SVI
iisraelivan
Community Member
I have a small problem:
I have 2 SVIs in the same router 7600 cisco:
int vlan 466
ip add 10.10.10.1 /29
int vlan 3300
ip add 10.10.20.1/29
Connect 2 PCs in the same router 7600 cisco, one in each vlan:
1.-  ip 10.10.10.3, gw 10.10.10.1
2.- ip 10.10.20.5, gw 10.10.20.1
I can ping PC1 to PC2 and I can ping PC2 to PC1, but after when i want ping again PC1 to PC2 lost connectivity.
Why I lost connectivity when i ping the second time??
Can i help me, please. Thanks
pwwiddicombe
Level 9
Level 9
Can we see the output of the following command from PC1 when the ping fails?
tracert 10.10.20.5
This should show if the gateway or remote address isn't responding.
sure,
The first hop is to SVI 466 (gw) 10.10.20.1 and the second hop is timeout request. Is when fails
But when i can do ping the first hop is 10.10.20.1 and the second hop is the host 10.10.20.5.
i forgot,
i can ping from PC1 and PC2 both SVIs 10.10.10.1 and 10.10.20.1 always, never lost connectivity
