SVI line up / protocol down using trunks
anaxagoras
switch is a 3750x running ipbase Version 15.2(4)E7
I'm having the classic problem with line up, protocol down on every SVI except vlan 1.  I'm a total newb to managed networking gear.
Now this is a test lab, All active ports are trunked.  i have 2 esxi servers, a couple of ubiquiti AP's that also support vlan tagging, and a router.  Currently we're in "router on a stick" mode which i'd like to change to layer 3 routing for performance.
So right now i'm just going to work with vlan 300.
Now as i understand with autostate:
The router VLAN interfaces have to fulfill the following general conditions to be up/up:
  • VLAN exists and is in active status on the switch VLAN database.
    • show vlan
      300 VLAN300-SecureWifi active
  • VLAN interface exists on the router and is not administratively down.
    • show interfaces vlan 300
      Vlan300 is up, line protocol is down
  • At least one L2 (access port or trunk) port exists and has a link up on this VLAN. The latest implementation of the autostate feature allows synchronization to Spanning-Tree Protocol (STP) port status.
    • I have multiple trunks that are active and carry this vlan, and i can ping from host to host
  • At least one L2 (access port or trunk) port is in spanning-tree forwarding state on the VLAN.
    • c3750x#show spanning-tree vlan 300
      VLAN0300
      Spanning tree enabled protocol ieee
      Root ID Priority 33068
      Address 6073.5c21.0780
      This bridge is the root
      Hello Time 2 sec Max Age 20 sec Forward Delay 15 sec
      Bridge ID Priority 33068 (priority 32768 sys-id-ext 300)
      Aging Time 300 sec
      Interface Role Sts Cost Prio.Nbr Type
      Gi1/0/1 Desg FWD 4 128.1 P2p
      Gi1/0/11 Desg FWD 4 128.11 P2p
      Gi1/0/29 Desg FWD 4 128.29 P2p
      Gi1/0/33 Desg FWD 4 128.33 P2p
      Gi1/0/48 Desg FWD 4 128.48 P2p
So what the heck am i doing wrong because as far as i can tell i meet all the paramaters?  I have also tried issuing shut/no shut to the vlan interface with no results.
15 Replies 15
it appears to be working now and all svi's seem to be comming up after passing some traffic across the vlan.
in exec mode i had to run
vtp primary vlan
