Control, Data and Management Plane Policing on 4500 Switch
stamati76
How do you configure control/service/management plane policing on a CIsco 4507
Aggregating the policy map to include all the system defined control traffic seems the easy option and i assume not best practice.  How would you therefore decide the correct conform rate for the respective traffic?
Furthermore, which traffic would you police on the management and service plane?
Thanks in advance
balaji.bandi
Hope this guide will help you to start with :
https://www.cisco.com/c/en/us/td/docs/switches/lan/catalyst4500/XE3-7-0E/15-23E/configuration/guide/xe-370-configuration/cntl_pln.pdf
BB
Yes i have read that document to start with, but i would like to know how to calculate the correct traffic within each policy map?
I was thinking of monitoring the traffic and filtering each traffic to work out a normal police rate for our network.  However, i was hoping there would be an easier way?
Are there further examples on configuring the management/service plane?
Any advice would be greatly appreciated
