Supervisor Module is Unknown
recep_ali_sevim
Frequent Visitor
Frequent Visitor
Hi, Today I realized that our backbone module 3 has down. We were using port chanel with module 3 and 4 therefore ıt wasnt a problem for us. So What can I do for that? Can I take it off and put it on while switch is running?
I used show module command;
Mod Ports Card Type Model Serial No.
1 48 CEF720 48 port 1000mb SFP WS-X6848-SFP SAL1819S9ER
2 48 DCEF 48P 1GE SFP C6800-48P-SFP SAL203001D1
3 0 Unknown (Other) Unknown Unknown
4 5 Supervisor Engine 2T 10GE w/ CTS (Acti VS-SUP2T-10G SAL1941QX54
5 48 CEF720 48 port 10/100/1000mb Ethernet WS-X6848-GE-TX SAL1825UZLA
7 48 DCEF 48P 10/100/1000MB Ethernet C6800-48P-TX SAL203000V8
Mod MAC addresses Hw Fw Sw Status
1 6412.252e.6970 to 6412.252e.699f 3.0 12.2(18r)S1 15.2(1)SY1a Ok
2 00f2.8b1b.bc84 to 00f2.8b1b.bcb3 1.0 12.2(18r)S1 15.2(1)SY1a Ok
3 0000.0000.0000 to 0000.0000.0000 0.0 Unknown Unknown Unknown
4 d072.dcbb.e4f7 to d072.dcbb.e4fe 2.1 12.2(50r)SYS 15.2(1)SY1a Ok
5 88f0.3160.4b78 to 88f0.3160.4ba7 1.2 12.2(18r)S1 15.2(1)SY1a Ok
7 0c75.bd0a.38e0 to 0c75.bd0a.390f 1.0 12.2(18r)S1 15.2(1)SY1a Ok
Mod Sub-Module Model Serial Hw Status
1 Distributed Forwarding Card WS-F6K-DFC4-A SAL1824UHUH 2.1 Ok
2 Distributed Forwarding Card WS-F6K-DFC4-A SAL203001JU 2.1 Ok
4 Policy Feature Card 4 VS-F6K-PFC4 SAL1948TTZ6 3.0 Ok
4 CPU Daughterboard VS-F6K-MSFC5 SAL1941QRV1 3.0 Ok
5 Distributed Forwarding Card WS-F6K-DFC4-A SAL1825UZLA 1.2 Ok
7 Distributed Forwarding Card WS-F6K-DFC4-A SAL203000V8 1.0 Ok
Mod Online Diag Status
1 Pass
2 Pass
3 Not Applicable
4 Pass
5 Pass
7 Pass
Scott Hodgdon
@recep_ali_sevim ,
All Cat 6K support online insertion and removal of second Supervisor and modules. While @balaji.bandi is being understandably cautious by suggesting a maintenance window, you should be able to remove and reinsert the module in slot 3 with no downtime.
So now you have two options 🙂 .
Cheers,
Scott Hodgdon
Senior Technical Marketing Engineer
Enterprise Networking and Cloud Group
5 Replies 5
balaji.bandi
Take the maintenance window, Pull the Module out and re-insert and test it.
Make sure you capture all the Logs from console.
BB
Scott Hodgdon
@recep_ali_sevim ,
Cheers,
Scott Hodgdon
Thank you friend 🙂 I've connected with console and switch has stayed RAMON mod. Then, I used some codes for boot module 🙂
No, something is not right.  Even if the Supervisor card is in ROMMON the output would at least show a MAC address.  For something to show up with a NULL MAC address means something else.
Console into the Supervisor card to capture the entire boot-up process and re-seat the line card.
While waiting for access to the line card, remotely reboot the line card by powering OFF and on the slot and watch the logs.
If rebooting the line cards remotely is not possible, let me know.  I have a few more tricks to find out the history logs.
Mark Elsen
 - Also connect a console before re-inserting and then follow-up on messages displayed such as module availability or self-test errors (possibly). Also check the led which denotes the module-status.
 M.
-- ' Listen to the wind, it talks
          Listen to the silence, it speaks
             Listen to your heart, it knows
Ganado Mucho (1809 to 1893 ) Navajo Indian
