SUP7-E uplinks in single mode
Hi everyone,
I have a single SUP7-E (no redundant supervisor). Of the four uplinks, which are the options availale? Can I use the four uplinks as 10G interfaces? Could I use two uplinks as 10G and the other two as Gigabit?
Reza Sharifi
Yes, you have 4 10Gig nonblocking interfaces.  You can use them as 10Gig or 1Gig depending on your optics.
SFP+ 10Gig
SFP 1Gig
The optics can be single mode or multimode.
Jose Solano
Level 4
Level 4
See this figure below:
Figure 2. High-Availability and Uplink Options for Supervisor Engine 7-E
http://www.cisco.com/en/US/prod/collateral/switches/ps5718/ps4324/data_sheet_c78-612364.html
Hi Leo,
The above figure 2 makes reference to a high availability scenario, this is, when you have two supervisors.
In case you have only one sup7-e, which are the options? I took the Reza's answer as good but now I'm not sure again. When the datasheet says "4 nonblocking uplinks" I think you can use the four uplink interfaces simultaneously.
All four uplinks may be used simultaneously on a single Sup7-E.
The "high availability" mentioned in the document linked above is referring to the fact that any given uplink can fail while the others continue to operate.
