SUP720 load specific config to startup during rommon
Hello Freinds,
Wendering if there is any tips to load specific file configuration(from disk0) to startup during rommon load, we need this to avoid "double" reload
when replacing new RMA SUP720, this will help to load correct config prior IOS loading without need to copy from file to startup config or
erease startup and copy the correct config while IOS already loaded thus, second reload is required.
any tips will be appreicated.
Mohamed.
Reza Sharifi
Hi Mohamed,
There is no way to do that. You would have to wait for it to reboot completely and than load the startup config.
Depending on the number of modules you have, the reboot should no take more than 10 minutes.
Hello Reza,
Thanks alot for your support, thus twice reload is required :-(
Mohamed.
