SVI and Router on a Stick
MrBeginner
I am confusing performance of SVI and Inter VLAN routing.
I would like to know which is more best practice. I have two scenario.
Eg.
1. cisco c892 have 2 x 1G WAN port and 8x 1G Switches port.we can configure one port as a trunk port and i create interface VLAN in router and run static route to communicate to our DC.(We are not using internet access).
2. i configure routing on the stick by creating sub interface in router PORT and route.
i would like to know which one can get best performance ?
Which one can control easily ?
All are the same ?
Francesco Molino
In a standard network, they are quite the same. On this this router, because you have a switch integrated, spanning-tree will be working no matter if it's a svi or sub interface.
In terms of software, depending on the platform and ios version, you can have some limitations on a svi. The most frequent are service policies capabilities differ if it's on a svi vs sub interface.
There's also a delay for convergence time that's higher on a svi compared to sub interface which is the lowest.
Francesco
PS: Please don't forget to rate and select as validated answer if this answered your question
Hello
if this router has an intergrated switch then run the vlans off an SVI (interface vlan xx)
Kind Regards
Paul
Hi ,
if i use ASR router 1001-X.and I didn't use L3 switches.if i use l2 switches,what kind of scenario should i use ?
router on the stick only ?
Hello
@MrBeginner wrote:
Hi ,
Yes that is correct ..
Kind Regards
Paul
