suspended: LACP currently not enabled on the remote port.
sebastien3
Level 4
Level 4
I have two 4500-X on which I want to activate an LACP :
interface Port-channel3
switchport
switchport mode trunk
interface TenGigabitEthernet1/1/14
channel-protocol lacp
channel-group 3 mode passive OR active
end
TenGigabitEthernet1/1/14 is up, line protocol is down (suspended)
I don't understand why I systematically get the message LACP currently not enabled ?
follow
 what do you have connected on this interface?  Does it supports LACP? Have  you tried with "channel-group 3 mode  on"
Port in suspended means the other side may refuse to agree on the LACP mode.
sebastien3
Level 4
Level 4
I found the problem ! Switches use VSS... The virtual-domain is identical on the 4500-X pair.
By changing the virtual domain on a pair the LACP works. However, I don't really understand why this has an influence ?
Virtual domain must be different and port channle mode should be ON.
