%SW_MATM-4-MACFLAP_NOTIF
susim
Level 3
Level 3
Hi ,
i have a vss enabled switch (6800) as uplink wi th multiple vlan
I just connected a 3650x to the 6800 using trunk , there was  some vlans creted  on the switch already . ( it's not same as the uplink switch )
Then  connected one device to the one of the port and assigned vlan . Everything was ok . after some time i did a shut and no shut the interface where the device connected .From that moment i was getting the following flap error
%SW_MATM-4-MACFLAP_NOTIF: Host 00eb in vlan 20 is flapping between port Te1/1 and port Gi0/1
 %SW_MATM-4-MACFLAP_NOTIF: Host 00e6 in vlan 20 is flapping between port Gi0/1 and port Te1/1
NOTIF: Host .fef0 in vlan 20 is flapping between port Gi0/1 and port Te1/1
W_MATM-4-MACFLAP_NOTIF: Host .00e5 in vlan 20 is flapping between port Gi0/1 and port Te1/1
Uplink switch running rstp and downlink running pvst
6 Replies 6
InayathUlla Sharieff
Is the mac address constant which is flapping between the ports?
if not then could you please provide me the config of the ports connecting between the switches?
Is there only one link from 3560 to VSS or you have two links?
Is there any other way the 3560 is connecting to VSS(I mean third switch)?
Inayath
6 mac address flapping , which is in another switch
3650 switch all port are in vlan 1 except gi0/1 assigned to vlan 20
vss
interface TenGigabitEthernet2/6/1
  switchport
 switchport mode trunk
 storm-control multicast level 1.00
 storm-control action trap
interface TenGigabitEthernet1/1
sw trunk encapsulation dot 1q
yes
there are multipl switches conneted layer2
Answer: Now you have to trace switch by switch to see if there is any STP loop. Usually the mac flap occurs due to STP loop(Exception for mac address flapping for wireless clients who are in roaming profile you expect to see the mac flap) but other than that if you are seeing it then its clear indication of loop.
1- Take one mac address and check with the ports g0/1 & t1/1
2- Go to the switch which is connected to g0/1 - check for this mac address?
 Check for high cpu/logs- enable mac move and see if you are seeing any mac flap on this box.
3- Same followed to the device T1/1 and go on further to the port/switch were you are seeing the mac address.
REgards
Inayath
****Please do not forget to rate all usefull posts.
Hi ,
You mean to check mac address learning from gi0/1 and t1/1 ?
I am attaching a rough topology
Yes you are right go ahead and verify the mac address via the ports and then follow the procedure to same ton th other switch and see if you are learning it in different way.
Inayath
Actually the flap started the moment i gave sh and no sh command on the interface gi0/1
taken from the switch where flap happens
0006.7601.fef0
Switch#sh mac address-table | in fef0
  20    0006.7601.fef0    DYNAMIC     Te1/1
sh mac address-table interface gi0/1
          Mac Address Table
Vlan    Mac Address       Type        Ports
  19   0006.7601.fede    DYNAMIC     Gi0/1
  19    0006.ba41.1e00    DYNAMIC     Gi0/1
i did not see any flap where the mac address '0006.7601.fede ' involved .
taken from the switch where the device is conneted
sw2#sh mac address-table | in fef0
  20      0006.7601.fef0   dynamic ip,ipx,assigned,other GigabitEthernet10/29
you mean  "mac-address-table notification mac-move" ?
cpu seems to be ok , logs from the switch where flap happens
: %SW_MATM-4-MACFLAP_NOTIF: Host 0006.7601.fef0 in vlan 20 is flapping between port Gi0/1 and port Te1/1
CPU utilization for five seconds: 29%/0%; one minute: 24%; five minutes: 23%
 PID Runtime(ms)   Invoked      uSecs   5Sec   1Min   5Min TTY Process
   1           0         4          0  0.00%  0.00%  0.00%   0 Chunk Manager
   2        5209    206060         25  0.00%  0.00%  0.00%   0 Load Meter
   3          91      8893         10  0.00%  0.00%  0.00%   0 DHCPD Timer
   4    12931546    586111      22063  6.22%  1.52%  1.23%   0 Check heaps
   5          49       208        235  0.00%  0.00%  0.00%   0 Pool Manager
   6           0         2          0  0.00%  0.00%  0.00%   0 Timers
   7           0         2          0  0.00%  0.00%  0.00%   0 License Client N
   8     2489278     17173     144953  0.00%  0.21%  0.20%   0 Licensing Auto U
   9          76         3      25333  0.00%  0.00%  0.00%   0 Image License br
  10         817     17920         45  0.00%  0.00%  0.00%   0 ARP Input
  11           0         1          0  0.00%  0.00%  0.00%   0 CEF MIB API
  12           0         1          0  0.00%  0.00%  0.00%   0 AAA_SERVER_DEADT
  13           0         2          0  0.00%  0.00%  0.00%   0 AAA high-capacit
  14           8         1       8000  0.00%  0.00%  0.00%   0 Policy Manager
  15          34         5       6800  0.00%  0.00%  0.00%   0 Entity MIB API
  16           0         1          0  0.00%  0.00%  0.00%   0 IFS Agent Manage
  17         850     17173         49  0.00%  0.00%  0.00%   0 IPC Dynamic Cach
  18           0         1          0  0.00%  0.00%  0.00%   0 IPC Zone Manager
  19        2337   1005713          2  0.00%  0.00%  0.00%   0 IPC Periodic Tim
  20           0         1          0  0.00%  0.00%  0.00%   0 IPC Managed Time
  21        1955   1005713          1  0.00%  0.00%  0.00%   0 IPC Deferred Por
  22        2501     68688         36  0.00%  0.00%  0.00%   0 IPC Seat Manager
  23           0         1          0  0.00%  0.00%  0.00%   0 IPC Session Serv
  24           0         3          0  0.00%  0.00%  0.00%   0 PrstVbl
  25           0         1          0  0.00%  0.00%  0.00%   0 Crash writer
  26        1262   1005668          1  0.00%  0.00%  0.00%   0 GraphIt
  27           0         2          0  0.00%  0.00%  0.00%   0 SMART
  28           0         2          0  0.00%  0.00%  0.00%   0 XML Proxy Client
  29           0         1          0  0.00%  0.00%  0.00%   0 ARP Snoop
  30        3574   1005714          3  0.00%  0.00%  0.00%   0 Dynamic ARP Insp
  31           0         1          0  0.00%  0.00%  0.00%   0 Critical Bkgnd
  32      107141   1119688         95  0.00%  0.01%  0.00%   0 Net Background
  33           0         1          0  0.00%  0.00%  0.00%   0 IDB Work
  34          18       101        178  0.00%  0.00%  0.00%   0 Logger
  35        1908   1005666          1  0.00%  0.00%  0.00%   0 TTY Background
  36       70513   1005717         70  0.00%  0.05%  0.01%   0 Per-Second Jobs
  37      467357     17381      26888  0.00%  0.03%  0.00%   0 Per-minute Jobs
  38           8         4       2000  0.00%  0.00%  0.00%   0 IF-MGR control p
  39           0        16          0  0.00%  0.00%  0.00%   0 IF-MGR event pro
  40           0         1          0  0.00%  0.00%  0.00%   0 Inode Table Dest
  41           0         1          0  0.00%  0.00%  0.00%   0 AggMgr Process
  42           0         1          0  0.00%  0.00%  0.00%   0 Transport Port A
  43       53952    304209        177  0.00%  0.00%  0.00%   0 HC Counter Timer
  44      105077      1724      60949  0.00%  0.00%  0.00%   0 SFF8472
  45           8        42        190  0.00%  0.00%  0.00%   0 EEM ED Identity
  46           0        83          0  0.00%  0.00%  0.00%   0 EEM ED MAT
  47          26       107        242  0.00%  0.00%  0.00%   0 EEM ED ND
  48          50        81        617  0.00%  0.00%  0.00%   0 USB Startup
  49       36351  20271981          1  0.00%  0.01%  0.00%   0 DownWhenLooped
  50           0         1          0  0.00%  0.00%  0.00%   0 HULC PBR Tcam Me
  51           0         1          0  0.00%  0.00%  0.00%   0 HULC ACL Tcam Me
  52           0         1          0  0.00%  0.00%  0.00%   0 Hulc Warm Upgrad
  53           0         1          0  0.00%  0.00%  0.00%   0 HRPC lpip reques
  54           0         2          0  0.00%  0.00%  0.00%   0 HLPIP Sync Proce
  55           0         1          0  0.00%  0.00%  0.00%   0 HRPC EnergyWise
  56           0         1          0  0.00%  0.00%  0.00%   0 HRPC actual powe
  57       44708   4022660         11  0.00%  0.01%  0.00%   0 HUSB Console
  58           0         2          0  0.00%  0.00%  0.00%   0 SM RBCP Monitor
  59           0         1          0  0.00%  0.00%  0.00%   0 HULC QM Tcam Mem
  60        4823        16     301437  0.00%  0.00%  0.00%   0 X2 HAMM detect p
  61         100      1033         96  0.00%  0.00%  0.00%   0 Net Input
  62       36354    205615        176  0.00%  0.00%  0.00%   0 Compute load avg
  63           0         1          0  0.00%  0.00%  0.00%   0 Madmax Process
  64           0         1          0  0.00%  0.00%  0.00%   0 HRPC asic-stats
  65    24453459  11432449       2138  1.75%  2.19%  2.21%   0 RedEarth I2C dri
  66    44641275   6879748       6488  3.67%  3.92%  4.02%   0 RedEarth Tx Mana
  67       35838   5716218          6  0.00%  0.00%  0.00%   0 RedEarth Rx Mana
  68       30169    206061        146  0.00%  0.00%  0.00%   0 HULC Thermal Pro
  69           0         1          0  0.00%  0.00%  0.00%   0 HRPC hsm request
  70           0         7          0  0.00%  0.00%  0.00%   0 Stack Mgr
  71         268        11      24363  0.00%  0.00%  0.00%   0 Stack Mgr Notifi
  72           8       135         59  0.00%  0.00%  0.00%   0 Adjust Regions
  73        5316   1005704          5  0.00%  0.00%  0.00%   0 hrpc -> response
  74       10320    205626         50  0.00%  0.00%  0.00%   0 hrpc -> request
  75        8040    205636         39  0.00%  0.00%  0.00%   0 hrpc <- response
  76           0         1          0  0.00%  0.00%  0.00%   0 HRPC hcomp reque
  77     2421987   5028279        481  0.15%  0.27%  0.22%   0 yeti2_emac_proce
  78           0         3          0  0.00%  0.00%  0.00%   0 HULC Device Mana
  79           0         3          0  0.00%  0.00%  0.00%   0 HRPC hdm non blo
  80           0         2          0  0.00%  0.00%  0.00%   0 HRPC hdm blockin
  81        1412    205616          6  0.00%  0.00%  0.00%   0 HIPC bkgrd proce
  82           0        24          0  0.00%  0.00%  0.00%   0 Hulc Port-Securi
  83           0         1          0  0.00%  0.00%  0.00%   0 HRPC hpsecure re
  84           0         1          0  0.00%  0.00%  0.00%   0 HRPC hfbm reques
  85         394     17178         22  0.00%  0.00%  0.00%   0 DHCPD Database
  86           0         1          0  0.00%  0.00%  0.00%   0 HRPC hlfm reques
  87     1210685  29710601         40  1.11%  0.49%  0.30%   0 HLFM address lea
  88        3455   1005677          3  0.00%  0.01%  0.00%   0 HLFM aging proce
  89      652663  29710609         21  0.63%  0.22%  0.12%   0 HLFM address ret
  90          16         8       2000  0.00%  0.00%  0.00%   0 HRPC emac reques
  91           0         1          0  0.00%  0.00%  0.00%   0 HRPC hulc misc r
  92        6078    343435         17  0.00%  0.00%  0.00%   0 HVLAN main bkgrd
  93           0         2          0  0.00%  0.00%  0.00%   0 HVLAN Mapped Vla
  94           8         2       4000  0.00%  0.00%  0.00%   0 Vlan shutdown Pr
  95           0         3          0  0.00%  0.00%  0.00%   0 HRPC vlan reques
  96           0         1          0  0.00%  0.00%  0.00%   0 HULC VLAN REF Ba
  97         494     17174         28  0.00%  0.00%  0.00%   0 hulc_xps_process
  98           0         1          0  0.00%  0.00%  0.00%   0 HRPC ilp request
  99       19613   1005683         19  0.00%  0.00%  0.00%   0 Hulc ILP Alchemy
 100           0         1          0  0.00%  0.00%  0.00%   0 HULC PM Vector P
 101           0         1          0  0.00%  0.00%  0.00%   0 HPM Msg Retry Pr
 102        4215       943       4469  0.31%  0.25%  0.18%   0 Exec
 103     7342839  15889693        462  0.31%  0.95%  0.91%   0 hpm main process
 104
*Mar 12 22:55:32.651: %SW_MATM-4-MACFLAP_NOTIF: Host 0006.7603.00e9 in vlan 20 is flapping between port Gi0/1 and port Te1/1     0        36          0  0.00%  0.00%  0.00%   0 HPM Stack Sync P
 105           0         1          0  0.00%  0.00%  0.00%   0 HRPC pm request
 106    19456863   1005675      19347  1.59%  1.67%  1.70%   0 hpm counter proc
 107           0         1          0  0.00%  0.00%  0.00%   0 HRPC pm-counters
 108           0         1          0  0.00%  0.00%  0.00%   0 hpm vp events ca
 109           0         1          0  0.00%  0.00%  0.00%   0 HRPC hcmp reques
 110          25       492         50  0.00%  0.00%  0.00%   0 HCEF ADJ Refresh
 111           0         1          0  0.00%  0.00%  0.00%   0 HRPC hl3mm reque
 112           0         1          0  0.00%  0.00%  0.00%   0 hl3md_rpfq_thrl_
 113        7759    716675         10  0.00%  0.00%  0.00%   0 hl3mm
 114        3792    514856          7  0.00%  0.00%  0.00%   0 hl3mm_rp
 115           0         1          0  0.00%  0.00%  0.00%   0 HACL Queue Proce
 116           0         1          0  0.00%  0.00%  0.00%   0 HRPC acl request
 117           0        14          0  0.00%  0.00%  0.00%   0 HACL Acl Manager
 118           0         1          0  0.00%  0.00%  0.00%   0 HRPC aim request
 119           0         1          0  0.00%  0.00%  0.00%   0 HRPC backup inte
 120        1057      3448        306  0.00%  0.00%  0.00%   0 OBFL TEMP obfl0
 121           0         1          0  0.00%  0.00%  0.00%   0 HRPC cdp request
 122           0         1          0  0.00%  0.00%  0.00%   0 HULC CISP Proces
 123           0         1          0  0.00%  0.00%  0.00%   0 HRPC dot1x reque
 124           0         3          0  0.00%  0.00%  0.00%   0 HULC DOT1X Proce
 125           0         1          0  0.00%  0.00%  0.00%   0 HRPC lldp reques
 126           0         2          0  0.00%  0.00%  0.00%   0 MACsec Process
 127           0         1          0  0.00%  0.00%  0.00%   0 HRPC macsec requ
 128           0         1          0  0.00%  0.00%  0.00%   0 HRPC system mtu
 129           0         1          0  0.00%  0.00%  0.00%   0 HRPC rep request
 130           0         4          0  0.00%  0.00%  0.00%   0 REP Helper Proc
 131           0         1          0  0.00%  0.00%  0.00%   0 HRPC sdm request
 132           0         1          0  0.00%  0.00%
*Mar 12 22:55:36.342: %SW_MATM-4-MACFLAP_NOTIF: Host 0006.7601.fef0 in vlan 20 is flapping between port Gi0/1 and port Te1/10.00%   0 SMI MSG Retry Pr
 133           0         1          0  0.00%  0.00%  0.00%   0 HRPC Smart Insta
 134     2243362   5028316        446  0.31%  0.17%  0.21%   0 Hulc Storm Contr
 135           0         2          0  0.00%  0.00%  0.00%   0 HSTP Sync Proces
 136           0         1          0  0.00%  0.00%  0.00%   0 HRPC stp_cli req
 137           0         1          0  0.00%  0.00%  0.00%   0 HRPC stp_state_s
 138           0         2          0  0.00%  0.00%  0.00%   0 S/W Bridge Proce
 139           0         1          0  0.00%  0.00%  0.00%   0 HRPC hudld reque
 140           0         1          0  0.00%  0.00%  0.00%   0 HRPC vqpc reques
 141           0         1          0  0.00%  0.00%  0.00%   0 HRPC iec_load_ba
 142        1687   1005687          1  0.00%  0.00%  0.00%   0 IEC Load balance
 143           0         1          0  0.00%  0.00%  0.00%   0 HRPC l2pt qnq rp
 144           0         1          0  0.00%  0.00%  0.00%   0 HRPC hled reques
 145    35231905  23626061       1491  3.35%  4.90%  4.70%   0 Hulc LED Process
 146      659877    754678        874  0.00%  0.07%  0.05%   0 HL3U bkgrd proce
 147           0         1          0  0.00%  0.00%  0.00%   0 HRPC hl3u reques
 148        3263    235700         13  0.00%  0.00%  0.00%   0 HL3U PBR bkgrd p
 149         299      8607         34  0.00%  0.00%  0.00%   0 HL3U PBR n-h res
 151           0         1          0  0.00%  0.00%  0.00%   0 HRPC dtp request
 152           0         1          0  0.00%  0.00%  0.00%   0 HRPC show_forwar
 153           0         1          0  0.00%  0.00%  0.00%   0 HRPC snmp reques
 154           0         1          0  0.00%  0.00%  0.00%   0 HULC SNMP Proces
 155     3730636    205623      18143  0.31%  0.33%  0.31%   0 HQM Stack Proces
 156      341588    411228        830  0.00%  0.05%  0.01%   0 HRPC qos request
 157           0         1          0  0.00%  0.00%  0.00%   0 HRPC span reques
 158           0         1          0  0.00%  0.00%  0.00%   0 HRPC system post
 159           0         1          0  0.00%  0.00%  0.00%   0 Hulc Reload Mana
 160           0         1          0  0.00%  0.00%  0.00%   0 HRPC hrcli-event
 161      460654     25509      18058  0.00%  0.00%  0.00%   0 crypto sw pk pro
 162           0         2          0  0.00%  0.00%  0.00%   0 image mgr
 163           0         5          0  0.00%  0.00%  0.00%   0 HL2MCM
 164           9         5       1800  0.00%  0.00%  0.00%   0 HL2MCM
 165           0         2          0  0.00%  0.00%  0.00%   0 AAA Server
 166           0         1          0  0.00%  0.00%  0.00%   0 AAA ACCT Proc
 167           0         1          0  0.00%  0.00%  0.00%   0 ACCT Periodic Pr
 168           0         1          0  0.00%  0.00%  0.00%   0 AAA System Acct
 169           0         1          0  0.00%  0.00%  0.00%   0 AUTH POLICY Fram
 170           0        12          0  0.00%  0.00%  0.00%   0 Auth Manager
 171           0         1          0  0.00%  0.00%  0.00%   0 Auth-proxy AAA B
 172          25      3443          7  0.00%  0.00%  0.00%   0 IP Admin SM Proc
 173      118933    103699       1146  0.00%  0.01%  0.00%   0 CDP Protocol
 174        3095     68687         45  0.00%  0.00%  0.00%   0 MDFS LC Download
 175           0         2          0  0.00%  0.00%  0.00%   0 ENABLE AAA
 176           0         1          0  0.00%  0.00%  0.00%   0 CMD HANDLER
 177           0         2          0  0.00%  0.00%  0.00%   0 AAA Dictionary R
 178           0         5          0  0.00%  0.00%  0.00%   0 SXP CORE
 179         193      8608         22  0.00%  0.00%  0.00%   0 DHCP Snooping
 180           0         2          0  0.00%  0.00%  0.00%   0 Dot1x Mgr Proces
 181           0         1          0  0.00%  0.00%  0.00%   0 EAP Framework
 182           0         1          0  0.00%  0.00%  0.00%   0 EAP Test
 183           0         2          0  0.00%  0.00%  0.00%   0 EAPoUDP Process
 184           0         3          0  0.00%  0.00%  0.00%   0 CEF switching ba
 185         159     17215          9  0.00%  0.00%  0.00%   0 IP Input
 186           0         1          0  0.00%  0.00%  0.00%   0 ICMP event handl
 187       21551   1991912         10  0.00%  0.00%  0.00%   0 IP ARP Track
 188        1339   1025542          1  0.00%  0.00%  0.00%   0 fnvRootHubPortSt
 189           0         1          0  0.00%  0.00%  0.00%   0 tHUB
 190       48746  10190423          4  0.00%  0.04%  0.00%   0 MDFS MFIB Proces
 191           0         3          0  0.00%  0.00%  0.00%   0 ADJ resolve proc
 192           0         2          0  0.00%  0.00%  0.00%   0 ADJ NSF process
 193           0         1          0  0.00%  0.00%  0.00%   0 IPv6 ping proces
 194           0         2          0  0.00%  0.00%  0.00%   0 KRB5 AAA
 195           0         1          0  0.00%  0.00%  0.00%   0 MAB Framework
 196           9         2       4500  0.00%  0.00%  0.00%   0 MKA
 197          25        13       1923  0.00%  0.00%  0.00%   0 SpanTree Helper
 198           0         2          0  0.00%  0.00%  0.00%   0 REP Topology cha
 199           0         1          0  0.00%  0.00%  0.00%   0 SMI Director DB
 200           0         1          0  0.00%  0.00%  0.00%   0 SMI CDP Update H
 201           0         1          0  0.00%  0.00%  0.00%   0 SMI Backup Proce
 202           0         2          0  0.00%  0.00%  0.00%   0 SMI IBC server p
 203           0         1          0  0.00%  0.00%  0.00%   0 SMI IBC client p
 204           9         2       4500
This is the uplink switch (vss) , it says the mac address from 'sw2'
VSS#sh mac address-table | in fef0
      19 0006.7601.fef0  dynamic  Yes        0     Te1/3/2
cpu log from vss has attached  since it is long list .
