cnt         = 0
    dma_buffer_size    = 0x0
BUFFER ALLOCATION, WRR and STATUS REGISTERS:
    lbic_pkt_type[0]     = 0x30      lbic_pkt_type[1]     = 0x30
    lbic_pkt_type[2]     = 0x30      lbic_pkt_type[3]     = 0x30
    lbic_pkt_type[4]     = 0x30      lbic_pkt_type[5]     = 0x30
    lbic_pkt_type[6]     = 0x30      lbic_pkt_type[7]     = 0x30
    idx_direc_rx_offset  = 0x30
INTERRUPTS:
    int_mask_hi         = 0x0003FEFE     int_mask_lo          = 0x87F13A59
    int_source_status_hi = 0x00000000    int_source_status_lo = 0x00000024
    int_status_0_hi     = 0x00000000     int_status_0_lo      = 0x00000000
    int_status_1_hi     = 0x00000000     int_status_1_lo      = 0x00000000
    int_status_2_hi     = 0x00000000     int_status_2_lo      = 0x00000004
    int_status_3_hi     = 0x00000000     int_status_3_lo      = 0x00000020
    int_status_4_hi     = 0x00000000     int_status_4_lo      = 0x00000000
    map[00]    = 0x4    map[01]    = 0x2    map[02]    = 0x2    map[03]    = 0x0
    map[04]    = 0x0    map[05]    = 0x3    map[06]    = 0x3    map[07]    = 0x2
    map[08]    = 0x1    map[09]    = 0x1    map[10]    = 0x1    map[11]    = 0x0
    map[12]    = 0x0    map[13]    = 0x0    map[14]    = 0x4    map[15]    = 0x4
    map[16]    = 0x4    map[17]    = 0x4    map[18]    = 0x4    map[19]    = 0x4
    map[20]    = 0x4    map[21]    = 0x4    map[22]    = 0x4    map[23]    = 0x0
    map[24]    = 0x1    map[25]    = 0x1    map[26]    = 0x1    map[27]    = 0x4
    map[28]    = 0x4    map[29]    = 0x2    map[30]    = 0x2    map[31]    = 0x0
    map[32]    = 0x2    map[33]    = 0x0    map[34]    = 0x0    map[35]    = 0x0
    map[36]    = 0x0    map[37]    = 0x0    map[38]    = 0x0    map[39]    = 0x4
    map[40]    = 0x4    map[41]    = 0x4    map[42]    = 0x4    map[43]    = 0x4
    map[44]    = 0x4    map[45]    = 0x4    map[46]    = 0x4    map[47]    = 0x4
    map[48]    = 0x4    map[49]    = 0x4
TIMERS:
    watchdog_timer : init_cnt = 0x0000A    cnt = 0x00006    enable = 1
    general_timer_0: init_cnt = 0x80000    cnt = 0x00001    cfg    = 0
    general_timer_1: init_cnt = 0xF4240    cnt = 0x038EE    cfg    = 3
========= End of Crashinfo Collection ================
Ok this crash is the same one as we got in the very begining of this thread. And this was caused by PF_REDUN_CRASH_COUNT variable getting higher than 3. This is done to break continuos boot loop. So this crash does not shed light on the problems which we had booting MSFC (this one happened before control was sent to RP).
I guess physical MSFC/memory reseat cleared the issue and sub-sequent reload can be related to the variable got higher than 3 due to old failed boot attempts.
Nik
P.S.
this got to be a big thread. can you pls mark the helpfull answers through it to make it usefull for others.
HTH,
Niko
