%SW_MATM-4-MACFLAP_NOTIF: Problem
infosateng
Hello Pros
I had a problem on a number of switches recently for an hour, and I'm trying to findout why.  I've never seen this error before, and our network has never had a Loop, but for some reason whether is was the design or a software or hardware problem we had one.  We have a number of 3750 switch stacks that connect together, some connect with Port-Channels, some just have a single connection, but all seems to have this problem at the same time.
If you look at the diagram attached, which is a cut down version, each switch stack connects to Switch Stack 2 on a single VLAN only, but Switch Stack 2 and 3 reported a problem on all VLANs that are Trunked accross the link.  The primary connection between Switch Stack2 and 3 is a 1Gb Fiber, and the Secondary connection  is 100Mb Wireless.  All the traffic goes across the Fiber as I have a ST cost of 100 on the Wireless
I'd just like to know the following if possible.
1.  Could the design be part of the problem and how can I keep the connectivity to my second data center loop free.
2.  Could it be a software related, all switch stacks are running IOS 3750-ipservicesk9-mz.122-53.SE1.bin
3. If there was a problem some where on the Fiber that my ISP isn't letting me know, could this have caused the problem.
See some more info below, and again I've attached a network diagram.
! Switch Stack 1
interface Port-channel1
switchport access vlan 10
switchport mode access
speed 100
duplex full
interface FastEthernet2/0/45
speed 100
duplex full
channel-group 1 mode on
interface FastEthernet3/0/45
speed 100
duplex full
#sho spanning-tree vlan 10
VLAN0010
  Spanning tree enabled protocol ieee
  Root ID    Priority    32860
             Address     000f.f7a9.c680
             This bridge is the root
             Hello Time   2 sec  Max Age 20 sec  Forward Delay 15 sec
  Bridge ID  Priority    32860  (priority 32768 sys-id-ext 92)
             Aging Time  300 sec
Interface           Role Sts Cost      Prio.Nbr Type
Po1                 Desg FWD 12        128.504  P2p
Po2                 Desg FWD 12        128.512  P2p
Po3                 Desg FWD 12        128.520  P2p
Po4                 Desg FWD 19        128.496  P2p
! Switch Stack 2
speed 100
duplex full
interface GigabitEthernet1/0/6
speed 100
duplex full
interface GigabitEthernet2/0/6
speed 100
duplex full
interface GigabitEthernet1/0/1
description Trunk to Data Center 2 (Via Fiber)
switchport mode trunk
speed 1000
duplex full
interface GigabitEthernet2/0/1
description Trunk to Data center 2 over 100Mb Wireless
speed 100
duplex full
spanning-tree vlan 1,10-13 cost 100
VLAN0010
             Cost        12
             Port        520 (Port-channel5)
             Address     6416.8d15.5980
             Aging Time  300 sec
Gi1/0/1             Desg FWD 4         128.1    P2p
Po1                 Root FWD 12        128.520  P2p
Gi2/0/1             Desg FWD 100       128.55   P2p
5 Replies 5
infosateng
Hello
Does anyone have an idea what the best practises are for setting up Spanning-tree between 2 3750 Switch Stacks, or if you can look at the diagram let me know if the something is obviously wrong
I assume in Data Center there should be SwitchStack 3 instead of 2? Can show output of STP for VLAN 10 on Stack 3?
And what about other VLANs 11,12,13? Output and settings for STP the same?
Abzal
Best regards,
Abzal
Hi Abzal
Yes its should be SwitchStack 3
! SwitckStack 3
VLAN0010
             Cost        16
             Port        1 (GigabitEthernet1/0/1)
             Address     6416.8d44.fd80
             Aging Time  300 sec
Gi1/0/1             Root FWD 4         128.1    P2p
Gi2/0/1             Altn BLK 100       128.55   P2p
Gi2/0/3             Desg FWD 19        128.57   P2p
Gi2/0/4             Desg FWD 19        128.58   P2p
Gi1/01 is the Fiber
Gi2/0/1 is the Wireless
Gi2/0/3 and Gi2/0/4 are Trunks to other switches with just one connection to each
Spanning-Tree output for other VLANs are the same for the connections to the fiber and Wireless, but have single connections to other switches on different ports, but same output as Gi2/0/3 and Gi2/0/4
Hello Abzal
Do you have an update or can anyone else give me some assistance
Select one root bridge and make it manually.
spanning-tree vlan 1,10-13 priority 0
Then make sure that the EtherChannel Port is UP via “show ip int brief” command or “show etherchannel summary”.
Look output mac address table of flapping MAC address:
sh mac address-table command will show you whether or not those ports belong to Po or Port-Channel interface.
Abzal
Best regards,
Abzal
