Suspecting ESP 10 to fail in ASR1002
skynetkazan
ASR1002 Cisco doesnt recognise ESP 10 module. Log is attached. We need to decide wether the chassi is OK or it is also affected.
We have conducted the following experiment: turned on the ASR1002  without ESP module and assigned 192.168.0.2 adress to an interface.
After that tried to ping 192.168.0.2 from outside, all pings have been lost.
Does the ASR1002 have to respond on the interface without ESP module?
subject to restrictions as set forth in subparagraph
(c) of the Commercial Computer Software - Restricted
Rights clause at FAR sec. 52.227-19 and subparagraph
(c) (1) (ii) of the Rights in Technical Data and Computer
Software clause at DFARS sec. 252.227-7013.
           cisco Systems, Inc.
           170 West Tasman Drive
           San Jose, California 95134-1706
Cisco IOS Software, IOS-XE Software (PPC_LINUX_IOSD-ADVENTERPRISEK9-M), Version 15.1(3)S1, RELEASE SOFTWARE (fc1)
Technical Support: http://www.cisco.com/techsupport
Copyright (c) 1986-2011 by Cisco Systems, Inc.
Compiled Sat 08-Oct-11 01:16 by mcpre
Cisco IOS-XE software, Copyright (c) 2005-2011 by cisco Systems, Inc.
All rights reserved.  Certain components of Cisco IOS-XE software are
licensed under the GNU General Public License ("GPL") Version 2.0.  The
software code licensed under GPL Version 2.0 is free software that comes
with ABSOLUTELY NO WARRANTY.  You can redistribute and/or modify such
GPL code under the terms of GPL Version 2.0.  For more details, see the
documentation or "License Notice" file accompanying the IOS-XE software,
or the applicable URL provided on the flyer accompanying the IOS-XE
software.
% failed to initialize nvram
A summary of U.S. laws governing Cisco cryptographic products may be found at:
export@cisco.com.
cisco ASR1002 (2RU) processor with 1700171K/6147K bytes of memory.
4 Gigabit Ethernet interfaces
32768K bytes of non-volatile configuration memory.
4194304K bytes of physical memory.
7798783K bytes of eUSB flash at bootflash:.
         --- System Configuration Dialog ---
Would you like to enter the initial configuration dialog? [yes/no]: no
Press RETURN to get started!
*Dec 12 16:40:24.348: %ASR1000_RP_NV-3-NV_ACCESS_FAIL: Initial read of NVRAM contents failed
*Dec 12 16:40:31.211: %LINK-3-UPDOWN: Interface Lsmpi0, changed state to up
*Dec 12 16:40:31.211: %LINK-3-UPDOWN: Interface EOBC0, changed state to up
*Dec 12 16:40:31.211: %LINEPROTO-5-UPDOWN: Line protocol on Interface VoIP-Null0, changed state to up
*Dec 12 16:40:31.212: %LINEPROTO-5-UPDOWN: Line protocol on Interface LI-Null0, changed state to up
*Dec 12 16:40:31.212: %LINK-3-UPDOWN: Interface GigabitEthernet0, changed state to down
*Dec 12 16:40:31.212: %LINK-3-UPDOWN: Interface LIIN0, changed state to up
*Dec 12 16:40:31.350: %NETCLK-5-NETCLK_MODE_CHANGE: Network clock source not available. The network clock has changed to freerun
*Dec 12 16:40:31.440: %ASR1000_MGMTVRF-6-CREATE_SUCCESS_INFO: Management vrf Mgmt-intf created with ID 1, ipv4 table-id 0x1, ipv6 table-id 0x1E000001
*Dec 12 16:40:31.715: %DYNCMD-7-PKGINT_INSTALLED: The command package 'platform_trace' has been succesfully installed
*Dec 12 16:40:33.429: %LINEPROTO-5-UPDOWN: Line protocol on Interface Lsmpi0, changed state to up
*Dec 12 16:40:33.430: %LINEPROTO-5-UPDOWN: Line protocol on Interface EOBC0, changed state to up
*Dec 12 16:40:33.430: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet0, changed state to down
*Dec 12 16:40:33.430: %LINEPROTO-5-UPDOWN: Line protocol on Interface LIIN0, changed state to up
*Dec 12 16:40:23.540: %IOSXE-5-PLATFORM: R0/0: xinetd[32286]: xinetd Version 2.3.14 started with no options compiled in.
*Dec 12 16:40:23.554: %IOSXE-5-PLATFORM: R0/0: xinetd[32286]: Started working: 1 available service
*Dec 12 16:40:34.225: %DYNCMD-7-CMDSET_LOADED: The Dynamic Command set has been loaded from the Shell Manager
*Dec 12 16:40:58.021: %LINK-5-CHANGED: Interface GigabitEthernet0/0/0, changed state to administratively down
*Dec 12 16:40:58.022: %LINK-5-CHANGED: Interface GigabitEthernet0/0/1, changed state to administratively down
*Dec 12 16:40:58.022: %LINK-5-CHANGED: Interface GigabitEthernet0/0/2, changed state to administratively down
*Dec 12 16:40:58.023: %LINK-5-CHANGED: Interface GigabitEthernet0/0/3, changed state to administratively down
*Dec 12 16:40:58.023: %LINK-5-CHANGED: Interface GigabitEthernet0, changed state to administratively down
*Dec 12 16:40:59.021: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet0/0/0, changed state to down
*Dec 12 16:40:59.022: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet0/0/1, changed state to down
*Dec 12 16:40:59.022: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet0/0/2, changed state to down
*Dec 12 16:40:59.023: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet0/0/3, changed state to down
*Dec 12 16:41:02.525: %ASR1000_OIR-6-REMSPA: SPA removed from subslot 0/0, interfaces disabled
*Dec 12 16:41:02.527: %SPA_OIR-6-OFFLINECARD: SPA (4XGE-BUILT-IN) offline in subslot 0/0
*Dec 12 16:41:02.531: %ASR1000_OIR-6-INSCARD: Card (fp) inserted in slot F0
*Dec 12 16:41:02.532: %ASR1000_OIR-6-INSCARD: Card (cc) inserted in slot 0
*Dec 12 16:41:02.532: %ASR1000_OIR-6-ONLINECARD: Card (cc) online in slot 0
*Dec 12 16:41:02.536: %ASR1000_OIR-6-INSSPA: SPA inserted in subslot 0/0
*Dec 12 16:41:02.743: %SYS-5-RESTART: System restarted --
*Dec 12 16:41:05.577: %SPA_OIR-6-ONLINECARD: SPA (4XGE-BUILT-IN) online in subslot 0/0
Router>
Router>en
Router#conf t
Enter configuration commands, one per line.  End with CNTL/Z.
Router(config)#in
Router(config)#int
Router(config)#interface lo
Router(config)#interface loo
Router(config)#interface loopback 0
Router(config-if)#ip ad
Router(config-if)#ip address 19
*Dec 12 16:42:04.778: %LINEPROTO-5-UPDOWN: Line protocol on Interface Loopback0, changed state to up2.1
Router(config-if)#ip address 192.168.0.1 255.255.255.0
Router(config-if)#exit
Router(config)#exit
Router#sho
Router#show run
Router#show running-config int
Router#show running-config interface
*Dec 12 16:42:18.204: %SYS-5-CONFIG_I: Configured from console by consolelo
Router#show running-config interface lo0
Router#show running-config interface loo
Router#show running-config interface loopback 0
Building configuration...
Current configuration : 65 bytes
interface Loopback0
end
Router#ping 192.168.0.1
Sending 5, 100-byte ICMP Echos to 192.168.0.1, timeout is 2 seconds:
Success rate is 0 percent (0/5)
Router#sho
Router#show in
Router#show in
Router#show inte
Router#show interfaces lo
Router#show interfaces loo
Router#show interfaces loopback 0
Loopback0 is up, line protocol is up
  Hardware is Loopback
  Internet address is 192.168.0.1/24
  MTU 1514 bytes, BW 8000000 Kbit/sec, DLY 5000 usec,
  Encapsulation LOOPBACK, loopback not set
  Keepalive set (10 sec)
  Last input never, output never, output hang never
  Queueing strategy: fifo
  Output queue: 0/0 (size/max)
     0 packets input, 0 bytes, 0 no buffer
     Received 0 broadcasts (0 IP multicasts)
     0 input errors, 0 CRC, 0 frame, 0 overrun, 0 ignored, 0 abort
     0 packets output, 0 bytes, 0 underruns
     0 unknown protocol drops
Router#
Router#
*Dec 12 16:43:06.922: %TRANSCEIVER-6-INSERTED: SIP0/0: transceiver module inserted in GigabitEthernet0/0/0
Router#sho
Router#show run
Router#show running-config interface gi0/0/
% Incomplete command.
Router#conf t
Router(config)#in
Router(config)#int
Router(config)#interface gi0/0
Router(config)#interface gi0/0/0
Router(config-if)#no shu
Router(config-if)#no shutdown
*Dec 12 16:43:44.764: %LINK-3-UPDOWN: Interface GigabitEthernet0/0/0, changed state to down68.2.
*Dec 12 16:43:43.813: %LINK-3-UPDOWN: SIP0/0: Interface GigabitEthernet0/0/0, changed state to down1
*Dec 12 16:43:47.440: %LINK-3-UPDOWN: Interface GigabitEthernet0/0/0, changed state to up
*Dec 12 16:43:46.437: %LINK-3-UPDOWN: SIP0/0: Interface GigabitEthernet0/0/0, changed state to up
*Dec 12 16:43:48.440: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet0/0/0, changed state to up
Router(config-if)#ip address 192.168.2.1 255.255.255.0
Router(config)#exit
Router#sho
Router#show run
*Dec 12 16:43:56.015: %SYS-5-CONFIG_I: Configured from console by consolegi
Router#show running-config interface gigabitEthernet 0/0/0
Current configuration : 94 bytes
interface GigabitEthernet0/0/0
 negotiation auto
end
Router#ping 192.168.2.2
Sending 5, 100-byte ICMP Echos to 192.168.2.2, timeout is 2 seconds:
Router#sho
Router#show in
Router#show inte
Router#show interfaces gi
Router#show interfaces gigabitEthernet 0/0/0
GigabitEthernet0/0/0 is up, line protocol is up
  Hardware is 4XGE-BUILT-IN, address is 8843.e100.7300 (bia 8843.e100.7300)
  Internet address is 192.168.2.1/24
  MTU 1500 bytes, BW 1000000 Kbit/sec, DLY 10 usec,
  Keepalive not supported
  Full Duplex, 1000Mbps, link type is auto, media type is LX
  output flow-control is off, input flow-control is off
  Last input never, output 00:00:27, output hang never
  Input queue: 0/375/0/0 (size/max/drops/flushes); Total output drops: 0
  Output queue: 0/40 (size/max)
     17 packets input, 2015 bytes, 0 no buffer
     0 watchdog, 17 multicast, 0 pause input
     0 output errors, 0 collisions, 4 interface resets
     0 lost carrier, 0 no carrier, 0 pause output
Router#sho
Router#show pl
Router#show platform
Chassis type: ASR1002
Slot      Type                State                 Insert time (ago)
0         ASR1002-SIP10       ok                    00:06:40
 0/0      4XGE-BUILT-IN       ok                    00:03:56
R0        ASR1002-RP1         ok, active            00:06:40
F0                            unknown               00:06:40
P0        ASR1002-PWR-AC      ok                    00:05:28
P1        ASR1002-PWR-AC      ps, fail              00:05:28
Slot      CPLD Version        Firmware Version
0         07120202            12.2(33r)XNC
R0        08011017            12.2(33r)XNC
F0        N/A                 N/A
Router#
System Bootstrap, Version 12.2(33r)XNC, RELEASE SOFTWARE (fc1)
Copyright (c) 2009 by cisco Systems, Inc.
Current image running: Boot ROM0
Last reset cause: PowerOn
Last reset at: Fri Dec 12 16:48:51 UTC 2014
ASR1002-RP1 platform with 4194303 Kbytes of main memory
Warning: filesystem is not clean
Located asr1000rp1-adventerprisek9.03.04.01.S.151-3.S1.bin
Image size 312873272 inode num 13, bks cnt 76386 blk size 8*512
Boot image size = 312873272 (0x12a61138) bytes
Missing or illegal ip address for variable DEFAULT_GATEWAY
Using midplane macaddr
Missing or illegal ip address for variable IP_ADDRESS
Missing or illegal ip address for variable IP_SUBNET_MASK
Package header rev 0 structure detected
Calculating SHA-1 hash...done
validate_package: SHA-1 hash:
        calculated 61d80af0:032b96a1:6b3b2b5c:667f969a:ad8e4c9f
        expected   61d80af0:032b96a1:6b3b2b5c:667f969a:ad8e4c9f
Image validated
%IOSXEBOOT-4-FILESYS_ERRORS_CORRECTED: (rp/0): bootflash contained errors which were auto-corrected.
              Restricted Rights Legend
Use, duplication, or disclosure by the Government is
           cisco Systems, Inc.
software.
export@cisco.com.
% Please answer 'yes' or 'no'.
*Dec 12 16:52:16.032: %ASR1000_RP_NV-3-NV_ACCESS_FAIL: Initial read of NVRAM contents failed
*Dec 12 16:52:24.113: %LINK-3-UPDOWN: Interface Lsmpi0, changed state to up
*Dec 12 16:52:24.114: %LINK-3-UPDOWN: Interface EOBC0, changed state to up
*Dec 12 16:52:24.114: %LINEPROTO-5-UPDOWN: Line protocol on Interface VoIP-Null0, changed state to up
*Dec 12 16:52:24.115: %LINEPROTO-5-UPDOWN: Line protocol on Interface LI-Null0, changed state to up
*Dec 12 16:52:24.11
Router>5: %LINK-3-UPDOWN: Interface GigabitEthernet0, changed state to down
*Dec 12 16:52:24.115: %LINK-3-UPDOWN: Interface LIIN0, changed state to up
*Dec 12 16:52:24.361: %NETCLK-5-NETCLK_MODE_CHANGE: Network clock source not available. The network clock has changed to freerun
*Dec 12 16:52:24.656: %ASR1000_MGMTVRF-6-CREATE_SUCCESS_INFO: Management vrf Mgmt-intf created with ID 1, ipv4 table-id 0x1, ipv6 table-id 0x1E000001
*Dec 12 16:52:25.151: %LINEPROTO-5-UPDOWN: Line protocol on Interface Lsmpi0, changed state to up
*Dec 12 16:52:25.152: %LINEPROTO-5-UPDOWN: Line protocol on Interface EOBC0, changed state to up
*Dec 12 16:52:25.152: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet0, changed state to down
*Dec 12 16:52:25.152: %LINEPROTO-5-UPDOWN: Line protocol on Interface LIIN0, changed state to up
*Dec 12 16:52:25.546: %DYNCMD-7-PKGINT_INSTALLED: The command package 'platform_trace' has been succesfully installed
*Dec 12 16:52:28.680: %DYNCMD-7-CMDSET_LOADED: The Dynamic Command set has been loaded from the Shell Manager
*Dec 12 16:52:15.830: %IOSXE-5-PLATFORM: R0/0: xinetd[31943]: xinetd Version 2.3.14 started with no options compiled in.
*Dec 12 16:52:15.844: %IOSXE-5-PLATFORM: R0/0: xinetd[31943]: Started working: 1 available service
*Dec 12 16:52:50.090: %LINK-5-CHANGED: Interface GigabitEthernet0/0/0, changed state to administratively down
*Dec 12 16:52:50.091: %LINK-5-CHANGED: Interface GigabitEthernet0/0/1, changed state to administratively down
*Dec 12 16:52:50.091: %LINK-5-CHANGED: Interface GigabitEthernet0/0/2, changed state to administratively down
*Dec 12 16:52:50.091: %LINK-5-CHANGED: Interface GigabitEthernet0/0/3, changed state to administratively down
*Dec 12 16:52:50.092: %LINK-5-CHANGED: Interface GigabitEthernet0, changed state to administratively down
*Dec 12 16:52:51.090: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet0/0/0, changed state to down
*Dec 12 16:52:51.091: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet0/0/1, changed state to down
*Dec 12 16:52:51.092: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet0/0/2, changed state to down
*Dec 12 16:52:51.092: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet0/0/3, changed state to down
*Dec 12 16:52:57.608: %ASR1000_OIR-6-REMSPA: SPA removed from subslot 0/0, interfaces disabled
*Dec 12 16:52:57.609: %SPA_OIR-6-OFFLINECARD: SPA (4XGE-BUILT-IN) offline in subslot 0/0
*Dec 12 16:52:57.613: %ASR1000_OIR-6-INSCARD: Card (cc) inserted in slot 0
*Dec 12 16:52:57.613: %ASR1000_OIR-6-ONLINECARD: Card (cc) online in slot 0
*Dec 12 16:52:57.615: %ASR1000_OIR-6-INSSPA: SPA inserted in subslot 0/0
*Dec 12 16:52:57.819: %SYS-5-RESTART: System restarted --
*Dec 12 16:53:00.828: %SPA_OIR-6-ONLINECARD: SPA (4XGE-BUILT-IN) online in subslot 0/0
Router>en
Router#sho
Router#show pla
0         ASR1002-SIP10       ok                    00:02:40
 0/0      4XGE-BUILT-IN       ok                    00:00:22
R0        ASR1002-RP1         ok, active            00:02:40
P0        ASR1002-PWR-AC      ok                    00:01:56
P1        ASR1002-PWR-AC      ps, fail              00:01:55
0         ASR1002-SIP10       ok                    00:02:52
 0/0      4XGE-BUILT-IN       ok                    00:00:34
R0        ASR1002-RP1         ok, active            00:02:52
P0        ASR1002-PWR-AC      ok                    00:02:08
P1        ASR1002-PWR-AC      ps, fail              00:02:07
Router#sho
Router#show fa
Router#show facility-alarm
Router#
Router#show facility-alarm ?
  status  Show Facility Alarms Status
Router#show facility-alarm st
Router#show facility-alarm status
System Totals  Critical: 1  Major: 0  Minor: 0
Source              Severity      Description [Index]
Power Supply Module 1      CRITICAL      Power Supply Failure [0]
xcvr container 0/0/0       INFO          Transceiver Missing [0]
xcvr container 0/0/1       INFO          Transceiver Missing [0]
xcvr container 0/0/2       INFO          Transceiver Missing [0]
xcvr container 0/0/3       INFO          Transceiver Missing [0]
Router#conf t
Router(config)#in
Router(config)#it
Router(config)#int
*Dec 12 16:53:59.059: %LINEPROTO-5-UPDOWN: Line protocol on Interface Loopback0, changed state to up192.168.0.1 255.255.255.0
Router(config)#exit
Router#sho
Router#show
*Dec 12 16:54:10.654: %SYS-5-CONFIG_I: Configured from console by consolerun
Router#show running-config interface go
interface Loopback0
end
Router#sgi
Router#sho
Router#show he
Router#show he
Router#show he?
% Unrecognized command
Router#show ?
  aaa                   Show AAA values
  access-expression     List access expression
  access-lists          List access lists
  accounting            Show accounting
  acircuit              Access circuit info
  adjacency             Adjacent nodes
  aliases               Display alias commands
  alignment             Show alignment information
  alps                  Alps information
  ancp                  ANCP information
  apollo                Apollo network information
  appfw                 Application Firewall information
  appletalk             AppleTalk information
  aps                   APS information
  arap                  Show Appletalk Remote Access statistics
  archive               Archive functions
  arp                   ARP table
  async                 Information on terminal lines used as router interfaces
  auto                  Show Automation Template
  backup                Backup status
  beep                  Show BEEP information
  bfd                   BFD protocol info
  bgp                   BGP information
  bootflash:            display information about bootflash: file system
  bootlog               Show bootlog contents
  bootvar               Boot and related environment variable
  bridge                Bridge Forwarding/Filtering Database [verbose]
  bridge-domain         Bridge-domain
  bsc                   BSC interface information
  bstun                 BSTUN interface information
  buffers               Buffer pool statistics
  call                  Show call
  call-home             Show command for call home
  capability            Capability Information
  cca                   CCA information
  cce                   Common Classification Engine (CCE)
  ccm                   CCM HA Information
  cdp                   CDP information
  cef                   CEF address family independent status
  cem                   CEM information
  checkpoint            Checkpoint Facility (CF)
  class                 Cem class information
  class-map             Show CPL Class Map
  clns                  CLNS network information
  clock                 Display the system clock
  cls                   DLC user information
  cns                   CNS agents
Router#show cpu
Router#show cpu
Router#show cpu?
Router#show cpu ?
Router#show c
Router#show c?
call      call-home      capability  cca
cce       ccm            cdp         cef
cem       checkpoint     class       class-map
clns      clock          cls         cns
compress  configuration  connection  controllers
cops      crypto         cts         cube
Router#show uti
Router#show util
Router#show util
Router#show util?
Router#show ut
Router#show ut?
Router#show
Router#show ?
  aaa                   Show AAA values
  aps                   APS information
  arp                   ARP table
  bgp                   BGP information
  call                  Show call
  cca                   CCA information
  cdp                   CDP information
  cem                   CEM information
  cns                   CNS agents
  compress              Show compression statistics
  configuration         Contents of Non-Volatile memory
  connection            Show Connection
  controllers           Interface controller status
  cops                  COPS information
  crypto                Encryption module
  cts                   Cisco Trusted Security information
  cube                  Show cube info
  dampening             Display dampening information
  data-corruption       Show data errors
  database              Show Database
  debugging             State of each debugging option
  decnet                DECnet information
  derived-config        Derived operating configuration
  dhcp                  Dynamic Host Configuration Protocol status
  diag                  Show diagnostic and eeprom information
  diagnostic            Show command for diagnostic
  dial-peer             Dial Plan Mapping Table for, e.g. VoIP Peers
  dialer                Dialer parameters and statistics
  dialplan              Voice telephony dial plan
  dlsw                  Data Link Switching information
  dmvpn                 Display DMVPN session related information
  dnsix                 Shows Dnsix/DMDP information
  drip                  DRiP DB
  dspfarm               Display DSPFARM related information
  dspu                  Display DSPU information
  dwnld_mgr             Download Manager
  dxi                   atm-dxi information
  eap                   Shows EAP registration/session information
  eigrp                 EIGRP show commands
  entry                 Queued terminal entries
  environment           Environmental Monitoring
  eobc                  Cat 6000 out of band (EOBC) interface show commands
  esmc                  Ethernet Synchronization Messaging Channel
  etherchannel          EtherChannel Parameters
  ethernet              Ethernet parameters
  event                 Embedded event related commands
  event-manager         Event manager information
  exception             exception informations
  facility-alarm        Show Facility Alarms
  file                  Show filesystem information
  flash:                display information about flash: file system
  flow                  Flow information
  flow-sampler          Display the flow samplers configured
  format                Show format information
  fpd:                  display information about fpd: file system
  frame-relay           Frame-Relay information
  fras                  FRAS Information
  fras-host             FRAS Host Information
  funi                  FUNI information
  gateway               Show status of gateway
  glbp                  GLBP information
  h323                  Show H.323 VoIP information
  history               Display the session command history
  hosts                 IP domain-name, lookup style, nameservers, and host
                        table
  html                  HTML helper commands
  http                  Display HTTP info
  hw-module             Show hardware module commands
  hw-programmable       Show hw-programmable information
  idb                   List of Interface Descriptor Blocks
  idmgr                 IDMGR interaction
  if-mgr                if-mgr information
  ifnum                 IDB Interface Index (Number)
  ima                   Display IMA Interfaces
  interfaces            Interface status and configuration
  inventory             Show the physical inventory
  ip                    IP information
  ipam                  IP Addr Mgr (IPAM) information
  ipc                   Interprocess communications commands
  ipv6                  IPv6 information
  isis                  IS-IS routing information
  issu                  ISSU Information
  kerberos              Show Kerberos Values
  key                   Key information
  keymap                Terminal keyboard mappings
  kron                  Kron Subsystem
  l3vpn                 l3vpn encapsulation ip commands
  lacp                  Port channel information
  lat                   DEC LAT information
  license               Show licensing information
  line                  TTY line information
  lisp                  Locator/ID Separation Protocol
  llc2                  IBM LLC2 circuit information
  lnm                   IBM LAN manager
  local-ack             Local Acknowledgement virtual circuits
  location              Display the system location
  logging               Show the contents of logging buffers
  login                 Display Secure Login Configurations and State
  management            Display the management applications
  management-interface  Host management-interface information
  media                 Display media related information
  memory                Memory statistics
  mfib                  MFIB address family independent status
  modem                 Show modem
  modemcap              Show Modem Capabilities database
  monitor               Monitoring different system events
  mpls                  MPLS information
  mrcp                  MRCP information
  mtm                   MTM
  mvr                   Show mvr global parameters
  nat64                 NAT64 information
  nbf                   NBF (NetBEUI) information
  ncia                  Native Client Interface Architecture
  netbios-cache         NetBIOS name cache contents
  netconf               Show NETCONF information
  network-clocks        Network clocks information
  nhrp                  Display NHRP related information
  node                  Show known LAT nodes
  ntp                   Network time protocol
  num-exp               Number Expansion (Speed Dial) information
  obfl:                 display information about obfl: file system
  odm-format            Show the schema used for ODM input file
  oer                   Performance Routing (PfR) information
  ospfv3                OSPFv3 information
  parameter-map         parameter map information
  parser                Display parser information
  per-call              Per call debug
  persistent            Show persistent information
  pfr                   Performance Routing(PfR) information
  platform              Show platform information
  policy-firewall       show firewall statistics
  policy-manager        Policy Manager
  policy-map            Show Policy Map
  ppp                   PPP parameters and statistics
  pppatm                PPP over ATM
  pppoe                 PPPoE information
  privilege             Show current privilege level
  processes             Active process statistics
  protocols             Active network routing protocols
  qbm                   QoS Bandwidth Manager information
  qllc                  Display qllc-llc2 and qllc-sdlc conversion information
  radius                Shows radius information
  radius-proxy          Shows radius-proxy client/session information
  rbscp                 RBSCP information
  recovered-clock       Clock recovery information
  redirect              Show L4 redirect information
  redundancy            Redundancy Facility (RF) information
  region                Region Manager Status
  registry              Function registry information
  reload                Scheduled reload information
  resource              Display Resource Usage/Relations and more details
  resource-group        Resource group statistics
  rhosts                Remote-host+user equivalences
  rib                   Routing Information Base
  rif                   RIF cache entries
  rmi                   Resource User Infrastructure information
  rmon                  rmon statistics
  rom-monitor           Show ROMMON version information
  romvar                All ROMMON environment variables
  route-map             route-map information
  rpms-proc             RPMS Process Information
  rtpspi                RTP Service Provider Interface
  rtsp                  Real Time Streaming Protocol information
  running-config        Current operating configuration
  sampler               Sampler information
  sasl                  show SASL information
  sbc                   Session Border Controller
  sccp                  Display Skinny Client Control Protocol information
  sdllc                 Display sdlc - llc2 conversion information
  service-routing       Service-Routing show commands
  services              LAT learned services
  sessions              Information about Telnet connections
  sgbp                  SGBP group information
  sgcp                  Display Simple Gateway Control Protocol information
  sgi                   Show SGI information
  sip-ua                Show SIP User Agent
  smf                   Software MAC filter
  smrp                  Simple Multicast Routing Protocol (SMRP) information
  sna                   Display SNA host information
  snapshot              Snapshot parameters and statistics
  snmp                  snmp statistics
  source-bridge         Source-bridge parameters and statistics
  spanning-tree         Spanning tree topology
  srp                   SRP information
  ssh                   Status of SSH server connections
  ssm                   Segment Switching Manager Status
  stacks                Process stack utilization
  standby               Hot Standby Router Protocol (HSRP) information
  startup-config        Contents of startup configuration
  stun                  STUN status and configuration
  subscriber            Subscriber Service Switch Information
  subscriber-policy     Subscriber policy
  subscription          Subscription information to show
  subsys                Show subsystem information
  tacacs                Shows tacacs+ server statistics
  tarp                  TARP information
  tcp                   Status of TCP connections
  tech-support          Show system information for Tech-Support
  template              Template information
  terminal              Display terminal configuration parameters
  time-range            Time range
Router#show sho
Router#show st
Router#show st
Router#show sta
Router#show sta?
stacks  standby  startup-config
Router#show stac
Router#show stacks
Minimum process stacks:
 Free/Size   Name
11384/12000  ISSU Infra API Delayed Registration Process
11400/12000  CDP BLOB
22936/24000  MRIB IPv4 Init Process
23240/24000  MRIB IPv6 Init Process
 7768/12000  MGMT VRF Process
10168/12000  EEM Shell Director
11352/12000  Autoinstall
45240/48000  Setup
23080/24000  BootP Resolver
11000/12000  DHCPv6 Bulk LQ
 9080/12000  ASR1000 LIIN config
11400/12000  Inspect Init Msg
11384/12000  SPAN Subsystem
11400/12000  WEBUI CONFIG SEND PROC
118536/120000  EEM Auto Registration Proc
11400/12000  SASL MAIN
119176/120000  script background loader
 9544/12000  IPC ISSU Versioning Process
 9336/12000  IPC ISSU Receive Process
10680/12000  RTTY Client Registration
38408/48000  Init
11192/12000  RADIUS INITCONFIG
23352/24000  DHCP Autoinstall
 5160/6000   Rom Random Update Process
11352/12000  URPF stats
Interrupt level stacks:
Level    Called Unused/Size  Name
  2           0  57392/65536  Network Interrupt
  3           0  52256/65536  Aux Thread
Router#sho
Router#show ?
  aaa                   Show AAA values
  aps                   APS information
  arp                   ARP table
  bgp                   BGP information
Router#show cpu
Router#show cpu?
Router#show cpu ?
Router#show cpu
Router#show
*Dec 12 16:57:20.919: %NETCLK-5-NETCLK_MODE_CHANGE: Network clock source not available. The network clock has changed to freerun
*Dec 12 16:59:37.316: %TRANSCEIVER-6-INSERTED: SIP0/0: transceiver module inserted in GigabitEthernet0/0/1
% Type "show ?" for a list of subcommands
Router#
Router#conf t
Router(config)#in
Router(config)#int
Router(config)#interface gigabitEthernet 0/0/1
Router(config-if)#ip address 192.167
*Dec 12 17:00:18.100: %LINK-3-UPDOWN: Interface GigabitEthernet0/0/1, changed state to dow
*Dec 12 17:00:18.002: %LINK-3-UPDOWN: SIP0/0: Interface GigabitEthernet0/0/1, changed state to down8.
*Dec 12 17:00:20.698: %LINK-3-UPDOWN: Interface GigabitEthernet0/0/1, changed state to up
*Dec 12 17:00:20.549: %LINK-3-UPDOWN: SIP0/0: Interface GigabitEthernet0/0/1, changed state to up
*Dec 12 17:00:21.698: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet0/0/1, changed state to up.5.1 255.255.255.0
% Invalid input detected at '^' marker.
Router(config-if)#ip address 192.168.5.1 255.255.255.0
Router(config)#exit
Router#sho
Router#show
*Dec 12 17:00:35.752: %SYS-5-CONFIG_I: Configured from console by consolerun
Router#show run
Router#show running-config interface GigabitEthernet0/0/1,
 negotiation auto
end
Router#ping 192.168.5.1
Sending 5, 100-byte ICMP Echos to 192.168.5.1, timeout is 2 seconds:
Success rate is 0 percent (0/5)        |                             |
Router#ping 192.168.5.3        |  Cannot open /dev/ttyUSB0!  |
Type escape sequence to abort.        |                             |
Sending 5, 100-byte ICMP Echos to 192.168.5.3, timeout is 2 seconds:                              +-----------------------------+
Router#show Q
Router#show in
Router#show P5Q
Router#show in
Router#show inte
Router#show interfaces gigabitEthernet 0/0/1
GigabitEthernet0/0/1 is up, line protocol is up
  Hardware is 4XGE-BUILT-IN, address is 8843.e100.7301 (bia 8843.e100.7301)
  Internet address is 192.168.5.1/24
  Last input never, output 00:01:49, output hang never
     103 packets input, 12209 bytes, 0 no buffer
     0 watchdog, 103 multicast, 0 pause input
Router#
*Dec 12 17:03:51.755: %LINK-3-UPDOWN: Interface GigabitEthernet0/0/1, changed state to down
*Dec 12 17:03:51.709: %LINK-3-UPDOWN: SIP0/0: Interface GigabitEthernet0/0/1, changed state to down
*Dec 12 17:03:52.755: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet0/0/1, changed state to down
*Dec 12 17:04:08.316: %TRANSCEIVER-6-REMOVED: SIP0/0: Transceiver module removed from GigabitEthernet0/0/1BAAAD
0 Replies 0
